Old 08-26-2016, 06:49 PM   #1
radroach
Drives: car
Would you rebuild your gearbox or buy another?
So say your syncros are worn or a tooth on 2nd gets chipped, I'm sure its happened to many a gearbox. When it comes time, what do you do: buy a brand new one, get a donor, or rebuild?
Old 08-26-2016, 08:02 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
No one clear cut answer fitting for everybody. Too many unknown / undefined variables that may differ a lot for ones answering and where they are located. For example if car is still under warranty, how much gearbox costs new, how much costs donor gearbox, how much just worn parts, how much local shops charge for rebuild and how much for drop in replacement.
Old 08-26-2016, 08:41 PM   #3
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Factory gearbox sucks, its a made out toilet paper.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 08-26-2016, 08:48 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
yes.
Old 08-26-2016, 09:05 PM   #5
Back in the day ....... I would have (and I have) rebuilt the transmission.
Went to the junkyard, pulled out 3 transmissions, took them all apart, laid out the pieces in order, put all the best pieces back in the best case, put the rest of them back together, returned them to the junk yard ...... told them none of them fit.
(sorry, times were tough .... we were poor......)
Now, if I had transmission problems, I'd use that as justification to get a new car ......
Old 08-26-2016, 09:43 PM   #6
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
No.
MS, CSCS, TSAC-F, CPT
Old 08-26-2016, 10:06 PM   #7
This^
Originally Posted by mav1178 View Post
yes.
This^
Originally Posted by weederr33 View Post
No.
This^
And especially this ^^^^^^^
Old 08-26-2016, 11:51 PM   #8
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Here's a clue: I just rebuilt a trans on my other car.
Working used trans ~350
ONE (used but mostly new) gear for the rebuild ~350.
You do the math
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
Old 08-31-2016, 11:22 PM   #9
DieselBones
Drives: 2013 Scion FR-S 6MT FA20
Factory gearbox with low mileage on eBay shipped for around 750
DieselBones is offline   Reply With Quote
Old 09-01-2016, 04:16 AM   #10
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Get the upgraded gearset (PAR?) then use that as an excuse to get a turbo!
Old 09-28-2016, 12:14 PM   #11
JacksTrans
JacksTrans's Avatar
Drives: Scion FRS - "FRSKY"
If you've got a few worn synchros, maybe a fork and synchro sleeve that needs to be replaced, then a rebuild is a good option, especially if you'll be getting back a trans that is massaged to shift better than OEM.
If you have broken a tooth on a gear then it gets a little more expensive, but frankly, the gears in this version of the AZ6 are not horribly expensive. Retail on the synchro gears is between $80-120.
That being said, if 3rd or 4th is broken, then there's a high probability that the mating gear on the countershaft has sustained some damage. That shaft is almost the cost of a good used core, so that makes the decision a lot easier to make!
JacksTrans is offline   Reply With Quote
Old 09-28-2016, 12:19 PM   #12
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Just skip second gear.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 09-28-2016, 12:29 PM   #13
MarkR171
MarkR171's Avatar
Drives: '05 Elise
[ame="https://www.youtube.com/watch?v=bbKGRESi6ME"]Sequential 6spd Toyota 86 by Holinger - YouTube[/ame]
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
MarkR171 is offline   Reply With Quote
Old 09-28-2016, 12:49 PM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
DO WANT!! and probably will never afford
gearbox issues blown Engine, Exhaust, Transmission 4 10-13-2014 02:22 PM
built gearbox? Rocket.BRZ Engine, Exhaust, Transmission 2 09-07-2014 01:28 PM
Gearbox Bushing Kit - BEST OFFER HORSEPOWER DIRECT Transmission and Driveline 2 01-08-2014 09:35 PM
Gearbox Stiffness? pevangelista Issues | Warranty | Recalls / TSB 3 05-08-2013 01:00 AM
Gearbox Oil os86 Engine, Exhaust, Transmission 1 07-18-2012 02:37 PM
