Old 08-15-2016, 03:31 PM   #15
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Originally Posted by Yanbags View Post
I'm surprised nobody else mentioned this - why not use sealant instead of wax?
I did, a few posts up.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
Yanbags (08-15-2016)
Old 08-15-2016, 03:35 PM   #16
Yanbags
Yanbags's Avatar
Drives: '17 Camaro SS 1LE
Apologies, didn't notice. Corrected my post.
Yanbags is offline   Reply With Quote
The Following User Says Thank You to Yanbags For This Useful Post:
shiumai (08-15-2016)
Old 08-15-2016, 04:53 PM   #17
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Originally Posted by MrDinkleman View Post
Power rinse with a 2,000psi power washer? Aren't you afraid of blasting the paint off? I use a garden hose (60psi?) with the "fan" style lawn watering nozzle to knock off loose dirt/dust and I still cringe at "blasting" it with that.
I've never had a problem and research suggests that high pressure rinsing is just fine for paint. I've got the power-washer at my disposal, so seems to make sense to use it.
I do a lot of highway driving and its amazing the junk that I pick up on the front of the car. Additionally I tend to pick up dirt around the fenders as I have quite wide wheels/tires.
At any rate, i'm used to washing once every 2-3 weeks or less. So I may find that I don't need the power washer if I can wash more frequently. Thanks for your input!
ajcarson11 is offline   Reply With Quote
Old 08-15-2016, 05:08 PM   #18
AdrianSaldana
That Guy
AdrianSaldana's Avatar
Drives: Fast and Hard
Originally Posted by ryoma View Post
I don't really see a need to wash your car every week. wash it once it gets dirty; I haven't washed my car for about a month and half and it still looks pretty clean.
however, when I do wash my car, I do the wheels first with Sonax cleaner. then I use a foam cannon and let the soap sit on the car for a bit before rinsing. if my car is relatively clean, I only use 1 bucket but if it's really dirty I use 2 buckets with a microfiber mitt and I just dump my left over soap from the foam cannon into the bucket and fill it up before going down the car. rinse it off again and dry. then, depending on how long ago it was, I apply Carnuba wax by hand (usually once every 3 months). if I don't use the Carnuba, I use a spray-on sealant after washing my car. then I use a window detailer afterwards on both inside and outside windows (and anything else). tire dresser comes in at the very end. don't apply too much dressing though since it might fling off when you drive it
this is the soap I use: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
this is the sealant I use (plus it smells great): https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
window cleaner: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
wheel cleaner: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
foam cannon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I buy all my car towels from theragcompany.com. they're cheap and good quality
does that spray sealant/retailer attract dirt?
"Knowledge will give you power, but character respect.."
DD: 2007 Suzuki Sv650
Weekend Car: 1969 Chevelle
Summer/Weekend Car: 2014 BRZ
AdrianSaldana is offline   Reply With Quote
Old 08-15-2016, 05:34 PM   #19
ajcarson11
Originally Posted by ajcarson11 View Post
Thanks for the tips! I may not wash every 7 days, but here in Indiana we get so much pollen and rain that the car gets dirty every 3 or 4 days easily.
I'm surprised there aren't more advocates for using a sealant. Protection from a wax really doesn't last longer than a month or two. A good sealant will last you for a good 4-6 months, so you can basically refresh it before winter & before summer; I personally use Menzerna PowerLock - really great stuff. You can top it with a wax for more shine but I just stick with the sealant. This should avoid the need to spend money on quick-waxes all the time.
RE: your question about having dirt left over after a 2-bucket wash, have you ever clayed the car? It sounds like you possibly haven't, so before doing a full seal/wax initially you should clay-bar the paint to get all of the difficult-to-remove contamination and smooth out the clear coat. That would prep the paint properly for any correction or wax/sealant.
Thanks for your input -- I'm currently using Ultimate Liquid Wax, which I believe to be a sealant. I'll definitely give the clay bar a try. I haven't clayed yet!
The Following User Says Thank You to ajcarson11 For This Useful Post:
Yanbags (08-16-2016)
Old 08-15-2016, 06:29 PM   #20
ryoma
ryoma's Avatar
nope.
Old 08-15-2016, 10:28 PM   #21
NLS8520
Drives: N/A
Always cool to hear about people stepping up their wash game. A few thoughts and recommendations:
In regards to the pressure washer, 2000psi is sort of on the high side for a vehicle, I would prefer something in the 1600-1700 psi range if possible. A foam gun looks cool, it may or may not actually show any improvements in grit removal and to be honest just a pressure washer rinse should be enough but it can never hurt. I am surprised your having grit still on the surface after washing. I think there is a possible kink in your technique or materials. What type of wash mitt are you using and what type of soap? Are your jambs completely clean? sometimes the hood or trunk jambs can leak dirty water on a clean car when you rinse.
