Old 07-19-2016, 12:34 AM   #15
benlaz88
Drives: 2013 Asphalt FRS
Ok thanks everyone!! Yes i forgot to mention i do have lower spring- sportline
Sent from my SM-G935V using Tapatalk
benlaz88 is offline   Reply With Quote
Old 07-19-2016, 12:35 AM   #16
benlaz88
Originally Posted by DarkSunrise View Post
I would try a different shop or different mechanic. With Whiteline camber bolts (identical to SPC), I was able to get the following alignment:
This was on stock suspension. Judging by your rear camber it looks like you're lowered around 1.5" so you should be able to get even more than that in the front, possibly closer to -1.8 degrees although every car varies. I would just ask for as much negative camber in the front as you can get evenly.
Also if you're at a shop that doesn't do specific alignments (i.e., just puts it within factory spec), it might help to tip the mechanic with money or beer. Sears is like that but I once was able to get a custom alignment by tipping the mechanic a $20.
Did u put ur camber bolt on the bottom slot?
Old 07-19-2016, 06:40 PM   #17
DarkSunrise
DarkSunrise's Avatar
No top slot with tab facing the strut, like this:
2022 BRZ Build
2013 FR-S Build
Old 07-19-2016, 09:57 PM   #18
benlaz88
Oh ok. The instruction said bottom. Interesting....
Old 07-22-2016, 05:42 AM   #19
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
1) Whats the part number?
2) lifetime alignements usually mean you have to take it back multiple times for them to get it right (I know I do). Try aday theh are normally slow so they dont rush it. I persoannly use it only to get my toe in line from time to time and pay a good shop when I have specs I want to hit
Old 07-22-2016, 09:54 AM   #20
Wyattkb
Drives: 2014 Whiteout FRS
Network Alignment on the west side of town did my alignment. They work with fully built race cars all the time and will get it to whatever specs you provide, given you have the correct parts to achieve said specs.
Then you have like 60 days if you think something is not to your specs for them to throw it on the rack again free of charge.
Also I have my camber bolts in the same top slot.
Wyattkb is offline   Reply With Quote
Old 07-22-2016, 07:44 PM   #21
benlaz88
Part # 81305 the SPC bolt
Old 07-22-2016, 08:14 PM   #22
finch1750
finch1750's Avatar
that belongs in the bottom hole
Old 07-22-2016, 08:58 PM   #23
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
The idea is to shift the upper hole inward toward the body and/or shift the lower hole outwards to create more of an angle.
Intent > Content
Old 07-24-2016, 03:12 PM   #24
ChrisSC300
Drives: 2014 SWP BRZ
I have the same Bolts and installed mine in the bottom like the instructions said. I got -1.5 on each side. Have another shop do the alignment and let them know you want max negative camber. They will look at you funny but will do it if thats what you want.
I would recommend following the instructions on bolt placement. Different part numbers have different instructions. The top and bottom bolts are different sizes. Also the position of the "lobe" for camber adjustment is opposite if you put them on top.
ChrisSC300 is offline   Reply With Quote
Old 07-27-2016, 02:38 PM   #25
benlaz88
I went to the different shop, they said they not able to get the camber more than -.08 in the front. Did i installed the bolt wrong?
Old 07-27-2016, 04:36 PM   #26
Calum
That Guy
Drives: 2013 asphalt FRS MT
Shows us a pick of your install.
I hope to god you didn't pay for that.
Old 07-27-2016, 04:40 PM   #27
benlaz88
Ok i will take a pic later this week. No he didnt charge me for it
Old 07-27-2016, 07:27 PM   #28
renfield90
The Stig's German cousin
-.08? For real? Or was it -0.8?
Which shop did you go to? Hard to install this wrong.
I've posted elsewhere but a lot of places will look at their database, see "front camber not adjustable," and tell you that they won't adjust camber (honest places) or make up a story about how they tried and couldn't get more than X camber (dishonest places).
In particular if you went to one of the places in the thread I posted, and they didn't bother to get you any camber, I'd like to know about it to warn others.
If you're using the SPC bolt there is no reason you shouldn't be over -1.0 at a bare minimum, unless you got oddball hardware from the factory. I'd also like to see pics.
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
FT-86 Club EXCLUSIVE. SPC Front and Rear Camber Kit SPCPerformance Brakes, Suspension, Chassis 2 04-10-2014 12:00 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
