Drives: 2013 Raven FR-S
Jelly in brake fluid
While I was installing new brake pads the other day I noticed a jelly like substance in the brake fluid reservoir. Anybody know what this is about? I'm using Motul RBF600 right now, but had the stock fluid before. This Motul fluid is around 9 months old and has been used mostly for street and AutoX. I've never seen this before, so any feedback would be appreciated.
#2 |
way overfilled. Don't know if that contributed.
#3 |
| The Following User Says Thank You to smg1138 For This Useful Post: | Ultramaroon (07-14-2016) |
#4 |
The only time I've seen gelatinous accumulation was the result of leaving E85 sit in a fuel system not designed for it. Is it possible ethanol got in there somehow?
#5 |
Since the weather got warm I've been using E85 most of the time. But, how would that affect the brake fluid? Doesn't seem like it could be related.
#6 |
It won't be unless somehow your brake fluid was contaminated with it. Do you see any contamination down in your reservoir, or is it just in your fill strainer?
#7 |
Drives: Not an FRS, but same initials.
I've seen something like this happen when someone mixed dot 5 which is silicone based and dot 5.1 or dot 4 which is glycol based.
Not sure what the car comes with, but if you added the wrong fluid be ready to flush the whole system. Sent from my iPhone using Tapatalk |
#8 | |
#9 |
I've never used DOT 5 brake fluid in this car. I believe the stock brake fluid is DOT 3 and the Motul fluid is DOT 4. To my knowlege, DOT 3, 4 and 5.1 are all compatible, correct?
#10 | |
| The Following User Says Thank You to CCJ For This Useful Post: | Shankenstein (07-15-2016) |
#11 |
Frosty Carrot
Drives: The Atomic Carrot
As CCJ's link states, DOT4 will more readily absorb water and other contaminants than DOT3 (which is probably what our cars came with). Also, it's worth noting that most tech sheets for brake fluids (like Valvoline, Castrol, ATE, Motul, etc) recommend that you are careful to avoid mixing different fluids. The chemical differences between DOT3, 4, and 5.1 won't make them immiscible, but if you are tracking the car... the weakest fluid will degrade first.
I wouldn't worry about it too much. Scoop the goo, pull the fluid from the reservoir using a turkey baster or similar syringe, then thoroughly flush the system. If you have access to a powerful vacuum bleeder, I'm guessing that it would help move any gelled fluid stuck in the system. Racing brake fluid is only intended to be in the system for a year or two... so if you're an infrequent racer (like me), it's best to flush the system for the first big event of each season. Also, if you're car is seeing cold weather (significantly below freezing), it can cause gelling. Usually the viscosity returns to normal, but some chemicals separate and misbehave at very low temperatures. My company uses plenty of epoxies and industrial coatings, and some have warnings "Throw away if it sees freezing temperatures." because of the separation issues cause permanent changes that lead to clogged dispense nozzles or inconsistent curing.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
| The Following User Says Thank You to Shankenstein For This Useful Post: | smg1138 (07-15-2016) |
#12 |
The Stig's German cousin
It's caught by your screen filter. It could just be dirt or something that's jelled up. If the fluid deeper inside is jelly-free I wouldn't worry.
| The Following User Says Thank You to renfield90 For This Useful Post: | smg1138 (07-15-2016) |
#13 |
#14 |
Just wanted to post an update on this. I flushed the Motul RBF600 and replaced it with Castrol SRF. The jelly appears to have completely gone away now. Still have no idea what caused the Motul to do that.
| The Following 4 Users Say Thank You to smg1138 For This Useful Post: |
| Brake Fluid Question... | Lebby83 | Tracking / Autocross / HPDE / Drifting | 2 | 11-02-2015 10:15 AM |
| Brake Fluid Question... | Lebby83 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 11-02-2015 09:01 AM |
| Brake Fluid Flush | protpibe | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 01-02-2014 02:19 PM |
| Swapping brake fluid | barabia | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 08-12-2013 09:58 PM |
| Track Day Brake Fluid | Skorov | AUSTRALIA | 2 | 11-11-2012 07:10 PM |
