Old 08-02-2016, 07:28 PM   #71
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
Originally Posted by justinco View Post
Myself, I need to learn how to close out my days with good 3rd runs...sitting on 1st run and 2nd run times is no bueno I did the same thing at Lincoln Spring Tour (and lost 3rd place) and the ProSolo (losing the last trophy spot), argh.
Pro Tip: Don't bump the key off with your knee on your third and likely fastest run of the weekend like I did.
Briankbot is offline   Reply With Quote
The Following User Says Thank You to Briankbot For This Useful Post:
Silverspeed (08-02-2016)
Old 08-02-2016, 09:22 PM   #72
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Hah, I was working the corner where you did that. Was wondering what the heck was going on lol
justinco is offline   Reply With Quote
Old 08-02-2016, 10:23 PM   #73
Silverspeed
Drives: 2014 FR-S
Hopefully the car is back up and running strong soon.
I found someone to do the seals - More or less $1000 to have them done. There goes the racing budget for the year. I've called several dealers who won't touch the car with any performance parts on it. I thought about taking the car back to stock but Dave indicated that most dealers would check to see if the car had been tuned which I guess they can tell even if you remove the tune. There is a Toyota TSB out on this issue - in which the solution was to reflash the car to reduce timing in certain areas of the revband to reduce heat and make the seals last longer.
My other option was to do it myself which I probably could, but since the parts were $500 + $100 for the tool to install the seals, $400 for the install with a 2 year 24k warranty seems reasonable. That's getting it done at a Toyota specialist in Denver. Hopefully the car will be done sometime next week if the parts aren't on backorder. I also ordered a set of plugs to be sure they weren't damaged by the broken seals.
Will you be posting video from Sunday? I'd be interested to watch our runs. Thanks again.
Silverspeed is offline   Reply With Quote
Old 08-02-2016, 10:48 PM   #74
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
For $1000 I would pay someone to do it too, not sure it would be worth the time spent especially when parts are that much.
Yep, working on getting videos up now. I will throw yours up on my personal youtube, sadly the damn thing didn't start recording for your best 3rd run Auto triggers have been flaky lately with the GoPro, might have to do manual start/stop from now on.
Old 08-03-2016, 12:11 AM   #75
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Here you go:
Greg Run 1 Day 2
[ame]http://www.youtube.com/watch?v=AJY242ryIVU[/ame]
Greg Run 2 Day 2
[ame]http://www.youtube.com/watch?v=zagnMbnZFeI[/ame]
My raw runs from same day, of course my fast run did not get recorded either, stupid thing...
Justin Run 1 Day 2
[ame]http://www.youtube.com/watch?v=hghDhdERqhE[/ame]
Justin Run 3 Day 2
[ame]http://www.youtube.com/watch?v=23LLKPn_4UE[/ame]
The Following User Says Thank You to justinco For This Useful Post:
Silverspeed (08-03-2016)
Old 08-03-2016, 01:00 AM   #76
Silverspeed
Drives: 2014 FR-S
My quickest day 1 run.
Old 08-14-2016, 12:34 AM   #77
Silverspeed
Drives: 2014 FR-S
The car is back in action... In the end, due to the shop not being able to get the direct injection seals on the old injectors, I opted to just replace all of the injectors. One of the seals was completely missing. I also replaced the spark plugs just to be sure there was no sign of the motor running lean - there was not.
I typically use Torco's Accelerator octane booster which I have heard turns the plugs orange - I can confirm it does.
As I noted earlier, the car is for sale. I will get a post up on this forum tomorrow now that I have the car back - $25,500.
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
[B is for Build] BRZ resurrection build im_topher Member's Car Journals 49 03-05-2018 09:41 AM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 04:00 PM
No build date on passenger side sticker, how to determine build date? BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 5 01-20-2015 10:14 PM
another STX build miwialex Tracking / Autocross / HPDE / Drifting 21 05-14-2013 01:07 AM
