Old 07-20-2016, 05:10 AM   #1513
CSG Mike
CSG Mike's Avatar
Not sure if it's been mentioned, but CSG includes a free D-box with every Edelbrock order placed since the D-box's release, upon request. It's THAT good.
*edit* The D-box is not CARB exempt, and technically makes your car not compliant with California emissions. If you want to be 100% emissions legal in California, you cannot run the D-box.
Old 07-20-2016, 10:00 AM   #1514
Colin86
Drives: 86
Not sure if it's been mentioned, but CSG includes a free D-box with every Edelbrock order placed since the D-box's release. It's THAT good.
I ordered the Edelbrock kit from CSG just a few weeks ago (long after the D-box had been released) but I didn't receive one.
Do I have one on the way?
Colin86 is offline   Reply With Quote
Old 07-20-2016, 01:29 PM   #1515
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
I noticed that the page for the SC still has the promotion for $300 rebate, but that ended last month, right? Or has it been extended?
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 07-20-2016, 01:55 PM   #1516
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Originally Posted by Reamer View Post
What's the top speed with the new FD?
Sent from my HTC 10 using Tapatalk
Don't know, never topped it out.
Lunatic is offline   Reply With Quote
Old 07-20-2016, 03:39 PM   #1517
CSG Mike
CSG Mike's Avatar
Possibly... can you forward me your invoice? I can double check.
Old 07-20-2016, 04:08 PM   #1518
Colin86
Drives: 86
Invoice number sent via pm, I look forward to hearing from you!
Old 07-25-2016, 12:20 PM   #1519
Tomcat07
Drives: 2015 Halo FR-S
Has anybody had any issues with their throttle body /throttle position sensor? My car threw a P2119 code and went into limp mode. Since then, the car has sat in a driveway and started up properly, idled fine, and was able to Rev past 3 k.
Tomcat07 is offline   Reply With Quote
Old 07-25-2016, 01:50 PM   #1520
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Are you on the CARB tune? P2119 shows as "thottle valve return spring malfunction" here: http://ft86tech.com/frs-brz-error-codes/
I would take the air box off and check if the throttle body moves smoothly ie nothing causing it to stick and that it returns back to closed relatively quickly when you let go of the gas pedal. If you are on the CARB tune, I'd give Edelbrock a call also, just to see if they have any other suggestions.
I had something similar happen once but I had a different code, P2135 "throttle position circuit low". Same symptoms, was driving on the freeway then went on limp mode with the CEL all of a sudden. Was able to limp to the side of the freeway to check the code. I disconnected,cleaned and reconnected the throttle connector (the Edelbrock comes with an "extension" for it) and the connector for the throttle pedal. Cleared the code and started it up and was able to drive home like normal. Haven't had the problem since (knock on wood). Mine seemed more like an electrical problem than a mechanical one like your code suggests.
Old 07-28-2016, 10:54 AM   #1521
leunglambs
leunglambs's Avatar
Drives: FRS RS1
New to the Edelbrock kit! Getting it installed this week! Excited to see the power it'll make.
leunglambs is offline   Reply With Quote
Old 07-28-2016, 05:13 PM   #1522
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Congrats! Are you installing it yourself or is someone doing it for you? I'm trying to install mine this weekend (if I can get my car back from the body shop)
BirdTRD is offline   Reply With Quote
Old 07-28-2016, 05:14 PM   #1523
leunglambs
leunglambs's Avatar
Drives: FRS RS1
Moto East is installing it
Sent from my ONE A2005 using Tapatalk
My 2015 Scion FR-S RS1 Build Thread
http://www.ft86club.com/forums/showt...19#post2718119
Old 07-28-2016, 05:38 PM   #1524
BirdTRD
Simply Forgotus
BirdTRD's Avatar
I kind of figured that since your in the Philly area. He's doing my tune, just got the base file yesterday.
Old 07-28-2016, 05:39 PM   #1525
leunglambs
leunglambs's Avatar
Drives: FRS RS1
Cool cool haha
Old 07-29-2016, 01:13 AM   #1526
Pyrium
Pyrium's Avatar
Drives: Raven 2016 FR-S
I want this kit. Too bad I have a seven year warranty. Oh well, I hope it is available in seven years.
Pyrium is offline   Reply With Quote
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
