Drives: Firestorm MT FR-S
Clutch Replaced
I had my clutch replaced today by Toyota and after I picked it up and drove it home I noticed a few things I wasn't used to. I'm not sure if what I am going to describe is normal operation after a clutch replacement or something I should be concerned about...
When I shift into different gears I can hear and feel the gears changing as I shift. Specifically, below my right forearm as I shift I kept feeling a faint noise like something was hitting the armrest underneath my arm. I had never felt or heard anything prior to the replacement and prior to repair it was smooth shifting through all gears. Do I need to allow the car to go through a break-in period? Also, as the car was idling the RPMS would bounce from the idle point of 600 RPMS then up to 7-800 RPMs and then dip down to 480 RPMS and back to 600 RPMS every 15 seconds or so - the AC was on. When I have the AC off it holds at 600 RPMS which is normal from previous operation. The RPM fluctuations would happen every now and again before when my AC was on, but it has me concerned as I just picked up the car up and I'm experiencing these different things. Should I give it a fee days for the car to adjust to the new clutch? I'm not tech savy enough to know if that has anything to do with it, but any feedback is appreciated. The car has about 53500 miles - 2013. Thanks. - Rob ********VIDEOS UPLOADED ONTO PAGE 3*********** Last edited by StOpNG0x; 08-28-2016 at 11:42 AM. |
#2 |
Drives: car
When doing a clutch job they typically drain the trans fluid and refill it after. Changing it from factory fill changes the shift feel and gearbox sound, maybe because it's a bit slicker.
RPM fluctuations are normal even if A/C isn't on it will fluctuate if you roll both windows down for instance. Last edited by radroach; 08-24-2016 at 07:09 AM. |
#3 | |
Why do you figure your old clutch went out .. ?? Boosted, tracked, new driver, don't know ....?? humfrz |
#4 |
#5 | |
Drives: 2014 BRZ Limited 6MT
I hope this is a serious question and ur not trollin because im about to answer it lol. The drive shaft has to come out first so trans fluid will pour out of that end and then you got a mess.
#6 |
One of the throwout bearings went and it happened to be covered under warranty. They said it wouldn't be a bad idea to just replace the entire clutch since everything has to come out just to replace the bearings. I said why not and all I paid for was parts instead of getting charged $1500 with labor all I paid was $587 including tax.
#7 | |
#8 |
Just curious as to what happens when the tob fails
#9 |
They don't go all at once. First they get noisy and if you're in tune with it, you'll feel it rumble in the pedal.
They screech when they start seizing. Don't wait that long.
#10 |
I have determined my idle noise is the flywheel chattering because it goes away when car heats up or clutch pedal is depressed. Guess if something brakes we will know then LOL
#11 | |
I didn't realize the tail shaft had to come out of the transmission on the FR-S. I'm stuck in the 50's again ...... We used to take apart the universal joint and then drop the driveshaft. Or, at least I did ...... yep, those "C" clips were a butch to get off of the universal joint without messing them up ..... ![]() Thanks again fer the edumacation. I'm going to add you to my consulting staff, along with @Ultramaroon. humfrz |
#12 | |
Stock lube does a better job of hiding it at the expense of being tougher to shift when cold.
#13 | |
#14 | |
| Should I get my HPFP replaced? | hmong337 | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 04-08-2015 07:52 AM |
| Had to get one tire replaced, where to put it? | malave7567 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 07-29-2014 06:33 AM |
| Chirp Gone Nothing Replaced | Employee | CANADA | 6 | 08-04-2013 12:25 PM |
| Can this part be replaced? | czar07 | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 11-07-2012 01:46 PM |
| I may have had the first ever manufacturer-replaced FR-S | VZ86 | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 05-13-2012 12:39 AM |
