#15 |
That happens a lot. I sometimes wonder how many people think I ignored them.
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#16 | |
Contract? /人◕ ‿‿ ◕人\
| The Following 3 Users Say Thank You to soulreapersteve For This Useful Post: |
#17 | |
Drives: Moped
| The Following 2 Users Say Thank You to Lonewolf For This Useful Post: | SmireyFase (07-23-2016), Tye300 (07-27-2016) |
#18 |
Drives: FR-S White - Smexy.
#19 | |
Thank you, this was really informative. Unfortunately, I don't have the stock tires :C. But I will definitely keep all this other information in mind. Wow I learned a lot haha. |
| The Following User Says Thank You to SmireyFase For This Useful Post: | soulreapersteve (07-23-2016) |
#20 | |
Drives: 2015 FR-S
So basically if you at the starting line at a standstill, you have to release the brake, gently press the gas, press and hold the brake again, and give it gas up to whatever RPM you are aiming for. I'll just tap the gas a little which will slightly roll the car forward, immediately hold the brake down all the way, then give it gas and the RPM climbs past 2k. If I don't hold the brake down hard enough, the rear tires break loose and start spinning while the front brakes grab the front tire and hold the car still. There is a fine line between doing a burnout and brake torquing this car. Holding the RPMs at 4k while doing this seems to be the sweet spot where the car leaves quickly and not spinning it's tires too much off the line but different tires determine that for each car. |
| The Following 5 Users Say Thank You to Impureclient For This Useful Post: | FX86 (07-25-2016), johan (08-11-2016), soulreapersteve (07-23-2016), Tcoat (07-23-2016), ysu (08-12-2016) |
#21 | |
Drives: 2013 FR-S AT Argento
#22 | |
So I tried doing this a few times before coming to work (with no traffic around, ofc). I kept spinning the tires lol... Either I'm not doing it correctly or its the stock tires. Also couldn't get past 2k still. |
#23 | |
Drives: 2015 FR-S
Could be this: Press and hold the "Trac Off button" for more than 3 seconds while the vehicle is stopped, the two lights come on the dash, then try those steps again. I never have tried it without turning of traction control so maybe that was missing when it didn't work for you. It did take a couple times to get the hang of it. Make sure the car accelerator responded by watching the RPM jump a little then push the brake. If you don't get it right it will stay below 2k rpm. Either you mistimed it or the trac off has to be done beforehand. |
| The Following 2 Users Say Thank You to Impureclient For This Useful Post: | skye67 (07-27-2016), soulreapersteve (07-24-2016) |
#24 |
M>A
#25 | |
Drives: '16 Scion FR-S - Oceanic
Here ya go! http://www.ft86club.com/forums/showthread.php?t=6485 |
#26 |
Drives: Toyota 86 TRD Version AT
Go for it!!!!
#27 |
Drives: 2014 Raven FRS
I'm sure plenty of people have tracked their automatic transmission cars. Go for it and have fun doing it! That's all that matters!
#28 |
I have a 2013 automatic, pretty much stock except trd springs, swaybar set, exhaust, 16 wheels and 225/50/16 yokohama advanced neova Ad08r. I love this car for autocrossing. Done around 120 laps.
2013 FR-S, AT, Braille 15lb battery, 16x7 Wedsport SA15R w 205/55/16 Continental Extreme Contact Sport, TRD drop in airfilter, TRD spring and TRD swaybars, TRD exhaust, TRD Brake Pads,4:56gear, 2740lbs
| Using handbrake with automatic gt86 and other issues with the automatic version | Tommygt86 | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 04-06-2015 04:42 AM |
| Automatic FRS for track | Lunatic | Tracking / Autocross / HPDE / Drifting | 40 | 07-10-2014 06:14 PM |
| Automatic Transmission Cooler, necessary for autoX and Track? | BRZPDX | Engine, Exhaust, Transmission | 4 | 07-11-2013 07:13 PM |
| Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning | AZP Installs | NY / NJ / CT / PA | 11 | 08-20-2012 11:31 PM |
| Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning | AZP Installs | Tracking / Autocross / HPDE / Drifting | 0 | 08-14-2012 06:46 PM |
