CSG Mike, gramicci101, grant86, GrimmSpeed, JDLAutoDesign, JRitt, KCMachine, King Tut, MillersOilsUS, PERRIN, phastafrican, Racecomp Engineering, Raceseng, Roadcone, Sportsguy83, UltramarineLuck, VerusEric, Wonderbar, Xero-Limit
Old 07-11-2016, 01:59 PM   #1723
Pat
Pat's Avatar
Drives: 2023 BRZ
Looks like a really nice piece.
Old 07-11-2016, 02:13 PM   #1724
secret.squirrel
secret.squirrel's Avatar
Drives: GT86
Dont suppose you know if they will be offering these with resonators as an option to quieten stuff down and tone down any unwanted drone?
secret.squirrel is offline   Reply With Quote
Old 07-11-2016, 02:35 PM   #1725
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I wonder what happened to the flange welding here, lol. Should seal, but wow.
Old 07-11-2016, 03:10 PM   #1726
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Resonators are being discussed but TBD.
Pre-production part and literally the first one made; not worried about it with Grimmspeed gaskets.
FWIW I have a similar small imperfection on my JDL header flange. It adds character to a hand-welded piece.
The Following User Says Thank You to ATL BRZ For This Useful Post:
DocWalt (07-11-2016)
Old 07-11-2016, 03:29 PM   #1727
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
My luck with the Grimmspeed gaskets has been rather poor, BTW. Couldn't make them seal, I'd always get dripping flanges on a cold start.
Old 07-11-2016, 06:05 PM   #1728
secret.squirrel
Drives: GT86
... I'd always get dripping flanges ...
HA!
I'll leave now.
Old 07-12-2016, 02:59 PM   #1729
ATL BRZ
ATL BRZ's Avatar
Here's how she sounds now: fully uncorked.
[ame="https://www.youtube.com/watch?v=ZcUnKZwEXUE"]Subaru BRZ with JDL UEL header and Dezod Motorsports headerback exhaust - YouTube[/ame]
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
DocWalt (07-12-2016), Lococholo84 (07-12-2016)
Old 07-12-2016, 03:31 PM   #1730
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by G-awesome View Post
I can design something similar in CAD and get it fabricated or 3D printed. Not sure if 3D printer plastic will hold the wing in place. Last thing I was is a CF wing shearing off on the highway and hitting another car!
I do not recommend using a 3D printed adapter for this.
FYI, I was at the track a week ago and saw an S2000 with a Voltex wing that got ripped right off the car due to so much downforce. The guy mounted it with 1/4" aluminum brackets and it ripped the aluminum in half.
Granted, that wing likely produced more downforce than this SARD unit, and his car is much faster than yours, but still...mount it with something thick and metal. 3D printed plastic isn't up the job.
The Following 2 Users Say Thank You to Pat For This Useful Post:
ATL BRZ (07-12-2016), G-awesome (07-12-2016)
Old 07-12-2016, 03:34 PM   #1731
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
dayum
The Following User Says Thank You to DocWalt For This Useful Post:
Old 07-12-2016, 11:22 PM   #1732
Gliderx
Drives: 2014 BRZ Limited
Just out of curiosity, since your car is really for track duty is there a reason you didn't go single exit or no muffler?
Gliderx is offline   Reply With Quote
Old 07-13-2016, 10:45 AM   #1733
ATL BRZ
ATL BRZ's Avatar
Mostly aesthetics. I like the symmetry and the axleback section is only 16 lbs. Entire catback is only 28 lbs. It's almost 12 lbs lighter than stock.
Old 07-24-2016, 10:22 PM   #1734
quinceyc
[QUOTE=ATL BRZ;2632527]Got busy today and did some track prep.
Swapped on Cobalt XR2 race pads in all four calipers.
Installed a Grillcraft mesh grille to keep the rocks off my oil cooler.
I was able to purchase and install the Velox Motorsports brake cooling kit a little earlier than expected thanks to @VeloxEric so I can get out on track with it this weekend.
For reference since I didn't get to take any pics in my haste to install the rest after the backing plates. The rotor backing plates fit with the AP Sprint rotors and the duct shoots air into the center of the rotors and through the vanes. The stock fender liners are re installed after minor trimming.
May i ask how many steering stoppers did you use when you install velox brake cooling kits? I have the same spec of the wheels and tires set up as yours for track. Because I still have clearance issues by using 3 steering stoppers for each side. When i turn the steering wheel all the way right or left.
quinceyc is offline   Reply With Quote
Old 07-25-2016, 04:06 AM   #1735
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
He used 3 and had a decent amount of room at full lock. How tight is the duct to the fender well? If the wheel is in the air, steering geometry is quite different than on the ground. Clearance should be tested on the ground and not in the air.
I rubbed on the inner fender liner before the duct at full lock (18x9.5 with 255s), 2 spacers each side and I clear the duct with room to spare. 3 spacers should be enough for nearly all packages minus extremely aggressive ones.
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following User Says Thank You to VerusEric For This Useful Post:
ATL BRZ (07-25-2016)
Old 07-25-2016, 09:59 AM   #1736
ATL BRZ
ATL BRZ's Avatar
Key point
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 04:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 01:46 PM
