Old 08-08-2016, 09:56 PM   #1415
Tor
Tor's Avatar
Drives: Toyota GT86
yep you could run it through the maf scaling utility again.
of if its just in that one particular area just reduce the maf flow numbers 5% in that area trying to keep the curve smooth
Thanks again. I'll give it a few more km to see if it changes anything, then I will start to dig into MAF scaling... it seems like there is no way around learning how that works.
Tor is offline   Reply With Quote
Old 08-10-2016, 01:55 PM   #1416
refriedspinach
refriedspinach's Avatar
Drives: 2016 Raven FRS
I recently tuned my car with the OFT to get most benfits from my UEL tomei headers.
I've been doing datalogging as im using Canadian fuel. I'm using chevron 94 for the stg 2 UEL 91 ROM.
http://datazap.me/u/refriedspinach/l...data=1-5-12-14
Here's the first run, which includes the ECU learning.
http://datazap.me/u/refriedspinach/log-1470805319?log=0&data=5-10-11-12-14
Here's my run form the end of day yesterday, about 20 mins after tuning to stage 2 and steadily cruising around.
-Is the FLKC supposed to be going crazy into +/- 100 like that?
-The Advance Multiplier(Is this IAM?) is staying at 0, and didn't move the full trip.
-knock correction didn't move the full trip either
@Boomerang Mentioned that with a ZA1JF40C CAL ID (I'm driving a 2016 MT) the OFT cant log some parameters properly. Is this the case?
I've tried searching everywhere but couldnt really find an answer to questions I have.
refriedspinach is offline   Reply With Quote
Old 08-11-2016, 01:24 PM   #1417
tinma
Drives: '13 BRZ
To start this off, I am very new to the tuning world so please go easy on me. I'm learning as I go on.
So I did a data log with my OFT of a 3rd gear pull yesterday from 2000rpm to redline.
http://datazap.me/u/tinma/log-147093...-9-10-11-12-13
I added the alarms that are on the OFT Tips & Tricks page and every so often these following alarms go off. I would also like to add that I seem to have backfire every so often coming out of 1st gear.
Alert B ( knock alert & Fuel Trim alert)
For E85 suggest -1 for Petrol may -2
FLKC < -1
Knock Correction < -1
IAM < 0.9
LTFT > +10
LTFT < -10
Alert C running lean alert
you might have to tweak AFR for petrol/E85 try 13 for E85 12.5 Petrol
RPM > 5000
Engine Load > 1
AFR > 13
Select AND at bottom of screen
I dont think the 3rd gear pull log will give me much info on this issue, but I feel like its a step in the right direction. If someone could give me a hand with this, I would greatly appreciate it! @steve99 or @Wayno if you have any input on this?
Running on 91oct stage 2 OFT tune with UEL header and drop-in filter
tinma is offline   Reply With Quote
Old 08-11-2016, 03:54 PM   #1418
denso
Drives: 86
I want to share my logs via datazap but the only thing i can see is "#encoding: utf8". I logged with ecutek and saved the .csv file to datazap.... can anybody help?
edit: http://datazap.me/u/denso/1?log=0&data=0&solo=0
denso is offline   Reply With Quote
Old 08-11-2016, 04:21 PM   #1419
phrosty
Does the first line of your file have #encoding, and then the rest have all the parameters? If so, delete that line.
phrosty is offline   Reply With Quote
Old 08-11-2016, 04:31 PM   #1420
denso
Drives: 86
First and only line is encoding... I can only see the seconds. No parameters
Old 08-11-2016, 05:21 PM   #1421
Kodename47
Kodename47's Avatar
Drives: UK GT86
Open it in Excel You want the top row to be the column headers. Recently ECUtek have added info into the top like OFT does.
.: Stealth 86 :.
Kodename 47 DJ:
denso (08-11-2016)
Old 08-11-2016, 07:13 PM   #1422
denso
Drives: 86
it worked with wordpad, too
Old 08-13-2016, 01:56 AM   #1423
steve99
Drives: FT86
FLKC < -1
IAM < 0.9
LTFT > +10
LTFT < -10
RPM > 5000
Engine Load > 1
AFR > 13
When the alarm goes off the offending parameter on the log screen will flash, its like
y flkc knock you have a bit round 4000-5000 in that log.
the load limits not being set looks like your running pretty rich when you get on throttle at lower rpm this may cause the miss fire , it also running on the rich side wot at most rpm, wont hurst just costs you power.
knock is not bad iam is still 1.
tinma (08-15-2016)
Old 08-14-2016, 08:03 PM   #1424
fibble
Drives: 2015 86 GTS
Unfortunately, OFT logging does not work correctly for later model ROMs. Knock Correction, MAF, Advance Multiplier (yes IAM) have never worked. FLKC originally worked, but was broken when an update to OFT was made via OFM. The reason FLKC looks crazy is that it is most likely logging another unrelated ECU address......maybe total timing.......
I strongly feel that Openflash should make this clear in the sales burb on their website so that you know what you are getting 😑. Feel free to send an e-mail to sales@openflash.com and raise the issue. More customers doing this will give them a sense of how many of us are affected. At some stage they might fix it 🤔.
fibble is offline   Reply With Quote
Old 08-15-2016, 01:55 PM   #1425
tinma
Drives: '13 BRZ
Awesome thank you!
I noticed you mention the Front Oxygen Sensor scaling in one post.
http://www.ft86club.com/forums/showp...&postcount=371
Would changing my tables to the ones you posted help fix this issue?
Thanks!
Old 08-16-2016, 10:07 AM   #1426
steve99
Drives: FT86
Awesome thank you!
Thanks!
no rescaling front 02 sensor wont help you, it just allows the sensor to read richer values.
you need some maf scaling correct load limits as in wayno's posts. and maybe a bit of smoothing of ignition timing, but best to get the fueling corrected first.
its not real bad though so don't sweat on it, , a different brand of fuel may fix the minor knock issue.
tinma (08-16-2016)
Old 08-17-2016, 10:49 PM   #1427
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by fibble View Post
Thx Steve - I suspected a MAF re-scale was in order, I was just not sure how much is enough for a Stg 1 tune.
Next will be a Stg2 UEL on 98.
Optimising Wayno's Stg 1 tune is my "development environment" and I am having a bit of trouble without OFT working properly
Looks completely fine.
The Following User Says Thank You to Wayno For This Useful Post:
fibble (08-18-2016)
Old 08-17-2016, 11:02 PM   #1428
Wayno
Wayno's Avatar
Originally Posted by Boomerang View Post
Hi, running an E85 EL @Wayno tune, looks OK but high LTFT?
Any issues I can fix?
BTW, D00G rom so IAM etc don't work
http://datazap.me/u/boomerang/log-14...&data=1-2-9-11
Looks fine.
IN latest version I've adjusted < 2.4 MAFV +5% (over stock) to better match AU E85. Should have zero affect on LTFT at WOT.
Boomerang (08-18-2016)
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
