Old 07-30-2016, 10:05 PM   #43
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Sorry to bump this again @steve99
You're knowledge has been a great help thus far. I've been logging for 4 days now via ECUTek. My logs show everything is working 100%, no issues what-so-ever.
So it appears the only issue is happening at the shop once they're plugged up and flashing. Seems to me an issue with their equipment and/or ROM being used... or improper flash / post flash procedure.
Any other thoughts or opinions? Thanks again.
Hmm im not sure what could be picked up from logs, but if ecuteck can monitor say the ecu commanded position of camms verses the measured position. You might be able to make an educated guess , say if the ecu is asking for 20 degrees and measured its still zero would indicate hardware issue, however i would ecpect that should trigger a cel code.
If the commanded position just stays at zero then maybe that something wierd in ecu hardware or some preset cindition is not being met.
Faults like this are going to be extremly timeconsuming and likely expensive to repair.
One of the TSB for cam issues involves replacing the ecu, its possible that the ecu hardware has a fault.
if you can source a second hand ecu you can replace it as per link below.
you can flash in the required rom calid before syncing to security if needed, im not 100% buy im pretty sure all the ecu are same hardware you just need to flash in correct rom to suit your car, flash it up with tactrix if you have one then you wont need to mess with ecutec licience.
you dont need to chage the vin in ecu for car to run
http://www.ft86club.com/forums/showthread.php?t=102810
SpectreRT is offline   Reply With Quote
Old 07-31-2016, 03:21 AM   #44
steve99
Drives: FT86
you guys have traction \vcs turned full off an dyno ? as that may upset things
After any reflash hot or cold you goiung to need to turn ignition fully off after flash.
Then start and let car idle for at least a minute after the idle has settled below about 750 rpm. if your tuner has bumped idle to a high rpm say 1000 it may cause issues not sure.
If that does not work id say turn ignition off , remove battery terminal , press brake pedal, reconnect and start and lket idle for at least a minute at normal idle speed.
after that im pretty stumped unfortunatly
Old 07-31-2016, 04:08 AM   #45
Kodename47
Kodename47's Avatar
Drives: UK GT86
If they're flashing via ECUtek, they should always go through the full procedure. Flash > Reset > Clear all DTCs when asked. Then you can fire up the car. Never had an issue with that method.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-31-2016, 04:38 AM   #46
steve99
Drives: FT86
Agreed,
ive flashed with ecutek and done the full reset dtc clear no issues.
But also flashed with ecuflash\tactrix and Open Flash tablet and never had the issues with cams and they dont clear dtc\reset the other modules in car..
Only time ive had issue is if you dont let it idle for a minute after flash at the base idle speed, its certianly a weird issue.
Old 07-31-2016, 10:38 AM   #47
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Thank you both for the replies. This thread has really restored my confidence in the FT86 community.
I believe they had traction off, but not the pedal dance diagnostic mode. I'd like to believe they followed full instruction as they've easily tuned 200+ twins. But I'll be a part of the next attempt to verify.
I'll report back with how this goes. I've been logging every day since my last visit to the shop and VVT / Timing is always spot on. So i'm fully convinced my car has no issues.
Thanks guys.
Agreed,
Old 08-03-2016, 01:55 PM   #48
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Tuner has the car now, daily driving it was fine. They checked it in the parking lot and it was fine. Put it on the dyno; no go.
Any final options?
Old 06-05-2017, 03:07 PM   #49
Kodename47
Kodename47's Avatar
Drives: UK GT86
Just like to bump this. This seems to be more common that I thought, I hear that certain cars require a certain amount of driving before the cams come active.
I have an interesting one now, I have a car that is simply not activating the cams at all. No CEL and no obvious reason why. Usual parameters are working, has anyone managed to locate a list of the actual requirements for activation?
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-05-2017, 07:46 PM   #50
steve99
Drives: FT86
No idea on exact conditions
Other than the 1 minute at normal idle that serms to work in most cases.
Is it possible to load a completly stock rom ??
Maybe try an A01G or I rom incase the newer roms have additional requirements as long as car is not a 2017 red manifold car
If its boosted is it possible that ecu sees positive pressure at idle and this may upset sequence
Else swap in another ecu if you have one,
Old 06-06-2017, 02:53 AM   #51
Kodename47
Kodename47's Avatar
Drives: UK GT86
Already done, 3 of them to be exact..... 700G/A00G/A01G. It's originally an A00G before flashing. No bueno. Even had them drive around on those tunes briefly.
It's running the same SCas me and the same basic tune as mine, runs fine on my car. No positive pressure at idle. It's annoying that we have no idea of how it was running before the tune and the car is in a different country.
I sent the official VVT test process yesterday so will see what the results are.
.: Stealth 86 :.
Kodename 47 DJ:
steve99 (06-06-2017)
Old 07-18-2017, 01:45 PM   #52
sw20kosh
Drives: 2013 Black FR-S
Curious if you have gotten anywhere with this? I have the same issue with an NA 2015 brz. No cam control whatsoever no matter what we do. Motec m150 runs the cams just fine though.... so it is probably not hardware though we have tried 2 stock ecus already.
Old 07-18-2017, 04:49 PM   #53
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's got to be the checks it does. Have you messed with the O2 sensor.I'm no further with this car however one of the exhaust banks logs 20deg constantly when the other 3 sit around 0. Not sure why this doesn't throw a CEL but I reckon it has to be the issue.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-19-2017, 08:05 PM   #54
sw20kosh
What would you do with the O2 sensor in this case?
I just changed the crank position sensor. No difference...
Why are these cars not throwing ANY codes while the cam control is completely shut off? Is this is terrible programing/design?
Old 07-20-2017, 03:10 PM   #55
Kodename47
Kodename47's Avatar
Drives: UK GT86
The car validates that it's working in closed loop I believe, ie a natural idle. If you're not having issues with that then I doubt it's that but could be worth validating the front and rear O2 voltages etc. Only a suggestion if you've removed the sensors to fit in a new manifold etc
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-22-2018, 10:12 AM   #56
laksman91
Drives: BRZ Sport-Tech, Evo X GSR, E92 M3
Has anyone figured out a solution to this? The Cams turn on when on the road, but wont on the dyno (Dynopak)
laksman91 is offline   Reply With Quote
Cam timing adjustments without dyno StormTrooper Software Tuning 17 02-19-2014 04:16 PM
POST UP YOUR DYNO FIGS!![Nat. Asp]DYNO Figures (BEFORE and AFTER) stevo_12v Engine, Exhaust, Transmission 10 12-19-2013 02:02 PM
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 08:06 AM
