Old 07-16-2016, 11:44 PM   #113
Olomana
Drives: Audi RS Q3 & Renault Clio 3 RS
Hello Guys,
I might be on the market for a 2017 BRZ/86.
Sadly they are both only on order and can't test drive one.
Lot of review talk about power issue ( not enough ).
I currently drive an Clio 3 RS 197HP/1250kg and I am pretty happy with it.
adding "easy 30whp" with bolt on and tune, HOW the car feels?
30whp seems a lot for bolt on a n/a car and should make the car more responsive?
Not looking to have a 0-60 car, but must be king on the twisty road
Thanks
Olomana is offline   Reply With Quote
Old 07-16-2016, 11:46 PM   #114
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Originally Posted by Olomana View Post
Hello Guys,
Thanks
Not sure exactly what you are asking. Test drive a 2016 in the lot my friend itll be the same car IMO.
tofurun is offline   Reply With Quote
The Following User Says Thank You to tofurun For This Useful Post:
BabaYaga (07-17-2016)
Old 07-17-2016, 01:06 AM   #115
Olomana
Adding 30whp to the car, that is make it make a huge difference?
I heard because of emissions regulations there are lot of restrictions.
People who did full bolt on tune, still unhappy after?
There is no BRZ/86 at dealer, so can't even test drive one.
Old 07-17-2016, 01:53 PM   #116
tofurun
tofurun's Avatar
I am going to see how much power I can make NA before going FI. There are many people on here that stay stock/ do full bolt on/ and go FI and each will tell you what they are happy with. I dont think there is a way to tell you what will make the car fit you because everyone is different with their own opinions. Just depends on what you are looking for. Like everyone on here told me before I bought the car. "Drive the car first and see what fits you"
Old 07-17-2016, 09:25 PM   #117
Olomana
I guess I will have to put one on order and see by myself
Thanks
Old 07-24-2016, 08:14 AM   #118
RPezza12
Drives: 13 Scion FR-S
For sale
I have a Greddy intake and axel back exhaust for sale if anyone is interested.
RPezza12 is offline   Reply With Quote
Old 07-25-2016, 01:24 PM   #119
EffaressNOOB
EffaressNOOB's Avatar
Drives: Halo 2016 Scion FR-S, 6MT
Here's the order of my mods and what I felt after install:
1: K&N Drop in filter:
Throttle response and top end HP was noticeable. I was surprised! Sounded throaty too!
2: OFH/OFT UEL Stage 2 93 OCT
Same opinion as most people. Ride quality greatly improved, especially during idle and low to mid range RPMs. TQ dip was only noticeable when I had a fat body in the passenger seat. I actually thought the car was a bit slower in the top end, but no real significant power gains with my butt dyno.
3: Invidia N1 CatBack:
Got loud and drony, but I got used to it. No real power gains.
4: OFT Stage 2 E85:
Yup. I got lucky and found a gas station that is right between home and work! Once I let the ECU learn for an hour, I went WOT and felt a SIGNIFICANT increase in both HP and TQ! I am still on my first fill up and I've been bookin' it everywhere I go! No more dropping 2 gears to pass (I spun out, which told me I need stickier tires). I can't wait to fill up again, let the ECU learn...again, and change the oil to an E85 friendlier oil. 5W30ish?
Needless to say, I'm going to stick with N/A for now. I'm not too sure how long it's going to take for me wanting to go faster with FI, but I'm very happy! Still looking to maybe go CAI, or just an intake tube. Any suggestions on intakes????
EffaressNOOB is offline   Reply With Quote
Old 07-25-2016, 06:02 PM   #120
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
4: OFT Stage 2 E85:
Oil weight has nothing to do with being E85 friendly. You can get 0/5w20 oils for E85. You do need to change it twice as often though.
The Following 2 Users Say Thank You to Wayno For This Useful Post:
ragequitfail (07-27-2016), Teseo (08-07-2016)
Old 08-20-2016, 03:21 AM   #121
goonz_maroon
goonz_maroon's Avatar
Drives: 2015 Scion FR-S
Hello new to exhaust mods. I would like to keep my headers stock. Looking to purchase a Perrin 2.5" resonated CBE. My question is will installing a high flow catted front pipe help increase the loudness while preventing rasp. Also will this effect my emissions during inspections or give me any CEL?
Sent from my SM-N910W8 using Tapatalk
goonz_maroon is offline   Reply With Quote
Old 08-21-2016, 08:00 PM   #122
tofurun
tofurun's Avatar
Anyone have the torque specs for the O2 sensors??
Old 08-22-2016, 10:06 PM   #123
tofurun
tofurun's Avatar
After looking far and wide nobody has posted a definite torque spec for our O2 sensors. So after much looking here is my find. I came to this conclusion by searching o2 sensors for our cars. Then I found NGK's line of oxygen sensors. They listed the o2 sensor as fitting our car and a few other subaru's including a saab LOLOL. but The torque spec for the subaru impreza is 22.1 . So spark plugs are to be torque according to the spark plug itself not car specific is my understanding. So if this plug is an oem replacement then it should be 22.1 on that ej making it 22.1 on our FA..... life is hard
Torque = 22.1 ft-lb. Apply anti-seize SS-30 by JET-LUBE
chaoskaze (08-22-2016)
Old 08-23-2016, 05:26 AM   #124
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
DO NOT get the anti-seize on the tip.
guybo is offline   Reply With Quote
Old 08-23-2016, 06:58 AM   #125
steve99
Drives: FT86
As per the first post in this thread, you will get little or no power gaind from a Cat back.
Perrin catback 2.5 resonated will sound nice with rest of exhaust stock and wont be too loud.
If you swap out the stock front pipe for a metallic high flow cat front pipe, expect a considerable increase in volume and likely some rasp and drone. Its probably not going to be too bad with stock header, you might gain a little power
but if you ever change out the header for catless, then that setup with high flow front pipe and perrin cbe will be quite loud and raspy.
Putting the stock front pipe in will tame it down a lot with catless header.
If you keep stock header you wont throw a CEL.
Im not sure how strict smog tests, visual inspections are but you should pass with stock header and hi-flow cat, except California I suppose.
goonz_maroon (08-23-2016)
Old 08-23-2016, 07:01 AM   #126
goonz_maroon
Thanks steve99. Are there any suggestions on what type of front pipe I can use to increase volume without creating any rasp or drone?
Useful/Frequent mods: a BRZ/FRS/GT-86 basic ! Simon99 BRZ First-Gen (2012+) — General Topics 104 10-10-2016 12:45 PM
What mods next? Exhaust? Intake? Ludacrits Scion FR-S / Toyota 86 GT86 General Forum 7 09-05-2013 08:25 PM
Question about basic performance mods bdanisi Engine, Exhaust, Transmission 2 01-25-2013 05:40 PM
