Old 08-11-2016, 10:40 PM   #1
LenA
Drives: 2015 Silver BRZ
CSG Brembo Brakes
I saw a 326mm front Brembo kit on CSG site. Do these brakes require spacer for stock wheels and are they lighter than stock brakes. They look like they use 1 piece rotors and 4 piston calipers
Thanks
Len
LenA is offline   Reply With Quote
Old 08-12-2016, 02:28 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Most sites also list contact page. It's worth using emails listed there to get info about some specific products. Brembo-s (unless some STI retrofits which i don't advise doing) are not the most common (probably due price) on toyobaru. Forum crowd might have less info on uncommon products then shop selling it.
Captain Snooze (04-02-2022), NoHaveMSG (05-02-2018)
Old 08-12-2016, 02:38 AM   #3
LenA
Yeah, probably a better idea. I'll post what I find out in case anyone else is interested
Len
Old 08-12-2016, 03:51 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
Oh, ignore my comment. It seems that i was in impression you were asking of previous brembo kits offered by CSG, that costed $7.5-8.5K. I see they have added both front and rear brembo kits "Brembo GT System CSG-Spec" costing 1/4th of price of those and marked as *NEW*. At that price level they might get wider user base.
They list kit product numbers though, so you can try searching on those on eg. brembo site, to see if they have some BBK fitment templates to print out and check on your wheels.
Old 08-12-2016, 05:14 AM   #5
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Thanks
Len
I contacted CSG and spoke with Mike over the phone about the kit and it will require a 20mm spacer to fit stock wheels. They are lighter than stock brakes, but not AP Racing light. They include 1 piece rotors so cost of entry is lower and over time can be upgraded to 2 piece rotors to further reduce weight. The Brembo GT caliper allows for thicker pads. That's all the basic info. Would definitely recommend giving them a call to find out further details.
JDKane527 is offline   Reply With Quote
The Following User Says Thank You to JDKane527 For This Useful Post:
Tanstin (02-06-2021)
Old 08-12-2016, 12:10 PM   #6
CSG Mike
CSG Mike's Avatar
Well, what would you like to know? The kit overall is lighter; the rotors are heavier (they are, after all, much larger than stock). You will need a 20mm spacer to clear stock wheels. Maybe (speculated) 15mm for the 17 performance pack wheels.
wparsons (05-02-2018)
Old 08-12-2016, 12:43 PM   #7
LenA
Thanks for reply. I don't really need better brakes yet, but trying to identify options when I get to that point where I do need/want to upgrade.
Len
Old 03-23-2018, 02:32 AM   #8
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Are there any wheels smaller than 18x9.5 that can clear these brakes without a spacer?
Wise is offline   Reply With Quote
Old 03-23-2018, 06:07 AM   #9
CSG Mike
CSG Mike's Avatar
Absolutely.
17x8, 17x9 are popular options.
Old 03-23-2018, 10:20 AM   #10
Wise
Circle Work Clerk
Absolutely.
Do you know if Weds TC105N in 17x9 +35 will clear?
Old 03-23-2018, 04:50 PM   #11
CSG Mike
CSG Mike's Avatar
Sure does!
Wise (03-25-2018)
Old 05-02-2018, 11:34 AM   #12
blown
Drives: ft86
are the rotors off the shelf?
blown is offline   Reply With Quote
Old 05-02-2018, 08:03 PM   #13
CSG David
CSG David's Avatar
They are Brembo HP discs from their high performance division. The metallurgy is different from the standard off the shelf OE replacement, aftermarket tuner replacement, and even OEM application.
The Following User Says Thank You to CSG David For This Useful Post:
Old 05-02-2018, 10:42 PM   #14
juliog
juliog's Avatar
Drives: 86
For anyone reading, these are the brakes the OP is asking about:
CSG Spec Brembo Big Brake Kit for Subaru BRZ / Toyota 86 / Scion FR-S
Great kit, but there's no one size fits all when it comes to brakes. CSG can steer you to the right solution based on your needs and budget
juliog is offline   Reply With Quote
EVO 7 BREMBO FRONT BRAKES ON BRZ? NOTORIOUS.BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-26-2016 01:24 AM
Fake Brembo's AP Racing Calipers/Brakes STIITS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 08-21-2014 12:11 AM
Evo X brembo brakes Justkiz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-12-2013 03:00 AM
Brembo GT Brakes fitments BRZ/FT86 Trap63 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-05-2013 10:39 AM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 11:08 AM
