Old 08-22-2016, 01:02 AM   #1
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
Traction control issue, won't turn off
So it was my last run today in autocross, i never turned the car off, i turned traction control off(held 5s) from the beginning. It wasn't until i was already into my first stretch, i noticed my traction control is on. I tried to turn it off during straights, but it just won't. later on, i forgot about the whole thing until we are on the road. I remembered and try to see if i can turn it off while cruising. It didn't. pressing the button many times and tried to hold it down, it just wont turn off... VSC Sport work just fine.
So once we got to a traffic light, i tried again, and this time light came on(trac off) and also held it down for 5 sec to turn it full off, and it worked. I started moving, it worked until i got above 30mph, nothing happened above that, doesn't matter how many time i press it. Drop speed back down, it worked again... my friends in their BRZ/FRS told me they can turn it on while at any speed(we were cruising together).
Has anyone else had this problem?
Edit: additional info. Just got new wheels and tires. TPMS warning light would flash for a bit and then stay solid. This happened while I was driving thinking the car finally figured out there is no sensor on the wheels. Now it flash everytime I start the car and turn solid
slyphen is offline   Reply With Quote
Old 08-22-2016, 08:50 AM   #2
PMPB
Drives: BRZ Sport-tech
It automatically turns on above 30mph... it's not broken.
PMPB is offline   Reply With Quote
The Following User Says Thank You to PMPB For This Useful Post:
Vulcan (08-22-2016)
Old 08-22-2016, 09:31 AM   #3
slyphen
Drives: Man
I've done plenty races with it completely off going way above 30. What do you mean.
Sent from my SM-G920V using Tapatalk
Old 08-22-2016, 09:40 AM   #4
FX86
PEDAL DANCE
The Following 2 Users Say Thank You to FX86 For This Useful Post:
CSG Mike (08-22-2016), Ultramaroon (08-22-2016)
Old 08-22-2016, 09:57 AM   #5
slyphen
Drives: Man
Originally Posted by FX86 View Post
PEDAL DANCE
That does not help me fix the problem. I'm checking here before taking it to the dealers.
Old 08-22-2016, 10:28 AM   #6
humfrz (08-22-2016), PWBRZ (08-22-2016), strat61caster (08-22-2016)
Old 08-22-2016, 10:52 AM   #7
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Not when you hold it down for 5secs...
-Josh
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
justatroll (08-22-2016)
Old 08-22-2016, 12:11 PM   #8
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
If you hold the button for 5 seconds it is not supposed to turn back on based on vehicle speed.
Mine does not, and I can even turn if OFF above 30 MPH.
Did the OP lift a wheel by chance?
Search 'Ice Mode' and see what you find.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
Old 08-22-2016, 05:35 PM   #9
slyphen
Drives: Man
didn't find much in Ice Mode. i almost start to wonder if it had something to do with me swapping wheels/tires from stock. my friends all said they were able to turn it off above 30mph, while i can only do it when we are below 30mph. I wonder what the dealer would say if i take it in, they might blame my wheels, or the lack of TPMS sensor?
Old 08-22-2016, 05:51 PM   #10
Nothing to do with TPMS. Did you get both lights after the 5-second push, or just the skidding car?
Old 08-22-2016, 05:58 PM   #11
Sounds to me like it is working exactly as it should. You can not turn the traction control off while moving and if just it is turned off it comes back on at 30.
Oh and your not having TPMS sensors has nothing to do with it.
slyphen (08-22-2016)
Old 08-22-2016, 06:07 PM   #12
slyphen
Drives: Man
Ok, now i read it again, it seems like i can not turn Trac and VSC (hold down button till both light comes on) while moving, and i can only turn Trac off while im traveling below 30. i get it. still don't explain why 4 other BRZ/FRS with me was able to do it :/
Thanks anyway i guess.
Old 08-22-2016, 06:52 PM   #13
I doubt they can.
Old 08-22-2016, 07:05 PM   #14
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
I doubt they can.
I can. The trac light doesn't come on by itself like it would below 30MPH, but if I hold it long enough, they both come on at the same time.
jawn is offline   Reply With Quote
Why doesn't traction/stability control actually turn off? Ganthrithor BRZ First-Gen (2012+) — General Topics 84 09-13-2015 01:37 PM
Traction control issue? mit_peid Issues | Warranty | Recalls / TSB 30 08-24-2013 04:17 AM
Turn off Traction Control FR_Soldier_77 Scion FR-S / Toyota 86 GT86 General Forum 35 01-22-2013 08:47 PM
traction control issue *KID* Scion FR-S / Toyota 86 GT86 General Forum 13 07-08-2012 08:13 PM
