Old 09-03-2015, 05:36 PM   #197
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
How is that?
Originally Posted by PowderfaceTr. View Post
Why not clutch the pulley and add a bypass. That beast is robbing you of tons of valuable powers at the top end. My estimates are around 31% loss when the blower is past its range.
It's a positive displacement. with the lower pulley that compound boost would dictate, the supercharger should be well within it's efficiency range even at the upper rpm range. That's the beauty of compound boost, the only thing that becomes a restriction is the air flow capability of the first FI system. You need to have a primary FI that provides enough TOTAL air flow for the power you are wanting at the boost levels that THAT specific device will be running at. For instance, say you're going to be running a pos. disp. S/C as the secondary and a turbo as the primary.
The S/C is running at a max of 9 psi and you want to run total boost at 30 psi. So you would be running the turbo at between 15-12 psi.
Now notice that I listed that backwards? That's because if your boost controller for your turbo is going off of manifold pressure, the turbo will be running higher boost while the S/C is at lower RPMs making lower boost and then the turbo will be making lower boost at higher rpms when the S/C is providing more boost. You will get maximum boost for a greater range of rpm as well compared to a non compound boost setup.
So you would want to look at the compressor maps for the turbos and find the amount of airflow that you want at that 12 psi range to determine which turbo you want to run.
Again for example, you want to get 550 hp, you're going to want a turbo that provides about 50-60 lbs/minute at 12 psi.
The airflow of the S/C doesn't even come into play. It's pos. displacement so it will take whatever air is coming into it and compress it at a specific ratio.
Jaden
Jaden is offline   Reply With Quote
The Following 3 Users Say Thank You to Jaden For This Useful Post:
DustinS (06-16-2016), killboy (07-25-2016), sato (09-06-2015)
Old 07-25-2016, 11:48 AM   #198
the_one_mike
Drives: 2013 BRZ World Rally Blue
Not sure if this has been posted anywhere but it looks like they recently (updates this month) dropped a VR38 built by HKS into this car and ditched the twincharger FA20 setup.
http://www.streetfx.com.au/streetfx-...35-gtr-engine/
I recently bought myself a 2013 BRZ and have dreamed of an insane twincharger setup that works consistently and it looked like this was the most promising I have found... Sad to see that they ditched it, though this is an insane swap itself.
Anybody know of any other successful twincharger setups (outside of the other mentioned in this thread)? I have also read about "Project 86" which is also based out of Australia but it appears that they are running a tandem supercharger/turbocharger as opposed to a true twincharged system.
the_one_mike is offline   Reply With Quote
Old 07-25-2016, 12:26 PM   #199
fang_gt86
FR Noob
fang_gt86's Avatar
Something like this? Not sure what happened to this build though..
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
Old 07-26-2016, 08:33 AM   #200
wtrxprs007
wtrxprs007's Avatar
Drives: 2006 Toyota Prado 4.0V6
Yeah I saw that on the "what did you do to your frs" thread but I thought it was just a photoshop render. Dang
wtrxprs007 is offline   Reply With Quote
Old 07-29-2016, 11:36 AM   #201
WTF
WTF's Avatar
Drives: FT86, BMW 5, JZA80, Porsche 986S
No sir, no photoshop :P
And yes, we ditched the twincharge.
We just werent going to be able to get the power figures we wanted from it reliably. We hope to get somewhere in the vicinity of 1hp per kg from this setup.
600hp Built FA20 Widebody Toyota 86/FRS.. build thread
WTF is offline   Reply With Quote
The Following 3 Users Say Thank You to WTF For This Useful Post:
8686 (07-30-2016), DustinS (07-29-2016), wtrxprs007 (08-09-2016)
Old 08-05-2016, 11:44 AM   #202
Jaden
Road-hole
ok can you atleast....
At least tell us what you DID get out of it?
Jaden
Old 08-07-2016, 10:28 AM   #203
WTF
WTF's Avatar
Jaden
best we saw out of the FA20 was 545whp.
We had HG probs and ended up deciding to press on with the VR38 idea as we wanted to get bulk hp, and the FA20 wasn't proving to be worth the amount of time and money. At least the VR38 is still unique and well capable of our goals.
