08-13-2016, 07:16 PM | #1905 |
Drives: United States
Finally got some pics. Car was stock with just under 30k miles when i bought it 7 months ago during a deployment. Car has just under 31k miles now and i did all the mods within the last 2 months.
Wheels 18x9.5 enkei rpf1's squared Tires 265/35 continental DWS squared Tein flex Z coil overs Stance V2 rear LCA's Muteki burnt blue lug nuts Aftermarket front sway bar endlinks (idk what brank they where on there when i got the car) |
08-17-2016, 07:33 PM | #1906 | |
Drives: 2015 BRZ
The Following User Says Thank You to chezzy79 For This Useful Post: | brz11b (08-17-2016) |
08-17-2016, 07:39 PM | #1907 | |
Haha yeah it is. I love the flex Z's and the DWS tire, it grips good and looks great, the tread wear is awesome to. I got my LCA for a steal so i went with stance. The main reason I went with stance v2 is because it adds wheels travel when you go low and i originally intended to go as low as possible. I still am going to just not yet.
BTW i love that color man that was my first choice but i love my galaxy blue. Quote:
08-17-2016, 08:04 PM | #1908 | |
Drives: 2015 BRZ
One thing about Flex Z is that no matter how low you go, there is no change in the spring travel distance. I would get a Stance or Voodoo13 if I am upgrading the coilovers for sure
08-20-2016, 08:43 PM | #1910 |
Drives: Man
Stock Prius tires vs 245/40R17 Bridgestone RE71R
The Following User Says Thank You to slyphen For This Useful Post: | Jive Turkey (08-25-2016) |
08-22-2016, 10:24 AM | #1911 |
Drives: 10 Series
NT03s on 265s
I havent done an alignment yet and dont have LCA / Camber plates. Last edited by imovertheinternet; 08-23-2016 at 12:28 PM. |
The Following User Says Thank You to imovertheinternet For This Useful Post: | brz fred (08-22-2016) |
08-25-2016, 08:57 PM | #1912 | |
08-25-2016, 09:57 PM | #1913 |
Drives: It runs
The Following 8 Users Say Thank You to Joeyk For This Useful Post: | ajaxthebetter (08-29-2016), batlwagn (08-28-2016), Bowen (08-25-2016), civicdrivr (08-26-2016), FujiwaraTofu86 (02-16-2017), Hostile_Kittens (08-27-2016), Ry.ruzn (08-28-2016), Spankopotomous (05-31-2021) |
08-27-2016, 12:23 PM | #1914 | |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
unstable at high speeds likely means toe is an issue. everyone should toe in the rear slightly for that stability. the car wanting to follow groves is normal for a car with a more aggressive alignment and tires, it will tramline no matter what you do. just go to AZP, alignment isn't expensive there, and get yourself a set of SPC arms. they are 250 installed at AZP. also not expensive compared to the other garbage out there that will seize. |
The Following 2 Users Say Thank You to Jive Turkey For This Useful Post: | BassBoosted86 (07-30-2017), Ry.ruzn (08-28-2016) |
08-28-2016, 12:46 AM | #1915 |
Grip>Drift
Drives: FRS
Rain traction is almost exclusively down to tires (compound and tread abilities). And WIDE summer tires are just asking to hydroplane.
Also generally speaking the more aggressive your alignment is for going around corners the less it wants to go in a straight line. Sent from my iPhone using Tapatalk
08-31-2016, 07:26 PM | #1916 |
the tuna, no crust.
if ya'll could stop block quoting photos that would be great
265 mpss 18x9.5 +40, over 50k miles with this style setup now. |
The Following 4 Users Say Thank You to Jive Turkey For This Useful Post: | 10Stars (09-01-2016), Hostile_Kittens (09-03-2016), Moooiiissst (11-01-2016), SuperDave (11-16-2016) |
09-01-2016, 11:09 AM | #1917 |
Drives: Toyobaruion
255/35/18 on 18x9.5 +38 Going to 265s this weekend. |
The Following User Says Thank You to c4lvinnn For This Useful Post: | Iceman (09-16-2016) |
09-01-2016, 10:54 PM | #1918 |
Drives: FRS
@c4lvinnn that is sweet set up you got there..
i love me some simple lowered FRS.. do you have more side shots
'14 Scion FRS
Tein Flex TE37 |
Similar Threads | ||||
Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
