Old 08-15-2016, 08:13 PM   #1
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
Changing oil without new plug crush washer.
I'm changing my own oil for the first time tomorrow, got all the supplies I needed tonite but no autopart stores had the drain plug crush washers in stock.
Would I be okay until the next oil change with the current washer, or should I wait and order one from the toyota dealer? How imperative is it?
Thanks.
Spacemane969 is offline   Reply With Quote
Old 08-15-2016, 08:23 PM   #2
frslee
Just drive it
Drives: 13' FR-S
Have you tried checking local dealers? If not...
I don't see a problem with re-using it. If you have a torque wrench, tighten it little bit more than factory torque spec. If it's 30 ft/lb, try 33ft/lb. Then pour a quart of oil and see if it leaks or not.
frslee is offline   Reply With Quote
Old 08-15-2016, 08:30 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
You can reuse it once (or a few times like some people haha)
Just buy a dozen next you pass by the parts store. They are cheap enough
Old 08-15-2016, 08:40 PM   #4
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
A washer came with my oil filter when i bought it:
http://subaruonlineparts.com/subaru-...nt-p-1417.html
Personally, I wouldn't reuse the crush washer if it's deformed as mine was when I removed the drain plug:
shiumai is offline   Reply With Quote
Old 08-15-2016, 08:42 PM   #5
Spacemane969
Thanks guys, closest dealer is about 35 minutes away so I think I'll just wing it this time. Granted I don't lose it in the oil bucket lol.
Old 08-15-2016, 08:44 PM   #6
Spacemane969
Good look. I was wondering if the design of the washer allowed it to be a one-time seal sorta thing. Haven't got to looking up if the crush term means anything.
Old 08-15-2016, 08:49 PM   #7
frslee
Just drive it
Drives: 13' FR-S
wow, that's really bad. Mine was flat and pretty.
The Following User Says Thank You to frslee For This Useful Post:
shiumai (08-16-2016)
Old 08-15-2016, 08:50 PM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
It does mean it "crushes". Most (all?) cars use it. You will feel it crush when you tighten it. Maybe some crush more than others. The one in the pic is pretty extreme, of the dozens and dozens of oil changes I've done I not seen one like that. Even after reusing some of mine a couple times.
Old 08-15-2016, 09:03 PM   #9
wbradley
Sarcastic SOB
wbradley's Avatar
Just get a short Fumoto, install it with a new crush washer. Cant you just wait to
to do the oil change when you have the peace of mind of a fresh washer? It‘s not like you can just remove the nut and put in the washer without collecting the oil and refilling afterward.
Old 08-15-2016, 10:25 PM   #10
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
I would wait till you get a crush washer. If you absolutely insist on re using it flip the washer over. Still I wouldn't do it.
tofurun is offline   Reply With Quote
Old 08-16-2016, 01:07 AM   #11
Do it right
Do it once.
DarkSunrise (08-16-2016), Silky (03-17-2018), trd87t (08-16-2016), Tristor (09-16-2018)
Old 08-16-2016, 10:13 AM   #12
Spacemane969
Thanks guys. I'll stop being lazy and track down some washers because I'm reaching 1k miles overdue on the change. :O
Old 08-16-2016, 10:29 AM   #13
Peaty
Scooby***s Guy
Peaty's Avatar
Drives: 2019 Impreza Sport - MT
Keep in mind that the first time the oil is changed it's not easy to find the crush washer. I've owned a lot of Subaru's and it's always the case. Because they paint the oil pan after they put the plug is installed, the crush washer is stuck to the plug and camouflaged. Sometimes it takes a knife blade to separate it from the plug. I've known a number of cases where people didn't think one was there and installed one so they had two. That will cause leaks.
I always install the Fumoto Oil Drain Valve, it makes things a lot easier. I have this one ready to install next oil change.
https://www.fumotooildrainvalve.com/...rain-plug.html
Peaty is offline   Reply With Quote
The Following User Says Thank You to Peaty For This Useful Post:
Hostile_Kittens (08-17-2016)
Old 08-16-2016, 10:31 AM   #14
ZionsWrath
Thanks
ZionsWrath's Avatar
I like first oil changes at the dealer. Particularly because the factory oil filter is almost welded to the engine from the factory. This car its easy to get leverage on it but I was in for the spoiler install anyway so I let them do it.
Beware || oil drain plug washer (when changing your oil) mav1178 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 11-14-2021 06:07 PM
Crush Washer Sizes Eric1855 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 55 08-30-2021 02:21 AM
GONE. yamsta Mid-Atlantic 9 05-25-2017 03:21 PM
OEM Oil Drain Crush Washer Buying Tip radroach Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-20-2016 09:42 PM
Crush Washer for AT BRZ888 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 07-27-2014 10:06 PM