I would also recommend to you to get a mild clay bar and clay the car at least 1X per year maybe more depending as needed.
In regards to protection. I would certainly recommend a paint sealant and possibly a wax topper. Two combos I have used in the past before moving on to coatings. Probably one of the easiest to apply is Optimum Opti-Seal and topped with Opti-Wax. Both preserve the clear coat with UV protection which is very important, will keep the paint clean and both are extremely easy to apply and maintain.
Second combo I would recommend Sonax Polymer Net Shield as the sealant and Sonax Brilliant Shine Detailer as the topper. Brilliant Shine is actually a spray sealant so don't let the name fool you. Now they are grabby to apply and require more technique but they bead water like a coating.
One of the big reason I recommend both the Optimum products and Sonax products is that they can be applied to ALL areas of the car, paint, trim etc. I personally like that I can protect everything with one product. Feel free to ask any questions and good luck.
NLS8520 is offline   Reply With Quote
The Following User Says Thank You to NLS8520 For This Useful Post:
AdrianSaldana (08-16-2016)
Old 08-16-2016, 03:26 AM   #22
It is a car with car paint the sun causes more damage than a pressure washer ever will. Pressure washer pressures are measured directly at the nozzle exit. If used on a fan setting you are nowhere near the rated pressure if even a few inches away. If you are washing your car any closer than about a foot you are going to take forever anyway. You do want to be careful around chips on the plastic parts though since they do not hold the paint as well as the metal and you can peal it off in a hurry if the water can get under it.
Old 08-16-2016, 08:33 AM   #23
ajcarson11
I figure that the pressure washer i've got doesn't put out the rated power of 2200 -- It's probably closer to 1500, especially when I throw on the angled nozzle. There has been a time or two when i've had sap or something still stuck to the car after the wash was complete. Mainly on the front bumper or right above (I drive a lot of highway miles). I'm working with Mcguairs Gold Class for soap and just a traditional wash mitt. I probably just need to pay a bit more attention as I'm going through the routine.
I'll definitely give the clay bar a shot -- as well as the sealants/wax boosters you suggest. Thanks!
Old 08-16-2016, 01:16 PM   #24
...............I'm working with Mcguairs Gold Class for soap and just a traditional wash mitt. .................Thanks!
I've found (learned back on the farm, watching my mother "soaking" baking dishes ......) that if you start by lathering up the buggy front clip, and let it "soak" while you wash the rest of the car ...... by the time you get around to the last part (the front clip) the bugs will just about fall off.
Old 08-16-2016, 01:21 PM   #25
gramicci101
Off Topic
Do you have grit guards for your wash buckets? If not, you really really need them.
The Following User Says Thank You to gramicci101 For This Useful Post:
ajcarson11 (08-17-2016)
Old 08-16-2016, 02:29 PM   #26
AdrianSaldana
That Guy
nope.
i'll try it out
Old 08-16-2016, 11:36 PM   #27
radroach
Drives: car
Everybody's needs are different depending on where you are in the states. The Socal folks are always going on about your waterless washes and detail sprays, but in the Southeast that doesn't work because we have way more pollen and bugs.
So I say use a detail regimen that works for you in your environment. For me, my car sits outside 100% of the time and needs a weekly wash for all the dirt, pollen, brake dust, bird poop, grass clippings, mold growth (yeah ew), and bug guts etc. My car has a few marks and scratches so I always keep a fresh coat of wax to keep them from showing up too much.
And I just got on the grit guard bandwagon. Man what have I been doing without these! So much dirt!
The Following User Says Thank You to radroach For This Useful Post:
Old 08-20-2016, 02:22 AM   #28
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
You can always try a Ceramic coat. it's expensive from the getgo but eliminates the need to ever wax your car again and all you need is a power washer to get off any dirst or pollen.
Xxyion is offline   Reply With Quote
Modding, moving, under warranty, maintenance? Tofu-86 BRZ First-Gen (2012+) — General Topics 27 12-29-2015 01:33 PM
Best place for 30k maintenance near San Francisco? kgc Northern California 13 12-09-2015 08:47 PM
New mini-review at The Weekly Driver Sport-Tech BRZ First-Gen (2012+) — General Topics 5 04-15-2012 08:24 PM
Finally a chance to check the BRZ; my review and some pic ironsurfer129 BRZ First-Gen (2012+) — General Topics 31 03-29-2012 10:38 PM
