Old 08-26-2016, 04:28 PM   #1
whjdm069
Drives: 2015 scion frs
Coilovers for a 2inch drop
Looking for a good set of coilovers in the 1k range that allow for a 2 inch drop and still can perform close to stock. Lots of info out there I just haven't been able to find specific information. I have a stock 2015 frs. Brand is not as important as function. Yes I have searched but a lot of the info is from a few years back. Thanks in advance.
whjdm069 is offline   Reply With Quote
Old 08-26-2016, 04:33 PM   #2
Amputechture
Drives: 2014 BRZ
When you say "perform close to stock" do you mean feel as comfortable as stock? If so your two best bets for a compliant ride without breaking the bank are Bilstein B14s and ST. I have B14s going on this Sunday, you can't go that low on them....I'm not even sure if they offer that much drop. But they are known to be the most compliant street ride...improvement over OEM even. ST will get you there and they are pretty "cheap" at around $800.
Amputechture is offline   Reply With Quote
The Following 2 Users Say Thank You to Amputechture For This Useful Post:
Shark_Bait88 (08-26-2016), smg1138 (08-26-2016)
Old 08-26-2016, 06:57 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
Also 2" drop is far from mild drop. Be ready to also buy other suspension parts, eg. for roll center correction, diff rising and so on.
One can get comfortable enough ride on higher drop levels vs far from ideal stock shocks and with big enough investments, but please, don't mention "importance of function". Reducing already low stock ground clearance and shock bumpless travel by 2", at least if daily driving is considered, is far from valuing function over form. Yes, you can reach that drop goal, but be truthful to yourself & be ready to sacrifice things in process to reach your goal of low drop (probably for bling/visual "form" purposes over "function").
Mr.ac (08-26-2016), x808drifter (08-26-2016)
Old 08-27-2016, 01:21 AM   #4
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
You're basically asking for the impossible. Two inches is a lot of drop and it will not perform close to stock. My advice, get some KW's and drop about 1" and save yourself the headache.
smg1138 is offline   Reply With Quote
Old 08-27-2016, 11:49 AM   #5
shellslinger
Drives: Whiteout FRS
Air bags maybe?
shellslinger is offline   Reply With Quote
Old 08-27-2016, 02:46 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
OP didn't specify if he wants to only slam park or permanent drop.
If permanent 2" drop, suspension will need extra working on/investments no matter which exactly coilovers you'll use, including air ones. If one cares about handling / safety / longevity of car that is.
Old 08-27-2016, 05:41 PM   #7
Amputechture
Drives: 2014 BRZ
Budget for Rear LCA's and a roll centre kit as well.
Old 08-27-2016, 08:24 PM   #8
WRBrzRX
Drives: runs&drives
Generally dropping it reduces travel so it's going to get rougher than stock.
An easy and budget friendly option is to buy lowering springs (H&R Sport/Super Sport, TRD etc) and swap them onto your OEM Showa coils yourself via this thread. I believe H&R SS are 2"
http://www.ft86club.com/forums/showthread.php?t=32414
They aren't tightly compressed and can be swung out from the tire well to switch while still connected at the hub, just releasing the tops. Little trim of the bump stop might be necessary but spring manufacturer lets you know. I was surprised how easy it was.
Not a race solution obviously but great for a couple hundred bucks.
WRBrzRX is offline   Reply With Quote
Old 08-28-2016, 01:20 AM   #9
whjdm069
Thanks for all the replies. Definitely got some thinking to do.
Old 08-28-2016, 03:24 AM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
Amputechture: Apart from roll center kit to fix handling also diff riser, or otherwise rear axles bearings will have short mileage.
PBM pro coilovers drop height keonigt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-13-2015 10:27 PM
bc coilovers extreme drop mrharry Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-17-2014 07:00 PM
EOI: Bilstein B14 coilovers (price drop) Fizz Australia Classifieds 3 01-30-2014 02:38 AM
BC Racing Extreme Drop Coilovers 636 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 10-16-2013 12:42 PM
