#1513 |
Not sure if it's been mentioned, but CSG includes a free D-box with every Edelbrock order placed since the D-box's release, upon request. It's THAT good.
*edit* The D-box is not CARB exempt, and technically makes your car not compliant with California emissions. If you want to be 100% emissions legal in California, you cannot run the D-box. Last edited by CSG Mike; 07-26-2016 at 02:19 PM. |
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
#1514 | |
Drives: 86
Do I have one on the way?
#1515 |
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
I noticed that the page for the SC still has the promotion for $300 rebate, but that ended last month, right? Or has it been extended?
#1516 |
Drives: 2015 Raven FRS
#1517 |
#1518 |
Drives: 86
#1519 |
Drives: 2015 Halo FR-S
Has anybody had any issues with their throttle body /throttle position sensor? My car threw a P2119 code and went into limp mode. Since then, the car has sat in a driveway and started up properly, idled fine, and was able to Rev past 3 k.
#1520 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
I would take the air box off and check if the throttle body moves smoothly ie nothing causing it to stick and that it returns back to closed relatively quickly when you let go of the gas pedal. If you are on the CARB tune, I'd give Edelbrock a call also, just to see if they have any other suggestions. I had something similar happen once but I had a different code, P2135 "throttle position circuit low". Same symptoms, was driving on the freeway then went on limp mode with the CEL all of a sudden. Was able to limp to the side of the freeway to check the code. I disconnected,cleaned and reconnected the throttle connector (the Edelbrock comes with an "extension" for it) and the connector for the throttle pedal. Cleared the code and started it up and was able to drive home like normal. Haven't had the problem since (knock on wood). Mine seemed more like an electrical problem than a mechanical one like your code suggests. |
#1521 |
Drives: FRS RS1
New to the Edelbrock kit! Getting it installed this week! Excited to see the power it'll make.
| The Following User Says Thank You to leunglambs For This Useful Post: | CSG Mike (07-28-2016) |
#1522 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
#1523 |
Drives: FRS RS1
Moto East is installing it
Sent from my ONE A2005 using Tapatalk
My 2015 Scion FR-S RS1 Build Thread
http://www.ft86club.com/forums/showt...19#post2718119 |
#1524 |
Simply Forgotus
I kind of figured that since your in the Philly area. He's doing my tune, just got the base file yesterday.
| The Following User Says Thank You to BirdTRD For This Useful Post: | leunglambs (07-28-2016) |
#1525 |
Drives: FRS RS1
Cool cool haha
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
