#771 |
Drives: 13 FRS
Still have some more ducting to do along with a few other things but i'm anxious to get it running sometime soon.
#772 |
Drives: 2013 Turbo FR-S Java Pearl
#773 |
Drives: 2015 Raven FRS
My new hood vent. $83 off e-bay. Came off a newer mustang I believe. So far road use in our 115 degree palm springs temps oil temps are down. Haven't had it on the track yet, that will not be till Sept.
| The Following User Says Thank You to Lunatic For This Useful Post: | sato (01-10-2020) |
#774 |
Drives: RX-7 / BRZ
Fuck and Bump. Did my oil change today and noticed my shroud has melted.
-FBM kit -Ceramic Coated and Wrapped pipes (DEI titanium exhaust wrap) -Spal 12" slim fans with FBM aluminum fan shroud -FBM radiator -vented lower aluminum underbody panel -custom grill opening and ducting -19 row oil cooler -PTP Lava Turbo Blanket -DEI Hose Fire Shield (on oil lines) -OEM wrx liquid oil cooler -Removed weatherstripping on cowl for ventalation -Functional STI fender vents, with cut fenders for ventalation -Spencer Fabrication radiator bracked (leans the rad forward 2") Oil temps in summer rarely exceede 215F. From the best of my knowledge it appears that the PTP blanket is holding in the heat and just under it at the opening, the heat is collecting, which melted the rings on my fan assembly. A couple of the fan blades themselves are slightly warped but, the fan itself still seems to operating.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#775 |
Drives: None
What's the consensus on ducting/custom air dams?
I know the evasive car runs a custom front duct/air dam... any other examples? This is a rough idea I'm working on - I have a plasmacam cnc available for my use, so I'm gonna see what I can concoct. Still need to work on the rad shroud it will attach to. Theoretically, it should seal the bumper nearly completely, the only air going in will be pressured through my rad and heat exchanger. Intake will be fed from my drivers side APR brake duct (passenger side will be ducted to an oil cooler). ![]() ![]() ![]() Obviously not ready to be cut, just a rough sketch |
#776 | |
Also, where did you get your bumper model? Is there an FRS version? |
#777 | |
Drives: None
Directing it more into the radiator should create a more positive flow of air through the rad, and a more pressurized airflow under hood. With proper hood venting, it should be very efficient. I think. I found the 3d model in 3d warehouse (sketchup database) for free! It isnt scaled, but I took measurements and made it to scale. There should be an FRS file in there as well. Worked on it a little bit more. Widened the overall ducting to the width of the rad, leaving the center "diffused/directed" and the sides open. The top slits also direct up towards the top. I'll be honest, the sides/top are just to appear more aesthetically pleasing than a boring single piece duct. ![]()
#778 | |
Sent from my XT1575 using Tapatalk |
#779 |
Drives: None
#780 |
#781 |
I also moved my engine oil cooler and tranny cooler out board where the running lights were. Now they get direct air flow and no longer stacked up in front of intercooler, and radiator.
| The Following 3 Users Say Thank You to Lunatic For This Useful Post: |
#782 | |
Drives: None
The cnc/plasmacam is my buddies. He has a business making cute little customized metal cut signs you put in front of your house. I'm pretty sure I'm using sketchup right now because it was the first thing that came up in my google search results for 3D design software. Only CAD experience I have is 2D design. |
#783 | |
#784 | |
Drives: None
| any serious benefit Heat Tapes? | Djen | Engine, Exhaust, Transmission | 22 | 02-18-2014 04:20 PM |
| Heat bad for your car? Ways to cool it? | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 08-01-2013 11:15 PM |
| Misfire with heat? | bigjake | Issues | Warranty | Recalls / TSB | 2 | 04-28-2013 10:02 PM |
| Do I Need a Heat Shield? | arleewa | Engine, Exhaust, Transmission | 1 | 01-08-2013 07:37 AM |
| Overpipe Heat question | Amadeus | Engine, Exhaust, Transmission | 5 | 12-19-2012 02:18 AM |
