#71 |
Drives: 2015 Ultramarine FR-S AT
Installed mine yesterday. Feels good man
#72 |
I used "Instapak Quick" to add some support underneath the panels.
I used size #100 and it seems one is enough to fill the gap. I also think this will help deadening the noise as well.
| The Following 3 Users Say Thank You to nunonuna For This Useful Post: |
#73 |
Drives: 2013 Raven Scion FR-S
I plan on making my own version of this kit, minus the seat-back separator piece. I like having the open cabin all the way to the back, but want the rear seat bottoms replaced.
nunonuna, those look perfect for that space!
#75 | |
Drives: anything you let me
![]() I imagine you could do a little Sneaky Pete bottle under each side but most standard bottles will be too big. Without getting too crazy into deconstructing your car, if you take out one of the rear seat bottoms and run a straight edge from the peak of the driveshaft tunnel to the outside plastic you'll see the space you have to work with. |
#76 |
Drives: 2025 BRZ, ex-2012 GT86
I'm surprised no one asked this before but to track guys that's the main question: does this kit allow to put 3 assembled wheels on top of it?
#77 |
Drives: 2018 Golf R
Not unless you put some sort of bracing underneath. I had two wheels (no tires) at about 18lbs each and the bottom panels did not like that.
Parting out HERE
| The Following 2 Users Say Thank You to civicdrivr For This Useful Post: | Efferalgan (08-30-2016), jliongh (02-25-2017) |
#78 |
#80 |
#82 |
| The Following 2 Users Say Thank You to nunonuna For This Useful Post: | Efferalgan (09-02-2016), jliongh (02-25-2017) |
#83 | |
For the price of the kit, fit and finish, you're better off picking up the kit and not installing the upright panel (which is removable at any time within seconds). I was looking to do exactly what you are but couldn't beat it for the price, factoring in how much labor would be involved in fabricating something to look this clean. |
#84 | ||
I'll have to grab a pic before Lime Rock next week. Just had an idea... If you're thinking of keeping 3 wheels standing vertically (like 3 back seat passengers), maybe you could cut a trapezoid shaped piece of thin plywood to throw down on top of the kit to distribute the weight. Remember the tunnel supports the middle of the span. Spray the plywood with a rubberized coating and it'll look clean, not leave fragments everywhere, and not wreck your interior. Last edited by Uplink; 09-01-2016 at 12:36 PM. Reason: Had an idea... |
| The Following User Says Thank You to Uplink For This Useful Post: | Efferalgan (09-02-2016) |
| Tags |
| diy, rear seat delete, weight, weight loss |
| Rear Seat Delete kit | ender2664 | Cosmetic Modification (Interior/Exterior/Lighting) | 53 | 10-04-2017 02:10 PM |
| REAR SEAT DELETE SUB BOX | NYCsubaruBRZ | NY / NJ / CT / PA | 19 | 01-28-2014 02:38 AM |
| Company in NC wants to make a rear seat delete | Lonewolf | Southeast | 33 | 12-23-2013 05:44 PM |
| Rear seat removal? | Shizuma | BRZ First-Gen (2012+) — General Topics | 34 | 04-01-2013 03:36 AM |
