Rear and front camber opinion.
I just had my alignment done. Its seem like my front camber did not change. I had the spc camber bolt in the front on the bottom hole. Its this number look ok?. I was hoping -1.4 up front. Any though would be great! Thanks
Sent from my SM-G935V using Tapatalk |
Your shop didn't adjust them, take it back or find another shop.
Ideally this issue should have been raised before you took your car back. |
You need to tell the tech what your goal is. If you want -1.4, tell them to try and hit it.
Personally, if you just have camber bolts up front, I'd tell them to aim for as much as they can get up front to gain more negative front than you have rear. (Even though.) Do you have any other mods, or just camber bolts? |
Alright, then my suggestion would be to hit around -2.5 if they can, and when you have components to dial back the camber in the rear a bit, you can play with the fronts more.
Also, zero toe. |
Ok thank you!
I would try a different shop or different mechanic. With Whiteline camber bolts (identical to SPC), I was able to get the following alignment:
Also if you're at a shop that doesn't do specific alignments (i.e., just puts it within factory spec), it might help to tip the mechanic with money or beer. Sears is like that but I once was able to get a custom alignment by tipping the mechanic a $20. |
+1 on finding another shop. In Tempe/Phoenix you should be able to find a shop that specializes in Subarus and does performance oriented alignments that knows this platform very well.
Latest alignment discussion: http://www.azsolo.com/forums/index.php?showtopic=14487
All the recommended places will do a custom alignment for you. |
If you're lowered with camber bolts and that's it, I would max my camber myself and then take to a shop to have them set the toe.
| All times are GMT -4. The time now is 11:53 AM. |
User Alert System provided by
