Old 07-08-2016, 10:12 AM   #267
HuntingtonFRS
Drives: 2013 Scion FR-S in White
What about running a flex fuel kit?
HuntingtonFRS is offline   Reply With Quote
Old 07-08-2016, 10:17 AM   #268
Torry@HKSUSA
Torry@HKSUSA's Avatar
Drives: HKS
There is no out of the box solution for running flex fuel. You would need to run a pump and injectors that can hold up to E85 but you would need a custom tune, as well as an Ethanol sensor and a tuning solution that can adjust based on ethanol content.
It's not something HKS supports, nor do we have plans to support.
Torry@HKSUSA is offline   Reply With Quote
Old 07-08-2016, 10:25 AM   #269
Timmy_Jones
Spun
Drives: 23' Supra
Originally Posted by zeal86 View Post
These are my hood vents...
__________________________________________
projekt zeal86 build
Any plans to re-install the grill, over those radiators??
Timmy_Jones is offline   Reply With Quote
Old 07-08-2016, 10:46 AM   #270
zeal86
zeal86's Avatar
Drives:
I don't plan on installing any sort of grille... I know there is definitely a chance for damage... but since my 86 is not a daily driver there will be less instances where my front deck will be in jeopardy of being damaged...plus, I keep my distance from other drivers.
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
CxG (07-09-2016), Kris86 (09-08-2016)
Old 07-08-2016, 07:15 PM   #271
WRX4ME
Drives: 2016 BRZ HyperBlue, 2015 WRX Red
http://www.superstreetonline.com/how...arger-upgrade/
Interesting article that touches on the differences between the V1 & V3 kits.
WRX4ME is offline   Reply With Quote
The Following 2 Users Say Thank You to WRX4ME For This Useful Post:
HuntingtonFRS (07-09-2016), zeal86 (07-08-2016)
Old 07-15-2016, 02:39 PM   #272
blindfold
Drives: brz
Very insight full article.
It is also very interesting here in the Asian market, version 2 looks like version 3 that's been released in the US and were also told only version 1's compressor pulley is removable. There is also an injector kit bundle that comes in with bigger(2mm) restrictor plate, my parts will arrive soon and I will try to update it here too.
Since superstreet's Hks kit is pieced together from version one, can anyone confirm the pulley is upgradable on the new version complete kit. Thanks
blindfold is offline   Reply With Quote
Old 07-15-2016, 02:45 PM   #273
Torry@HKSUSA
Drives: HKS
Yes, the V3 kit pulley is upgradeable.
Old 07-15-2016, 03:43 PM   #274
Apex-Apex
Apex-Apex's Avatar
Just started my install on my HKS V3 with upgraded pulley and I have to say the instructions are not the best. I had a HKS V-Mount for my RX-7 and the instructions on that is much better. However, if you read the entire instruction and you have an idea what you're doing, you can number the steps yourself to avoid taking off and putting back on parts. Overall the kit fits pretty well but the fitment gets VERY close with the Koyo radiator in there. This causes the AC condenser to get very close to the IC. I also mounted my SC cooler a different than factory from HKS since I had to mount my oil cooler in a similar area.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
The Following 2 Users Say Thank You to Apex-Apex For This Useful Post:
Kris86 (09-08-2016), zeal86 (07-15-2016)
Old 07-15-2016, 06:15 PM   #275
HuntingtonFRS
The upgraded pulley, does it require other mods such as injectors?
Old 07-15-2016, 06:59 PM   #276
Apex-Apex
Apex-Apex's Avatar
Yes, if you run their e85 tune, you will need Deathswerke 700cc.
IG: @apexapexapex
Old 07-15-2016, 07:09 PM   #277
zeal86
zeal86's Avatar
Drives:
Same here... except my AC condenser is basically up against my radiator. I've blocked of the top, bottom, and sides of my radiator with foam... I'll be looking into building a shroud this weekend in order to get as much air flow through the radiator as possible.
Old 07-15-2016, 07:21 PM   #278
Apex-Apex
Apex-Apex's Avatar
Yup, mine gets right up against my radiator also. I'll probably be spacing my radiator back more since I have room.
IG: @apexapexapex
Old 07-15-2016, 07:29 PM   #279
HuntingtonFRS
Ok. That's what I thought. Just didn't know you went that far with it. That's awesome. Big jump from stock. I was really happy with the kit on 93 octane after being stock. Enjoy it!
Old 07-15-2016, 07:41 PM   #280
Apex-Apex
Apex-Apex's Avatar
Thanks! Hopefully it'll feel close to my RX-7. It's been a while since I've had power.
IG: @apexapexapex
supercharger help... sosick Forced Induction 25 08-16-2013 12:02 AM
HKS GT Supercharger Evasive Motorsports Forced Induction 48 02-08-2013 07:21 PM
ETA on TRD Supercharger? frsinpa Forced Induction 18 01-11-2013 11:09 AM
supercharger? but by who? carbonBLUE Forced Induction 14 11-02-2012 11:10 PM
HKS GT Supercharger Kit BPAuto Forced Induction 18 10-27-2012 04:11 PM
