Old 07-30-2016, 09:02 PM   #57
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Originally Posted by Spartarus View Post
All the captive hardware for mounting the transmission crossmember is on a single large stamped plate / brace. There's only spot welds holding it on. You don't have to cut into the chassis at all. Spot drilling that brace piece out also opens the transmission tunnel up quite a bit, and makes space for new components and hardware.
Much easier than clearancing the tunnel brace with a grinder and recycling the old captive hardware.
You have to grind the coating off to weld anything new on anyway, and cutting spot welds is pretty clean with the right tools.
AFAIK, @Ross is the only one to go this route with my car.
With the V160, I don't think there's enough room with the FRS OEM bracing to be kept, but that was almost a year and a half ago? So I can't recall exactly.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 07-30-2016, 10:04 PM   #58
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Badass work!!
Old 07-31-2016, 12:03 PM   #59
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
That is very clean work indeed.
Yeah, there's no space to keep the bracing with any "real" transmission.
The GTO T56 will fit with lots of "clearancing" but anybody doing it is better off just cutting the damn bracing out.
The 3sGE Altezza motor will fit with its J160 transmission, (not to be confused with V160) but it's funny because the J160 is literally the same Aisin box as ours. Well, the center section at least...
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 08-02-2016, 01:34 PM   #60
cf6mech
Drives: FRS Silver LS1 swapped.
As I promised......[ame="https://www.youtube.com/watch?v=5GDEaYuJ8Ek"]CAN integration for BRZ/FRS/FT86 platform - YouTube[/ame]
cf6mech is offline   Reply With Quote
Old 08-02-2016, 07:13 PM   #61
slicktop
Glad you got it working. Feels good right?
-slicktop
2013 Scion FRS
Old 08-02-2016, 07:47 PM   #62
cf6mech
Its a friends car.....mine should be soon.
Old 08-02-2016, 11:57 PM   #63
Zer0
Drives: 2015 frs
Looking good. Did the can bus device keep all stock functions, if not what was not kept?
Zer0 is offline   Reply With Quote
Old 08-03-2016, 12:54 AM   #64
cf6mech
Reference to a blog soon to be posted answering these questions .
Old 08-03-2016, 04:54 AM   #65
Zer0
Drives: 2015 frs
Thank you for everyone who contributed to this thread. It's good to know we have a few standalone solutions for combined ECU and can bus functions, as well as people working on a solution to add in the needed can bus signals if you are doing a swap, and need to use a oem ECU which is the case for me.
Old 08-04-2016, 06:14 PM   #66
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
I would consider only one swap, LS swap. Thought I won't do it until there is a solution with All systems working properly.
@Manji so everything works with the Motec M150?
I see full blown sells a plug and play package as far as it replacing the stock ECU. (I know the engine harness needs to be moddified to accomodate the new motor sensors).
Yes everything.
AC, Heater, PS, TC, ABS etc.
The one thing that didnt work out of the box was the fuel level gauge. This car does something weird with how it measures the fuel level. Rather than measuring the tank, it remembers how much its used. When I first got my car back, the economy gauge said I was doing 5L/100km (so less than the boxer) I knew that wasn't right but didn't care. Not until I ran out of gas when the gauge said I still had 3/8th's of a tank.
But once that was known, a quick plug in and adjustment of a value/factor and now it's correct.
Manji is offline   Reply With Quote
Old 08-04-2016, 06:18 PM   #67
Sportsguy83
Drives: Limited BRZ
Originally Posted by Manji View Post
Yes everything.
That's very awesome!! I would only do a swap if everything was working like stock, like yours. Amazing build. Lots of respect.
Sent from my Nexus 6P using Tapatalk
Old 08-05-2016, 11:22 PM   #68
cf6mech
SOME GREAT NEWS RIGHT HERE.......https://m.facebook.com/story.php?sto...74774139259849
Old 08-06-2016, 02:25 AM   #69
Zer0
Drives: 2015 frs
Nice. Thanks for the update.
Old 08-08-2016, 10:17 AM   #70
toddy101
toddy101's Avatar
Drives: LS3 BRZ
Hi guys,
Andrew from AGT Engineering here.
Just thought I would put in my 2c to this thread.
I developed a prototype solution a fair while ago (nearly 12 months). I do not own a FT86/BRZ and have so far relied on a couple of projects in Australia to test my first prototype units. We had the instrument clusters RPM, temp gauge, MIL and Oil pressure lights working the end of last year and the EPS functional. Unfortunately this is as far as it got as the test vehicles were still projects and were only able to be driven down the driveway and back. A couple of units were also sent to the US for testing. One went to the Vorshlag vehicle for testing, but turns out the GM ECU was an older version and didn't have the right CAN messages, so it did not work. I then added hard wired inputs to allow RPM pickup, coolant sensing, as well as the original I/O for indicator lamps to/from Canbus. A couple of these units were then resent to the testers, including the Vorshlag. The latest units have also been used for early model (pre-can) Subaru engines into late model Can based Subarus (04+ Legacy and 08+ Impreza/Wrx's) and sent across the world with great feedback. There have been no reports of spikes on gauges as previously speculated. I guess the combination of the on-board hardware and software filtering is doing its thing.
I have so far spent countless hours studying the 86 Canbus without any form of income. The units have been given to all the testers at my cost. I have found it a bit disappointing and a bit odd that some testers have gone and bagged my FREE product and writing it off BEFORE contacting me for assistance on how to connect it up or troubleshoot.
So basically I would like to say please help me to help you. If you have an 86/BRZ engine swap project that is about to be running, are technically minded and not scared to do a bit of fault finding for me, canbus logging and access to a good ABS/ECM diagnostic machine, contact me and I will see if I can give you a free (prototype) 86/BRZ Translator for testing.
Andrew.
toddy101 is offline   Reply With Quote
Switching to LEDs. Do I need CANBUS bulbs? soilent BRZ First-Gen (2012+) — General Topics 11 01-07-2016 11:28 PM
Odb2/canbus flexibility Futaba Electronics | Audio | NAV | Infotainment 1 08-25-2015 03:00 PM
CanBus Triple xjohnx Electronics | Audio | NAV | Infotainment 8 01-31-2015 11:39 AM
Toyota codefest CANbus competition robot Electronics | Audio | NAV | Infotainment 5 12-12-2014 03:11 AM
CANBus pseudo Electronics | Audio | NAV | Infotainment 4 09-03-2014 01:11 PM
