Old 06-21-2012, 09:15 PM   #1
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
Hard shifting into 2nd gear when cold
Anyone notice hard/notchy shifting into 2nd gear when driving off in the morning?
I can start car and move shift lever through all gears effortlessly in the garage first thing before moving off. But when its time to shift into 2nd going down the street it is rather balky.
After gearbox warms up a few miles it shifts great.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 06-21-2012, 09:29 PM   #2
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
On my FR-S it does this. Very notchy, audible gear change. Does go away after driving it a bit. I think the reason cause the transmission fluid isn't warm yet.
F1point4 is offline   Reply With Quote
Old 06-21-2012, 09:35 PM   #3
Indestruct
Drives: 2013 SWP Limited BRZ, MT
I have this problem too, very notchy. I like to shift w/out pressure, but when second is giving me problems i'll just force it in lol.
Indestruct is offline   Reply With Quote
Old 06-21-2012, 09:46 PM   #4
Lighting Red
Habitual Line Crosser.
Lighting Red's Avatar
Drives: ^ Two of my favorite things.
I haven't noticed it... But that's mainly due to me not having the car yet.
But, but, but... It's only 200 hp?!
Lighting Red is offline   Reply With Quote
The Following 4 Users Say Thank You to Lighting Red For This Useful Post:
DAN_BRZ (06-05-2013), dori. (06-22-2012), FoolCyclist (06-22-2012), Jayde (06-22-2012)
Old 06-21-2012, 10:50 PM   #5
Asphaltfrs1
Asphaltfrs1's Avatar
Drives: 2013 asphalt fr-s
Usually 1st is the one that gives me trouble. Sometimes it feels like it doesn't want to go in. So I move it to 2nd and back to 1st. That seems to work.
Asphaltfrs1 is offline   Reply With Quote
The Following User Says Thank You to Asphaltfrs1 For This Useful Post:
Dang Lad (06-23-2012)
Old 06-21-2012, 11:42 PM   #6
speedracer38
speedracer38's Avatar
Drives: 2015 CWP Subaru BRZ Series.Blue
2nd is extremely tough to shift into while the car is cold....it takes about 5-10 seconds to shift because I don't want to force it into gear and I am very gentle on it until the car is warmed up. I usually put it in neutral after i get up to speed in 1st then release the clutch, then clutch in and gently put the car into 2nd when it's cold and the car seems to like that more then going straight from 1 - 2 quickly. Try it out I hope it helps you as well!
speedracer38 is offline   Reply With Quote
Old 06-22-2012, 01:17 AM   #7
cwik
cwik's Avatar
Drives: 1st NA BRZ, 2007 GSX-R 600
I'm definitely noticing this too. I called up my dealership, and they said I could schedule a ride with one of their service people so explain the problem, but I was worried the car would warm up by the time I got to the dealership. The fact that others are seeing this too makes me feel a bit better.
The main reason I started to panic immediately is because my brother owned a '93 Eclipse, and getting into 2nd gear (from 1st or 3rd) was awful (it was actually the opposite of the BRZ, where it was perfect when the car was cold, but acted up once warmed... far worse :P). It would always resist, it would crunch and grind, etc. The only thing that seemed to help was to double clutch, and that didn't even work all of the time.
As long as it doesn't get worse than what it is, I'm fine with how my BRZ acts.
cwik is offline   Reply With Quote
Old 06-22-2012, 01:25 AM   #8
dietz
Drives: Raven / 6MT FR-S
AKA double clutching. I'm not good at it, but I noticed today that it makes the 1-2 shift butter smooth when cold.
dietz is offline   Reply With Quote
Old 06-22-2012, 05:19 AM   #9
BMWDavid
+1, I'll try this as well.
2005 Honda XR650L
2006 VW GTI/DSG
Old 06-22-2012, 05:49 AM   #10
Enemies
Drives: '13 SWP Sport-Tech (Limited)
I thought I just sucked but 1st and 2nd gear can sometimes be a bit rough. 3rd and above always seems great. 2nd definitely by far is the worst though.
Enemies is offline   Reply With Quote
Old 06-22-2012, 06:15 AM   #11
#87
I usually post drunk
#87's Avatar
hmm I always thought if you can't find it, grind it ^_^
#87 is offline   Reply With Quote
The Following User Says Thank You to #87 For This Useful Post:
dori. (06-22-2012)
Old 06-22-2012, 06:23 AM   #12
blalor
Drives: WRB BRZ Limited 6MT
I'm noticing the exact same thing. It's difficult to do the 1-2 shift most of the time when cold. It seems to get better after driving for a bit. First is also finicky. I'm considering changing the fluid when I finally get to 1,000 miles.
blalor is offline   Reply With Quote
Old 06-22-2012, 06:32 AM   #13
Lighting Red
That technique is reserved for women, you have to treat your car better than that.
Old 06-22-2012, 06:46 AM   #14
BMWDavid
As I replied a bit earlier I will try the double clutch method. Was wondering if a trans lube change would help? Perhaps a different brand than OEM? I see a thread on the lube, oils section that deals with this but no one has actually tried a different fluid yet.
2005 Honda XR650L
2006 VW GTI/DSG
Hard shifting into first gear; normal? blalor Engine, Exhaust, Transmission 54 08-31-2017 09:57 PM
shifting from 1st to 2nd jarviz Scion FR-S / Toyota 86 GT86 General Forum 35 05-26-2016 07:15 PM
cold air intake? carbonBLUE Engine, Exhaust, Transmission 72 09-30-2013 12:56 PM
Thud/Clunk when shifting. erom Engine, Exhaust, Transmission 10 06-17-2012 07:08 PM
How's the shifting of MT compared to other cars Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 25 06-07-2012 10:20 AM
