Old 07-25-2016, 09:32 AM   #1
Mazikowski
Drives: 2013 GBS BRZ Limited
Not understeer, not oversteer... something else?
So, I've noticed that when cornering my car usually doesn't exactly oversteer or understeer... once grip breaks it just kind of slides sideways like it's doing both at once. It has happened on multiple sets of tires on both the autox course and the street. On the track I'm obviously pushing the car harder and on the street it typically happens when the road is just a little bit wet. My last alignment was to stock specs, but I've been meaning to have it checked and tweaked some anyway.
Has anybody else experienced this? Any recommendations on what I could do to bias the car more toward oversteer?
Mazikowski is offline   Reply With Quote
Old 07-25-2016, 09:44 AM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
That's called a 4 wheel drift. Your car is perfectly neutral through the corner and slides to the outside of the corner a bit. As long as it's slight, it's a sign that your suspension is dialed in really well.
-Josh
Old 07-25-2016, 09:45 AM   #3
Icecreamtruk
Drives: Track preped NA FRS
If what you think is happening is actually whats happening then you dont need to do anything, you have achieved perfect handling (4wheel drift at the limit). Now I really doubt that's the case considering stock alignment is a recipe for considerable understeer.
What else do you think a car can do once its past the limit of grips of your tires?
Icecreamtruk is offline   Reply With Quote
Old 07-25-2016, 10:25 AM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
When your car neither understeers or oversteers it's a condition commonly referred to as "perfect". To cure the perfect condition, start throwing random untested mods at your car. Throw on things like bigger rear wheels, changing weight distribution, slam it, mess with roll bars etc- when not prooerly implemented or tested,these are all ways to cure your car of the perfect condition and allow you to modify it to a "ruined" condition.
guybo is offline   Reply With Quote
Old 07-25-2016, 10:47 AM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Yes.
When you want more oversteer, clutch kick.
Old 07-25-2016, 10:57 AM   #6
Yoshoobaroo
TRACKBREAD
drop your tire pressure in front and raise it in the back
Old 07-25-2016, 11:01 AM   #7
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Bigger rear sway bar
Old 07-25-2016, 11:02 AM   #8
Yoshoobaroo
TRACKBREAD
Originally Posted by mav1178 View Post
Yes.
All of the above
Old 07-25-2016, 11:33 AM   #9
Racecomp Engineering
Is the car fast and are you comfortable with the handling? Do you have any in-car video? A lot of the time people think this is happening, it's actually understeering. Not saying this is the case here, but I see it often.
- Andrew
Old 07-25-2016, 12:40 PM   #10
Mazikowski
- Andrew
That could very well be the case. I have had a few times on the track where the BRZ definitely understeered and just plowed into a corner. I'm used to understeer (at least in FWD cars) being an almost all-or-nothing feeling, so I suppose if it's only minor understeer that could be why it feels more like lateral movement.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Old 07-25-2016, 12:46 PM   #11
FX86
mine does the same but it is fully stock....rather it be neutral and have the car slide evenly on all four tires rather than kicking it's tail out or plowing straight forward
Old 07-25-2016, 04:38 PM   #12
CSG Mike
CSG Mike's Avatar
If you guys can post in-car videos, I can confirm what is happening.
CSG Mike is online now   Reply With Quote
Old 07-25-2016, 06:43 PM   #13
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
OE alignment? I'd bet my bottom dollar the car is being over-driven.
ineedyourdiddly
Old 07-25-2016, 06:50 PM   #14
guybo
Huge E85 fan!
guybo's Avatar
Most of the time "plowing through a corner" is a driver problem, not a car problem. This car has been proven time and again to be very well balanced in its stock form. Yes, most cars are set up from the factory to be plow trucks, the Toyobaru is a different and unique beast.
Understeer Solutions? Sway Bars? Gopherboy6956 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 56 07-04-2019 03:49 AM
Handling Setup - Oversteer vs. Understeer DarkSunrise Tracking / Autocross / HPDE / Drifting 58 07-29-2015 09:15 AM
Do pigs understeer? Thrustin Off-Topic Lounge [WARNING: NO POLITICS] 11 05-31-2014 09:42 AM
BRZ stock suspension understeer... what to do? mtimney Tracking / Autocross / HPDE / Drifting 40 07-31-2013 12:48 PM
03/23 Reviews --> No understeer complaints... bloomy116 BRZ First-Gen (2012+) — General Topics 19 03-26-2012 11:06 AM
