Northern California NorCal
Old 08-11-2016, 11:02 PM   #29
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Originally Posted by Bach415 View Post
I wonder what it would have made/the difference on CARB tune vs custom tune.
With all the pipes, injectors,etc I bet the carb tune would be awful.
Anyway, where are the rest of the results? Come on guys!
Old 08-12-2016, 01:13 AM   #30
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Probably. But it would be nice to know if it still ran with the CARB tune after all the mods so smog wouldn't be a bitch after the 6 years no smog limit.
Bach415 is offline   Reply With Quote
Old 08-12-2016, 02:52 PM   #31
PMok
Codename: Stitch
PMok's Avatar
I think that would be irrelevant... a smog tech wouldn't be able to tell the difference between a CARB tune and a custom tune on the car. That's not the stumbling block to failing smog. The car as equipped would almost immediately fail visual inspection for all the non-emissions compliant parts on the car.
Old 08-12-2016, 09:26 PM   #32
Bach415
Bach415's Avatar
I don't think it's irrelevant that much. I know that the smog tech wouldn't be able to tell the difference between the two tunes on the car, but the sniffer that is used for the smog inspection does. We know that the difference between tunes contribute to how much emissions produced at the tail pipe for the sniffer test. Visual inspection is a whole another thing because not all places would visually inspect the exhaust system before doing the smog.
In a way, what I'm asking is, will the car run properly with the current mods on, using the CARB tune as that should produce less emissions? It could help pass smog test (sniffer portion) without the hassle of changing the parts out.
Old 08-12-2016, 10:34 PM   #33
GenRuleAThumb
GenRuleAThumb's Avatar
Drives: 2014 FR-S
New cars don't get the sniffer. They simply plug into obd port.
GenRuleAThumb is offline   Reply With Quote
The Following User Says Thank You to GenRuleAThumb For This Useful Post:
Bach415 (08-12-2016)
Old 08-12-2016, 11:52 PM   #34
Bach415
Bach415's Avatar
Well then. I stand corrected on my previous post. I didn't notice that newer cars just use obd only and visual for smog.
Old 08-19-2016, 12:00 AM   #35
undefindedt
Hi.
undefindedt's Avatar
Drives: 14' Asphalt
Nice results people. I guess Chris in his Stormtrooper ran a pull or two but his clutch wouldnt grab..well he got mad and bought a ACT and CF driveshaft..put it in last weekend..
Took it to Sonoma drags last night and ran a 13.1x with TC on and bog off line even with a 5K launch control
Makes me wanna stop putting money into my trucks and go boosted but idk
14' ZN6
92' RN80
81' RN38 "Shitbox"
I like Toyota's
IG: undefindedt
undefindedt is offline   Reply With Quote
Old 08-21-2016, 05:43 PM   #36
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I'm getting ATC, injectors, fuel pump, flex fuel, and tune from William at delicious. Can't wait to see the new numbers.
Old 09-01-2016, 06:31 PM   #37
exE36M3
So I see quite a few "catless" parts in the notes of the dynos. :\
I'm all for making more power gentlemen but you guys are putting some serious stuff into the air.
CARB and emissions aren't all about politics.
When you are standing in line at the pharmacy to buy asthma inhalers for your kids or yourself...
That 15 hp - 20 hp over the other guy doesn't seem worth it to me.
And if you happen to get the *wrong* cop to pull you over...
Section 43008.6 (a-b) allows the courts to collect up to $1,500 per offense or failure to pass smog due to tampering.
Federal Offense by Section 205 (a). The operator's fine can be no more than $2,500 and the installation agency no more than $25,000.
exE36M3 is offline   Reply With Quote
Old 09-02-2016, 12:22 AM   #38
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Not me! Stock headers and catted mid-pipe. Even when I had JDL, I had the catted version lol. Probably going to stick with running the CARB tune too
The Following User Says Thank You to BigFatFlip For This Useful Post:
exE36M3 (09-02-2016)
Old 10-06-2016, 12:31 AM   #39
GenRuleAThumb
Drives: 2014 FR-S
Fair enough.. but I'm running e85. And only missing the cat at the header not the mid pipe.. my guess is I'm polluting less than you with the e85 and 1 cat..
Old 10-14-2016, 06:09 PM   #40
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Just to clarify, your car has the TRD exhaust doesn't it? D-shaped exhaust tips... Seems like it's good for extra 8hp compared to my standard exaust...
Gary at Mann and Bill of Delicious both said the TRD is worse than stock. Gary said they measured pipe diameter and TRD is less than stock. They think it is robbing me of 10 Hp.
New numbers:
303.5 corrected
310.3 engine
231.9 torque
kask2_6.0 (10-14-2016)
Old 10-14-2016, 08:21 PM   #41
PMok
Codename: Stitch
PMok's Avatar
New numbers:
303.5 corrected
310.3 engine
231.9 torque
Wow, very nice... that's got to be a nice kick in the pants compared to what you had before...
Old 10-15-2016, 08:58 PM   #42
Sapphireho
Famous Potatoes
Sapphireho's Avatar
The car is perfect now, and I don't just mean power, I mean idle, parking lot speed, and going fast. It is so smooth and perfect. I am so happy with it now.
The new clutch is awesome too. I just really love the car now.
I just had to drive it so I took it up hwy 9 to Boulder Creek today, then down Bear Creek. It was super wet, covered with tree debris, and slippery, but I had to drive it. First time the car has been in the rain. I just cruised, practiced shifting with the new clutch, and had a blast.
I can't say again how happy I am with the car! Sooooper fun
Norcal86 86Day Block Party and Dyno Day finch1750 Northern California 115 08-11-2016 06:53 PM
My Nameless header dyno results (results to follow) Simply_the_best Engine, Exhaust, Transmission 39 06-28-2016 04:09 PM
Australian Dyno Dyno Results Shiv@Openflash Software Tuning 11 07-22-2015 04:57 AM
2014 Norcal's 86CUP Challenge Results MyRx Tracking / Autocross / HPDE / Drifting 36 10-31-2014 07:13 PM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
