Drives: Scion FR-S (Red)
RPMS Gauge do not Move to the Limit when I put the Key Switch to On Position
Greetings fellow. I have a problem with the meter rpms. Couple of days ago the car battery was damaged and quickly change the other. The problem is that before when moving the key switch to On the rpms gauge needle is moved to the limit and back to zero. After changing the battery the meter stopped. As I can fix that?
FR-S Puerto Rico Group: https://www.facebook.com/groups/2725...okmark_t=group
Puerto Rico Solo 1 Group: https://www.facebook.com/groups/3509...okmark_t=group |
#2 |
Drives: 2015 WRB BRZ Premium
Does it operate correctly otherwise, like when driving around normally? All of the other guages work?
The tach on these cars is run off the canbus, a stepper motor operates the needle. As you say, it should sweep when you turn the key. My suspicion is that there is a problem with the cluster. The ECM must have a good rpm signal if the car runs without throwing a code, so the issue is somewhere in the cluster. Its not a communication issue with the cluster, as the ECU would throw a fault code if that was the case. First thing i would do is disconnect the battery, hit the brake, then reconnect the battery and see if that solves the problem
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
#3 |
Try to set your shift light again.
As far as I know rpm needle sweeps to where shift light point is set. Im not 100% sure but it may work. |
#4 |
Sometimes I'm wrong.
Drives: '13 FR-S/'96 240SX
Try setting your shift light.
[ame="https://www.youtube.com/watch?v=fB9dcC9dl3w"]Scion FR-S: How to set the Shift Light & Gear Indicator Display Settings (BRZ GT86) - YouTube[/ame] |
#5 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
RTFM :P
#6 |
http://www.ft86club.com/forums/showthread.php?t=8655
http://www.ft86club.com/forums/showthread.php?t=27377
#7 |
Ok Rightnow Im at work. But when I have the opportunity I will try your imputs. Thanks.
#8 |
Problem fixed. Thank you guys!
| The Following User Says Thank You to rene0023 For This Useful Post: | humfrz (08-06-2016) |
| Switch to 5w30 has made my pressure gauge crazy | BDotG | Engine, Exhaust, Transmission | 20 | 05-05-2016 12:52 PM |
| FS: Unichip, USB cable, 2 tune selector switch, Clutch switch | BII302 | Engine, Exhaust, Bolt-Ons | 6 | 04-13-2015 08:06 PM |
| WTB Instrument Gauge Cluster Dimmer Switch Wire Harness | Arcadien Angel | Want-To-Buy Requests | 1 | 04-12-2015 10:58 PM |
| How to replace turn signals with switch backs and its relay switch. | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-31-2013 12:42 AM |
| FS: Cyberstork red gauge cluster overlays with white RPMs. | stockysnail | Interior Parts (Incl. Lighting) | 7 | 05-17-2013 12:41 PM |
