Old 07-05-2016, 04:49 PM   #15
j_motion
Drives: 14 BRZ Red premium
Originally Posted by continuecrushing View Post
This is for Valenti lights...so it shouldn't matter as long as its a "valenti" light.
Open it up and see
This is the newer board.
If the board look the same follow the instruction.
If the board look different, you might have to dig through the original
Valenti alternate wiring post
I dont think there are any of the old version on sale right now anymore.
j_motion is offline   Reply With Quote
Old 07-07-2016, 12:38 PM   #16
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
just did this mod again today!
Old 07-19-2016, 02:57 PM   #17
continuecrushing
bump-Need your help!
So, it seems that if you have switchback turn signals up front and the flasher relay, it MIGHT cause an issue with the 4th brake light/blinking.
This is a current/load issue-I'm sending pm's to people who might have done this mod according to my video to confirm!
Old 08-17-2016, 03:58 PM   #18
continuecrushing
good news! I found an "older" valenti rear light, with slightly different wiring when you open it up. Its the same as some of the other ones I've seen floating around.
Got the wiring figured out, will have photos and video shortly!
Old 09-03-2016, 08:32 PM   #19
djwishbone
Last Starfighter
Drives: 2016 FR-S Series 2.0
I'm plan on doing the blinking version and have switchback blinkers up front. Anyone validate this?
djwishbone is offline   Reply With Quote
Old 09-05-2016, 11:52 PM   #20
qitorr
Drives: 2015 Series.Blue
I have one of the older lights with a different wiring from the videos. It sounds like the wiring described in the original thread but those pictures have gone dead and I wanted to be sure. @continuecrushing, were you able to get a video or pictures with the old light you found?
qitorr is offline   Reply With Quote
Old 09-06-2016, 12:19 AM   #21
djwishbone
Last Starfighter
I'll let @continuecrushing confirm but I'd say you just do the same thing with the blue and red wires. Disconnect them and wire them directly to each other to isolate the V. Then move orange wire over for blink and solid red assuming it works the same as the new version. Just some guesswork though.
Sent from my SM-G930T using Tapatalk
Old 09-06-2016, 11:43 AM   #22
continuecrushing
I do have photos/video...I'll get that up in a few days! Thanks for the reminder lol, I forgot I had that.
Old 09-06-2016, 11:52 AM   #23
djwishbone
Last Starfighter
Thanks again for the video. I wired up mine this weekend and this post let me do exactly what I wanted. I have switchbacks inbound so I can test that out. Not sure why that would have anything to do with this circuit. I know some people were having some odd unrelated issues with cheaper led switchbacks.
Old 09-23-2016, 11:17 PM   #24
qitorr
@continuecrushing any updates on this?
Old 01-23-2017, 01:28 PM   #25
qitorr
@continuecrushing you had mentioned possibly getting to this over the holidays. Any luck?
Old 05-06-2017, 08:13 PM   #26
WolF_RS
WolF_RS's Avatar
Drives: 2015 Ultramarine Scion FR-S (MT)
Mine works how it should once re-wired when off, v turns on with lights, triangle flashes. But once the car is on, everything still works, except the triangle. The triangle turns on dimly and doesn't flash. What exactly am I looking at here as the issue? Would it be the ground?
WolF_RS is offline   Reply With Quote
Old 06-14-2017, 12:16 PM   #27
Raekna
Drives: Hot Lava GT86
Hi,
Is there a way to wire it so the middle triangle doesn't blink but still lights up when I turn on the rear fog light ?
Thanks
Raekna is offline   Reply With Quote
Old 06-14-2017, 08:15 PM   #28
continuecrushing
Yeah, switch to version 3 and it'll work. I have no idea why it does that. It bugs me that I haven't found out why yet. E
Originally Posted by Raekna View Post
Hi,
Thanks
Sure, set it up like wiring 3. BUT, the red wire that comes from the 4th brake light needs to go to the (+) of your rear fog lights. I don't have a rear fog, so I don't know where that wiring is/which wire it is.
valenti, valenti mods, valenti wiring
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 08:42 PM
WTB: Valenti 4th Brake Light thecarfilmer Want-To-Buy Requests 1 05-22-2016 07:50 PM
Valenti 4th brake light vs Valenti Style brake light? JGalp Electronics | Audio | NAV | Infotainment 9 03-24-2016 05:48 PM
SOLD -Valenti Tails and Valenti 3rd light (Smoked) / Wheelhaus' headliner brake light AtlasMick Exterior Parts (Aero, Lighting, Etc.) 8 03-07-2015 06:51 PM
how to turn that rear triangle reflector into working brake light chris's fr-s DIY (Do-It-Yourself) Guides 29 06-10-2013 07:25 AM
