Old 08-18-2016, 03:59 PM   #659
nisti
nisti's Avatar
Drives: BRZ & XV
Originally Posted by Psilox View Post
Hey all, I'm in love with the RPF1 17x9 +35s, and I think that they're by far the best looking lightweight wheel available for a decent price. My only concern is the 13mm difference in offset between these and the stock wheels. Have y'all noticed any handling differences/degredation between these and the stock wheels? I know tires play a big factor, but I really want to make sure I don't accidentally introduce a lot of oversteer or wheel kick that could compromise the awesome handling of the car.
Bonus question, how is MPG on these? (Assuming, let's say 245s?)
Would I be better off going with the 17x8s at +45?
Thanks in advance!
Wider tires/wheels in the rear will NOT induce more oversteer.
Quality of handling has increased for me.
Steering will obviously feel slightly heavier with the larger contact patch up front.
But overall the car is way more planted and ready to take turns hard.
I'm lowered only a small amount with RCE yellow springs.
My review of the setup is nothing but positives.
You will need camber adjustment both front and rear to get the "look" right, otherwise your tires will stick out quite a bit, and handle poorly.
I can't comment on mpg, I have never reset a trip, and only have driven 1,700 miles with this setup.
nisti is offline   Reply With Quote
The Following User Says Thank You to nisti For This Useful Post:
Psilox (01-03-2017)
Old 08-18-2016, 11:23 PM   #660
trigger happy
Bang Bang
trigger happy's Avatar
Drives: 2013 Raven FR-S
Originally Posted by GodDamnLiteracola View Post
which tires did you go with? love that meaty stance 👍
Raven 6MT//Injen CAI//VDS UEL//Invidia N1//OFT//ST Coilovers
trigger happy is offline   Reply With Quote
Old 08-19-2016, 02:38 AM   #661
GodDamnLiteracola
Drives: 2015 BRZ
Thanks! I'm running Bridgestone Potenza RE-11 255/40r17.
GodDamnLiteracola is offline   Reply With Quote
The Following User Says Thank You to GodDamnLiteracola For This Useful Post:
trigger happy (08-19-2016)
Old 10-19-2016, 02:57 AM   #662
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Is anyone running a larger brake setup like Wilwood, AP or OEM WRX 08?
What fits best and are there any clearance issues?
Wise is offline   Reply With Quote
Old 10-19-2016, 10:02 AM   #663
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I've got the AP Sprint kit. No fitment issues and they work well. The clearances are fairly tight, but not close enough to be a concern, IMO.
The Following User Says Thank You to DocWalt For This Useful Post:
Wise (10-19-2016)
Old 10-19-2016, 01:02 PM   #664
kch
Senior Misanthrope
kch's Avatar
With the AP Sprint Kit:
The Following User Says Thank You to kch For This Useful Post:
Wise (10-19-2016)
Old 10-19-2016, 07:17 PM   #665
Wise
Circle Work Clerk
Thanks for the pics. I wonder if AP are able to do special order Red/white calipers like they do for the Road/Track calipers.
Old 10-28-2016, 12:24 PM   #666
Scion
Drives: Scion tc
Scion is offline   Reply With Quote
The Following User Says Thank You to Scion For This Useful Post:
swarb (02-22-2017)
Old 10-30-2016, 06:14 PM   #667
novice
novice's Avatar
Drives: Fr-S 2.0 Release
will I be fine with these wheels on TRD spirings? what size tire?
novice is offline   Reply With Quote
Old 10-31-2016, 01:05 PM   #668
kch
Senior Misanthrope
kch's Avatar
Yes. Sweet spot is 245/40/17.
novice (11-01-2016)
Old 11-01-2016, 05:43 AM   #669
novice
novice's Avatar
OK so I'm looking through this thread and It seems anyone running +35 squared on stock or springs has a lot of poke. unless i'm not seeing good angles, doesn't seem flush?
Old 11-01-2016, 07:00 AM   #670
novice
novice's Avatar
Originally Posted by Toyarzee View Post
Just threw in some spc camber bolts, TRD springs, 17x9 et35 rpf1's in gunmetal/dark silver with 235/40 NT01's. The bead came out right at 9" and the sidewall is not stretched at all. Pretty damn happy with the outcome. I also support the million and one +1s on this setup, it really is a good fit for the car.
And yes, I'm daily'ing this
OH here we go... I am having TRD springs installed and I want these wheels. This seems like the best look I've seen as far as it being flush with this set up goes, exactly what I want. I'm a total noob so i have some questions about the camber bolts: Do they come in a certain type like + or - or do they allow you to dial in the camber? What number did you set it at?
Old 11-01-2016, 11:52 AM   #671
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
It'll seem more simple when you see them. Just a bolt with a lobe in the middle of it. No real accurate metric, just rotate in its seat until reaching the desired setting and tighten bolt. With TRD springs and switching the 14 mm strut bolt and replacing 16 mm with the camber bolts, I got almost exactly -2.0 camber all 4 corners.
Toyarzee is offline   Reply With Quote
The Following 2 Users Say Thank You to Toyarzee For This Useful Post:
novice (11-01-2016), pooch (11-01-2016)
Old 11-01-2016, 04:17 PM   #672
novice
novice's Avatar
will I need these to have no poke? or can i slap the wheels right on there?
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
