Old 08-24-2016, 08:39 AM   #15
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Originally Posted by Panamaniac View Post
I have an Autopower Roll Cage installed.
What pictures do you want?
I would love to see how people welded/bolted the plates to the car. Any shots of that would be helpful.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 08-24-2016, 11:17 AM   #16
Kris86
Kris86's Avatar
Drives: RHD Gt86
Originally Posted by Apex-Apex View Post
How did u go about installing this cage??
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 08-24-2016, 01:11 PM   #17
Apex-Apex
Apex-Apex's Avatar
Originally Posted by FRS Justin View Post
ok how can the bar be ahead of the b pillar on the last pick and behind it on the first pic?..... smh
The cage is not installed
I do like the design but fitment cant be determined
Calm down, it's installed in both pictures.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 08-24-2016, 01:13 PM   #18
Apex-Apex
Apex-Apex's Avatar
With lots of tears and cuts In all seriousness though, it was pretty straight forward. Remove rear interior, remove front seats, pull back carpet, slide in, install and put everything back.
IG: @apexapexapex
The Following User Says Thank You to Apex-Apex For This Useful Post:
Kris86 (08-24-2016)
Old 08-24-2016, 01:15 PM   #19
Apex-Apex
Apex-Apex's Avatar
Originally Posted by GSpeed View Post
How is rear visibility with the rear X? We thought about adding that to our design (still might) but we were worried it would make it too hard to see out the back, due to how high the rear attachment points are.
Jake
Hello Jake,
I honestly can't see crap besides the little window above my X. It's enough to see cop lights, I've had experience with that.
IG: @apexapexapex
The Following 4 Users Say Thank You to Apex-Apex For This Useful Post:
DustinS (09-01-2016), GSpeed (08-24-2016), Hyper4mance2k (02-08-2018), Takumi788 (08-24-2016)
Old 08-24-2016, 01:30 PM   #20
FRS Justin
Drives: 2013 Asphalt FRS
still never answered the question but that's ok
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 08-24-2016, 01:30 PM   #21
Kris86
Kris86's Avatar
Drives: RHD Gt86
awesome! where could I Purchase the "X" bar that you have installed along with it from?
Old 08-24-2016, 02:07 PM   #22
Apex-Apex
Apex-Apex's Avatar
I don't get how much more I can answer besides it's installed. Like everyone said, it's just the angle
IG: @apexapexapex
Old 08-24-2016, 02:07 PM   #23
Apex-Apex
Apex-Apex's Avatar
I had my friend's shop weld in the X for me.
IG: @apexapexapex
Old 08-25-2016, 01:32 AM   #24
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Mine is the full cage, but the roll bar mounting points are the same as the main hoop.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
The Following User Says Thank You to zdr93523 For This Useful Post:
Takumi788 (08-25-2016)
Old 08-25-2016, 07:02 AM   #25
Takumi788
JHerbert Racing
Takumi788's Avatar
Perfect! Thank you!
Old 08-30-2016, 04:33 PM   #26
forwallblakmail
Troll Level: Expert
forwallblakmail's Avatar
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
Have you run into any tech issues with the cage? I noticed you're also in ST2.
Thanks!
Nick K.
NASA ST5/TT5 #130
Southeast Region
forwallblakmail is offline   Reply With Quote
Old 08-30-2016, 11:26 PM   #27
zdr93523
zdr93523's Avatar
Thanks!
No, the Autopower cage is NASA and SCCA legal. The diagonal bar and harness bar intersect per the rules, the number of bends in each bar complies, and the bolted area are the correct size and have the correct number of bolts. The roll bar footer and the door bars are welded in so it is not a simple "bolt-in" even though it is called one. The footer requires you to build a plinth box to fill in the triangular gaps on the sides due to the curvature of the leading edge of the rear seat base. The cage is 1.75" tube which is larger than required for the car's weight. The only issue (not really an issue) is that I have a Sparco Ergo XL and it is absolutely the largest seat you can fit in the car with the cage and you have to eliminate the slider. I'm 6'2" 225lbs and my wife is 5'3" so not having a slider requires a significant back pad. She runs the car in TT2.
www.makesmodels.com
www.camautomag.com
forwallblakmail (08-31-2016)
Old 08-31-2016, 08:34 PM   #28
forwallblakmail
Troll Level: Expert
Even with the diagonal bar being at an angle as it intersects the harness bar? (I have the 4pt in my car now). I've been told by NASA guys it wont pass if I turn it into the full cage.
Nick K.
NASA ST5/TT5 #130
Southeast Region
4 Point Roll Bar, Seat, Harness Installed IPGJames Tracking / Autocross / HPDE / Drifting 10 02-04-2016 11:20 AM
WTB Autopower roll bar bjun Want-To-Buy Requests 1 12-09-2015 01:06 PM
port installed spring and roll bar for BRZ danh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 04-30-2015 04:38 PM
Show us your Custom Roll Cage or Roll Bar and Harness Setup Black Tire Tracking / Autocross / HPDE / Drifting 27 02-13-2015 09:59 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 06:54 PM
