Old 12-18-2015, 12:19 PM   #57
SlammedSilly
Drives: 2015 Ultramarine FR-S
anyone else feel as if their interior gets dirty stupid quickly with have the sound generator coming into the cabin? my back window gets dirty on the inside so quickly... ill fully detail the car and with a day or two the back window is dirty again...
or is it just me?!?!
SlammedSilly is offline   Reply With Quote
Old 12-18-2015, 02:40 PM   #58
MrDinkleman
Drives: 2016 Oceanic, "base" model
It's just you.
The sound generator is a sealed diaphragm inside the "can". There is no air passing through the tube from the intake to the cabin so there is nothing being injected into your passenger cabin. The reason I know this is because I was examining the can after I removed the sound generator. While examining the parts, I noticed that Subaru labeled the can part of it "DAMPER". Looking inside as best as I could, I could see that the interior wall is like a rubber accordion material. Then I also noticed that the intake side of the DAMPER is the exact size of the other end of the hose and it would fit directly into the intake tube.
Soooooo...
It got me wondering, would mounting the can directly to the intake tube quiet the intake even more/better than just having the resonator chamber at the bottom of the intake tube? Or better yet, will it tune the intake for better response/power? Or is it just a coincidence? Or did Subaru intentionally do it to waste my time?
Has anyone tried it? If so, did it change anything?
I plan to mount it up there just for the heck of it. Unfortunately, I don't have access to a dyno to see if it makes any measurable difference...
MrDinkleman is offline   Reply With Quote
Old 12-25-2015, 11:29 PM   #59
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
I tossed the sound generator last weekend and was very happy with the results. It eliminates the buzz and instead you get to hear a much lower tone from the engine.
10/10, would rip out again.
Also, there was some sort of error with Home Depot's system when I went and the 3/4" plug rang up for 1 cent. Yes please!
Kestrel is offline   Reply With Quote
The Following User Says Thank You to Kestrel For This Useful Post:
theneptune86 (08-19-2020)
Old 05-09-2016, 02:11 PM   #60
jarviz
jarviz's Avatar
Drives: Raven FRS MT
Does anybody know the weight of the soundtube? I'm trying to decide if the work is worth the weight savings, vs just plugging up the cabin firewall hole.
jarviz is offline   Reply With Quote
Old 05-09-2016, 02:56 PM   #61
Under a pound. It is just a piece of plastic tubing.
Old 05-09-2016, 03:26 PM   #62
jarviz
jarviz's Avatar
Ah. Thanks. Then I guess there's no real benefit to removing the whole tubing vs just pluggin up the port.
Old 05-09-2016, 03:27 PM   #63
The one big benefit to removing it all is appearance. It makes a bigger difference than you would think to remove that clutter.
B-R-Z (05-09-2016)
Old 08-11-2016, 07:32 PM   #64
jamesw1301
Drives: 2013 Subaru BRZ
Has anyone who's removed their sound generator and kept it off for long periods of time experienced any issues?
jamesw1301 is offline   Reply With Quote
Old 08-12-2016, 01:19 AM   #65
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
I've had mine off since posting this diy and have no issues. Running strong at 83k
B-R-Z is offline   Reply With Quote
Old 08-18-2016, 11:25 AM   #66
jamesw1301
Good to hear! what did you use to plug your intake?
Old 08-18-2016, 02:14 PM   #67
MrDinkleman
I used a PVC 1" pipe cap. I put it in with the open end out to get as smooth of a flow as possible, just in case it mattered.
I haven't had any problems that I am aware of since removing my sound tube as well.
Old 08-18-2016, 04:16 PM   #68
jamesw1301
Have you noticed the decel rattle has gone away since you've removed your sound generator?
Old 08-18-2016, 05:42 PM   #69
MrDinkleman
Sorry, but I can't say if it reduced/eliminated/prevented anything besides the superfluous sound in the cabin. I knew about the sound generator from even before I bought the car so I took it out almost immediately after buying the car so I don't know if doing so had any effect on anything.
Old 08-20-2016, 12:13 AM   #70
B-R-Z
B-R-Z's Avatar
What do you mean? Everything I used is in this diy.
Sound Generator to keep or not to keep? FRS86edition#3 Scion FR-S / Toyota 86 GT86 General Forum 73 11-24-2013 02:26 AM
Sound generator delete for $1.06 PineappleFriedRice Engine, Exhaust, Transmission 13 11-10-2013 01:28 PM
Sound Generator Tube Delete Anthony Engine, Exhaust, Transmission 8 09-01-2013 05:25 AM
WTB: OEM snorkle (not sound generator) Laika Engine, Exhaust, Bolt-Ons 2 11-08-2012 12:31 PM
