CSG Mike, gramicci101, grant86, GrimmSpeed, JDLAutoDesign, JRitt, KCMachine, King Tut, MillersOilsUS, PERRIN, phastafrican, Racecomp Engineering, Raceseng, Roadcone, Sportsguy83, UltramarineLuck, VerusEric, Wonderbar, Xero-Limit
Old 07-28-2016, 12:08 PM   #1737
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Celebrating 4 years of ownership today!
Made some cool artwork with the Prisma app.
The Following 3 Users Say Thank You to ATL BRZ For This Useful Post:
civicdrivr (08-11-2016), gramicci101 (07-28-2016), Teseo (07-28-2016)
Old 07-28-2016, 03:38 PM   #1738
Teseo
Drives: frs
The Porsche stalker...
The Following User Says Thank You to Teseo For This Useful Post:
ATL BRZ (07-28-2016)
Old 07-28-2016, 08:38 PM   #1739
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
hows the flex fuel treating you? notice any reduction in oil temp? ur set up is sort of simliar to mine except i got the CSG louvers and im turbo'ed
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 08-01-2016, 12:08 PM   #1740
ATL BRZ
ATL BRZ's Avatar
Ethanol doesn't really effect the engine oil temperature at all. It affects the combustion chamber temperatures by lowering them and allowing more ignition timing advance without detonation. Thats where the 30whp gain comes from. The flex-fuel kit and corresponding tune makes running ethanol much more convenient and safe.
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
killboy (08-03-2016), Teseo (08-02-2016)
Old 08-09-2016, 11:34 AM   #1741
ATL BRZ
ATL BRZ's Avatar
Some photos from our 86 Day drive at the Tail of the Dragon.
It's been a while since I've made it up there but it was totally worth the day spent driving.
The Following 5 Users Say Thank You to ATL BRZ For This Useful Post:
ap5512 (08-09-2016), Bramick (08-10-2016), killboy (08-10-2016), stoked_on_spool (08-09-2016), Teseo (08-20-2016)
Old 08-20-2016, 08:11 PM   #1742
jmimac351
Chin Chief Instructor
jmimac351's Avatar
Drives: 2015 Ford F150 Aluminium Couch
Originally Posted by ATL BRZ View Post
Resonators are being discussed but TBD.
Pre-production part and literally the first one made; not worried about it with Grimmspeed gaskets.
FWIW I have a similar small imperfection on my JDL header flange. It adds character to a hand-welded piece.
On my first Factory Five Roadster, I had a lot of trouble with one of the header flanges not being perfectly true and it didn't want to seal for very long against a head, and exhaust leaks developed. I tried "everything". I eventually found out about Remflex gaskets. I think they started as a father & son operation, good people. The gaskets are made of very thin slices of graphite, sandwiched together. They are thicker than regular gaskets (which was good for my problem) and they compress when installed. Supposedly they maintain some spring and that helps them keep bolts tight as well. The material they're made of withstands very high heat. Bottom line, I never had another exhaust leak. The cool thing is you can send them a gasket for a custom application and they will do a drawing and make it for you. And I don't think they charged much at all to do it custom - it ends up in their catalog. I ended up having header to sidepipe gaskets custom made, as they were notorious for blowing out.
So, if you do have trouble down the road, check these out:
http://catalog.remflex.com/
http://catalog.remflex.com/category_s/154.htm
2015 Subaru BRZ
2008 NC Miata with 2.5 swap
Building 1963 289 Cobra Le Mans Replica
Cobra Replica Build Pics
Chin Chief Instructor www.ChinTrackDays.com
jmimac351 is offline   Reply With Quote
The Following 3 Users Say Thank You to jmimac351 For This Useful Post:
Brzzee (08-25-2016), civicdrivr (08-22-2016), killboy (08-22-2016)
Old 08-20-2016, 08:22 PM   #1743
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
+1 on the Remflex gaskets. That's all I have on my BRZ because all of the other gaskets on the market pretty much suck for 2 bolt flanges.
Old 08-22-2016, 11:45 AM   #1744
ATL BRZ
ATL BRZ's Avatar
Good to know, thanks @jmimac351
Old 08-22-2016, 04:30 PM   #1745
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Alongside my hood struts and master cylinder brace, this makes 3 GrimmSpeed products in my engine bay which says a lot. Their stuff is super high quality and well-engineered to be functional. Can't wait to take it for a spin, lots of customers already reporting that the brace delivers a snappier steering response and noticeably less NVH. I'll report back with my own opinions later.
I couldn't find the post on your feedback on the GS strut tower bar. Any thoughts? (Sorry if I missed them!)
JazzleSAURUS is offline   Reply With Quote
Old 08-22-2016, 05:35 PM   #1746
ATL BRZ
ATL BRZ's Avatar
It's in the post right after the one you just quoted.
The Following User Says Thank You to ATL BRZ For This Useful Post:
JazzleSAURUS (08-23-2016)
Old 08-24-2016, 12:25 PM   #1747
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Congrats on 4 years! Same here! Car is looking good. Love the wing and hood vents!
Tye300 is offline   Reply With Quote
Old 08-30-2016, 04:24 PM   #1748
ATL BRZ
ATL BRZ's Avatar
Gridlife South at Road Atlanta was a huge success!
I met a bunch of cool 86 drivers from Houston and really enjoyed the festival atmosphere along with the full-course drifting and time attack cars running around my home track at the ragged edge.
Old 08-30-2016, 04:26 PM   #1749
ATL BRZ
ATL BRZ's Avatar
Hot lap from Gridlife.
[ame="https://www.youtube.com/watch?v=UO2gz3PPaVU"]Subaru BRZ at Road Atlanta with Gridlife South 2016 - YouTube[/ame]
Car ran great despite the 120F surface temps and cranked out a 1:47.6 which isn't what I wanted but it inspired me to finally start pulling weight out of the interior soon.
civicdrivr (08-30-2016), MaximeT (08-30-2016), Teseo (08-30-2016)
Old 08-30-2016, 10:50 PM   #1750
georgiafrsguy
Drives: white 2013 frs
looked good out there man. we were actually in the same group. I think I gave you a point by on the back strait. was wondering how you cruised past me so easily haha. I need to get a tune asap to squeeze out some more ponies.
wish the track wasn't so hot either. I melted my tires actually and spun coming out of 3.
georgiafrsguy is offline   Reply With Quote
The Following User Says Thank You to georgiafrsguy For This Useful Post:
ATL BRZ (08-31-2016)
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 04:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 01:46 PM