Old 08-07-2016, 06:01 PM   #204
the_one_mike
Is the other twin charge project you were associated with still running? Or has that been dismantled as well?
Old 08-08-2016, 02:16 AM   #205
WTF
WTF's Avatar
this was the only one we had any involvement in.
Old 08-08-2016, 08:15 AM   #206
the_one_mike
Ahhh okay, I thought you were also part of the "Jet86" build as well.
Regardless, I appreciate all the effort that your team put into trying to make this successful. Maybe my dreams aren't so realistic... That is why they call them dreams.
Old 08-08-2016, 02:40 PM   #207
Jaden
Road-hole
If you were using the same turbo..
I'm not surprised that's all you saw out of it if you were using the same turbo as the jet86 project. He was using a gtx3076R...
You would need a turbo capable of 60-70 lbs a minute at 10 psi to get the most out of that setup, a 3076R is going to be air starved at those total boost levels.
Jaden
An FA20 should be capable of 750hp at 35 psi of boost, but in a twin charge config, you need a turbo capable of 75-80 lbs/minute airflow at 13-15 psi to do it.
The Following 2 Users Say Thank You to Jaden For This Useful Post:
DustinS (08-08-2016), XtremeMaC (02-18-2019)
Old 08-09-2016, 04:03 AM   #208
wtrxprs007
wtrxprs007's Avatar
I always thought there were two WTF86s running around. I kept seeing pics of one with VIC plates and another with QLD plates (one saying WTF 86 and another with WTF 086) as well as different stickers on them. Oh well
Old 08-09-2016, 12:59 PM   #209
Jaden
Road-hole
Whenever anyone talks about compound boost...
Whenever ANYONE talks about compound boost they make the true, yet erroneous statement that they can make more power on turbo alone...
That just simply isn't true. You can't make any more power on turbo alone. You simply can make more power on THAT specific turbo alone and that's because you are restricted by the air flow of the primary (read, pulling from atmosphere) FI system.
You need a larger turbo with a compound boost system than you would from a stand alone turbo. That's the only difference..Now the benefits...
If you are doing it with a pos. displacement S/C as the secondary, you get a more linear throttle response, reduced lag and quicker spool of the turbo.
Because of this, having to use a larger turbo to get the same max power actually isn't that big of a deal.
Your torque curve will be monstrous and the spool characteristics of even a large turbo will be insane when sized right...
The key thing though is that the turbo HAS to be sized RIGHT...
You need to be aware of what boost level the turbo will be running at and make sure it has the air flow to support the power you want.
I absolutely PROMISE you that had they used a bigger turbo they would've had the power that they wanted. Would it have spooled fully by 2800 like they were getting? Probably not, but they would've likely spooled it up by 3500 if they sized it right and you have to remember that the S/C was probably providing 9-10 psi of boost by about 1800 rpm already anyways.
A compound boost setup done right is amazing on low displacement engines, unfortunately, few people know how to do them right.
Will a vr38 and a twin turbo do as much for less? Probably...and I don't blame him for switching, but I'd still love to see a compound boost setup done right on an FA20...
Jaden
The Following 4 Users Say Thank You to Jaden For This Useful Post:
DustinS (08-09-2016), JustAnEngineer (08-11-2016), killboy (08-09-2016), XtremeMaC (02-18-2019)
Old 08-09-2016, 11:20 PM   #210
killboy
killboy's Avatar
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
Not a jab, I'm genuinely curious as to what your background/resources are in this area.
killboy is offline   Reply With Quote
The Following User Says Thank You to killboy For This Useful Post:
streetfx, supercharged, twincharged, wtf86
JET86 Twincharged complete build !INSANE! jet86 Member's Car Journals 97 08-05-2016 12:15 PM
Dezoris | FR-S Build | Supercharged & More Dezoris Member's Car Journals 329 03-21-2016 04:48 PM
Supercharged Rocket Bunny Widebody Conversion Build Thread RWDRIFT Member's Car Journals 278 01-06-2014 12:12 AM
Supercharged Forgestar Rocket Bunny Widebody Scion FR-S RWDRIFT FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 102 03-27-2013 06:48 AM
Supercharged GT 86/FR-S/86 vs. Turbocharged BRZ switchlanez Scion FR-S / Toyota 86 GT86 General Forum 61 12-20-2011 11:16 AM
