Old 08-13-2016, 07:16 PM   #1905
brz11b
Drives: United States
Finally got some pics. Car was stock with just under 30k miles when i bought it 7 months ago during a deployment. Car has just under 31k miles now and i did all the mods within the last 2 months.
Wheels 18x9.5 enkei rpf1's squared
Tires 265/35 continental DWS squared
Tein flex Z coil overs
Stance V2 rear LCA's
Muteki burnt blue lug nuts
Aftermarket front sway bar endlinks (idk what brank they where on there when i got the car)
brz11b is offline   Reply With Quote
The Following 2 Users Say Thank You to brz11b For This Useful Post:
nima314 (08-13-2016), slow15frs (08-15-2016)
Old 08-17-2016, 07:33 PM   #1906
chezzy79
chezzy79's Avatar
Drives: 2015 BRZ
It's pretty crazy how your post is right before mine haha, I just got my squared 265/35 Continental DWS installed today, lowered on Tein Flex Z, with 18x9.5 TC1015N's. I was considering getting a Stance or Voodoo13 LCA as well, but the drop on those are pointless with Flex Z so now I'm eyeing the Velox LCA...
chezzy79 is offline   Reply With Quote
The Following User Says Thank You to chezzy79 For This Useful Post:
brz11b (08-17-2016)
Old 08-17-2016, 07:39 PM   #1907
brz11b
Haha yeah it is. I love the flex Z's and the DWS tire, it grips good and looks great, the tread wear is awesome to. I got my LCA for a steal so i went with stance. The main reason I went with stance v2 is because it adds wheels travel when you go low and i originally intended to go as low as possible. I still am going to just not yet.
BTW i love that color man that was my first choice but i love my galaxy blue.
chezzy79 (08-17-2016), RichardJ (10-20-2016)
Old 08-17-2016, 08:04 PM   #1908
chezzy79
chezzy79's Avatar
Drives: 2015 BRZ
that's ironic, WRB and GBS were definitely my top two choices, I got a good deal on DGM so I went with it, since it was a close third for me.
One thing about Flex Z is that no matter how low you go, there is no change in the spring travel distance. I would get a Stance or Voodoo13 if I am upgrading the coilovers for sure
brz11b (08-17-2016)
Old 08-20-2016, 06:38 PM   #1909
brz fred
Drives: 2015 Brz
finally joined the gang, 255/35/18
brz fred is offline   Reply With Quote
The Following User Says Thank You to brz fred For This Useful Post:
nima314 (08-20-2016)
Old 08-20-2016, 08:43 PM   #1910
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
Stock Prius tires vs 245/40R17 Bridgestone RE71R
slyphen is offline   Reply With Quote
The Following User Says Thank You to slyphen For This Useful Post:
Jive Turkey (08-25-2016)
Old 08-22-2016, 10:24 AM   #1911
imovertheinternet
Drives: 10 Series
NT03s on 265s
I havent done an alignment yet and dont have LCA / Camber plates.
imovertheinternet is offline   Reply With Quote
The Following User Says Thank You to imovertheinternet For This Useful Post:
brz fred (08-22-2016)
Old 08-25-2016, 08:57 PM   #1912
Ry.ruzn
Ry.ruzn's Avatar
Originally Posted by c4lvinnn View Post
Attitude? You're the one who called two people's specs out and said they were "terrible." My brash attitude is along the same lines as yours.
BC Coilovers. 0.08 toe in as well, -3.5* front camber with toe at 0.
This isn't my first rodeo with camber. I used to run -6.4* (natural from just the drop) on a double wishbone front suspension and drove that like a madman. Rears were around -4.5. Tires lasted me 10-12k miles. Completely negligible to me so don't use tire wear as an explanation as this is less than half of that specific set up. Oh and that was with 360 treadwear which isn't much...
My car is very reactive to input which I want and has no negative effects, no squirelly, no unstable high speeds from toe or camber, etc.
Does everyone forget that toe kills tires, not camber?
I have unstable high speeds, horrible rain traction, and car pulls left/right when coming to a stop as if its pulling to every groove on the street. Shop that did my alignment I'm sure murdered my alignment. Been thinking of hitting up AZP installs or Motoeast for correction + install of my LCA's....SIGHHHHH
Ry.ruzn is offline   Reply With Quote
Old 08-25-2016, 09:57 PM   #1913
Joeyk
Drives: It runs
ZE40 18x10 +40
275-35-18 square set up
-2.5 front 3mm total toe out
-2.4 rear 0 toe
no real issues... doesnt rub. (any more)
Joeyk is offline   Reply With Quote
The Following 8 Users Say Thank You to Joeyk For This Useful Post:
ajaxthebetter (08-29-2016), batlwagn (08-28-2016), Bowen (08-25-2016), civicdrivr (08-26-2016), FujiwaraTofu86 (02-16-2017), Hostile_Kittens (08-27-2016), Ry.ruzn (08-28-2016), Spankopotomous (05-31-2021)
Old 08-27-2016, 12:23 PM   #1914
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
rain traction depends on tires also.
unstable at high speeds likely means toe is an issue. everyone should toe in the rear slightly for that stability.
the car wanting to follow groves is normal for a car with a more aggressive alignment and tires, it will tramline no matter what you do.
just go to AZP, alignment isn't expensive there, and get yourself a set of SPC arms. they are 250 installed at AZP. also not expensive compared to the other garbage out there that will seize.
Jive Turkey is offline   Reply With Quote
The Following 2 Users Say Thank You to Jive Turkey For This Useful Post:
BassBoosted86 (07-30-2017), Ry.ruzn (08-28-2016)
Old 08-28-2016, 12:46 AM   #1915
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Rain traction is almost exclusively down to tires (compound and tread abilities). And WIDE summer tires are just asking to hydroplane.
Also generally speaking the more aggressive your alignment is for going around corners the less it wants to go in a straight line.
Old 08-31-2016, 07:26 PM   #1916
Jive Turkey
the tuna, no crust.
if ya'll could stop block quoting photos that would be great
265 mpss 18x9.5 +40, over 50k miles with this style setup now.
The Following 4 Users Say Thank You to Jive Turkey For This Useful Post:
10Stars (09-01-2016), Hostile_Kittens (09-03-2016), Moooiiissst (11-01-2016), SuperDave (11-16-2016)
Old 09-01-2016, 11:09 AM   #1917
c4lvinnn
Drives: Toyobaruion
255/35/18 on 18x9.5 +38
Going to 265s this weekend.
c4lvinnn is offline   Reply With Quote
The Following User Says Thank You to c4lvinnn For This Useful Post:
Iceman (09-16-2016)
Old 09-01-2016, 10:54 PM   #1918
PeterFRS
PeterFRS's Avatar
Drives: FRS
@c4lvinnn that is sweet set up you got there..
i love me some simple lowered FRS..
do you have more side shots
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
