Old 08-14-2016, 08:31 PM   #645
fibble
Drives: 2015 86 GTS
Originally Posted by GT86 Guy View Post
I'm thinking about retuning it. Just flashing the stock ECU then stage 1 then stage 2 if those steps are necessary. With the Tomei headers I'm using a lot more gas it seems like. Idk if that's because I love the sound and I'm just smashing the pedal.
Those steps are not necessary - ECU reset after each flash.
If when you say "retune" you mean write/flash the same tune again (e.g. Stg 2 UEL), this is also probably not necessary. Its OK if you do it, but then drive the first 100+ miles smoothly in closed loop (no WOT) mode to help your car learn new fuel trims.
Logging your tune is the only way to tell if thing are OK. Read the posts linked in steve99 signature.
If you happen to have a Tactrix cable (or know someone who has one) and ECUflash/Romraider, you can pull the ROM and view the parameters. If this doesn't make a lot of sense to you, then simply flash and log with OFT.
fibble is offline   Reply With Quote
Old 08-16-2016, 01:58 AM   #646
GT86 Guy
Drives: 2016 Scion FRS Raven
First 100 miles? I was smashing it with that beautiful sound after 10 lol maybe thats why? That's what I meant by reflashing like flash the Stage 2 tune again and drive with low RPMs for the first 100 miles now that I know. Should I stay under a certain RPM?
GT86 Guy is offline   Reply With Quote
Old 08-16-2016, 05:48 AM   #647
fibble
Drives: 2015 86 GTS
Its not so much about revs, more about light and progressive throttle use - although staying under 5000 rpm might be a good idea.
You can configure the real time display on your OFT to show you whether you are closed or open loop. From memory, the parameter you want is Fuel System Status and 2 means you are closed loop (car will learn trims), 4 means open loop (no learning).
You don't have to reflash, you can just drive more gently from now. The more you stay in closed loop, the quicker the car will learn the correct trims and apply them in open loop.
The Following User Says Thank You to fibble For This Useful Post:
Teseo (08-16-2016)
Old 08-16-2016, 07:04 PM   #648
toyoyoyoyo86
Drives: 86
How do you know when the car has finished learning the correct trims?
Sent from my SM-G920I using Tapatalk
toyoyoyoyo86 is offline   Reply With Quote
Old 08-16-2016, 07:46 PM   #649
fibble
Drives: 2015 86 GTS
It never actually "finishes" learning trims as this is the process the ECU uses to deal with variations.
To give an analogy:
Your friend moves house and you are going to visit for the first time.
He asks how long you will be - he wants the fried chicken he is making you to be nice and hot .
You have never driven the route before so make a guess based on the distance (30 mins)
It takes you 45 mins to get there because of traffic, weather, etc.
Next time you drive there you tell him 45 mins - but it only takes you 35 mins. No traffic.
You've now been going there once a week for a year. You can pretty reliably estimate that it will take 32 mins in the dry and 44 mins in the wet. You can never be exactly precise because there are still variables (e.g. road works, slow grandpa, traffic light sequence), but you can give your friend a very good estimate.
9 times out of 10, dinner is nice and hot....you've "finished" learning your fuel trims.
General views seem to be that 100 miles of closed loop driving is a good start.....
Hopefully you will notice sharper throttle response, more power and better fuel mileage - although most of this will happen progressively
Boomerang (08-20-2016)
Old 08-16-2016, 08:21 PM   #650
phrosty
You really only need maybe ~20sec in each mafv "bin" to learn trims. The trick is to help the higher up bins learn -- these are ones you rarely use during actual driving and so by 100 miles you should have trained them, but you can speed it up by doing slow & steady (keep it closed loop) pulls up to 5000rpm -- it'll get you up to around 3 volts.
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
fibble (08-17-2016)
Old 08-17-2016, 07:03 PM   #651
toyoyoyoyo86
Drives: 86
My real time display shows mafv is 0v. Not 3v. Is there something wrong?
Old 08-17-2016, 09:41 PM   #652
steve99
Drives: FT86
unfortunatly several logging parameters do not work correctly with oft , this is on most 2015 and above ecu calibration id.
Old 08-19-2016, 11:55 PM   #653
mulekr1
mulekr1's Avatar
Drives: 15' Limited BRZ
I'm in NY, all they do is hook up OBD2 to read for CEL when I buy a OFT and turn off the p0420 code from the OFH, does that make it "not ready" or does that turn it off? If it says not ready i'd never pass and thats worrying.
mulekr1 is offline   Reply With Quote
Old 08-20-2016, 12:21 AM   #654
Teseo
Drives: frs
As far i know (on my experience) the stage 2 tune disable the the code p0420.
Old 08-20-2016, 05:11 AM   #655
steve99
Drives: FT86
Tunes for catless headers will disable the P0420 cel code for cat efficiency and you wont trigger cel light.
However no tune system i am aware of even ecutek, will bypass or set the readyness checks to good, this is a separate piece of code in ecu
So even though you wont get cel the readyness check for front cat will still show fail
Teseo (08-20-2016)
Old 08-20-2016, 07:34 AM   #656
Teseo
Drives: frs
Which is the best way?
Flash stock tune the moment before got inspected?
Old 08-20-2016, 07:58 AM   #657
Skyllz
Drives: Something fun.
New to me 2014 BRZ, was absolutely stock when I bought it as far as I know. No bolts had been touched anywhere from OEM.
I loaded Openflash manager on my PC, plugged the OFT, it did a firmware update(I think that's what it did). Took 4-5 minutes with my slow internet.
After this, I went and plugged the OFT in my 2014 BRZ, went through the menus, pressed read and once it was done, I got the "Mod file not found" error. Read/Write buttons are now greyed out.
My stock rom is the B00C.
Could there have been a tune in there already? Or since I had done an update on the OFT it erased all the preloaded maps that would have been on there? If that's the case, i'll just load up the B00C stage 1 91 map, OTS Stage 2 UEL 91 map and the Stage 2OFH 91 map. I'll be installing my OFH3 later this week.
I also sent an email to OFT with the .ori file it spat out also.
Skyllz is offline   Reply With Quote
Old 08-20-2016, 11:32 AM   #658
mulekr1
mulekr1's Avatar
So to pass inspection i'll have to put back on my OEM header?
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
