Old 07-15-2016, 02:51 AM   #29
PresiO.
Drives: 2013 Scion Fr-s
Originally Posted by radroach View Post
something like a kickstand or something, I'm sayin..
Or a damper..
Lol I can see it now... *Opens door* *unfolds door kick stand* gets out of car.... *folds kickstand back up* *closes door*
I like my usual open door jump out before the door slams on me... it makes me keep my agility up.
PresiO. is offline   Reply With Quote
The Following User Says Thank You to PresiO. For This Useful Post:
radroach (07-15-2016)
Old 07-15-2016, 03:12 AM   #30
Mr Nerd
Mr Nerd's Avatar
I'm so glad I found this thread. Gonna start using my shin to stop the door from this day forward!
Mr Nerd is offline   Reply With Quote
Old 07-18-2016, 09:10 AM   #31
Da Brz
Drives: 2016 Subaru BRZ
@radroach ........ you're about to beat this puppy to death.......
When on "level ground" the doors will stay open ....... just because you can't find any "level ground" in Tennessee ....... ain't the car's fault ......
I swear my parking spot at work is level as you can get. Door shuts. And it doesn't just barely shut, no, it shuts hard enough to shut all the way.
Da Brz is offline   Reply With Quote
Old 07-18-2016, 01:57 PM   #32
saj
saj's Avatar
Drives: ̶1̶0̶ ̶S̶
You can always recognize 86 drivers by looking at their shins.
saj is offline   Reply With Quote
Old 07-18-2016, 03:30 PM   #33
Well, @radroach is from Tennessee and you are in Arkansas.
Sometimes, it ain't all that easy to figure slope, in the hill country, ...... especially if one leg is shorter than the other......
http://www.roadsideamerica.com/tip/53
Now, if you park your car in one direction and the door closes and you park your car in the other direction ...... and the door closes ....... you may be on to a new "Mystery Spot".
Old 07-18-2016, 03:40 PM   #34
PresiO.
Im glad everyone enjoyed this thread. This door dilemma has been on my mind for awhile now
Old 07-18-2016, 03:59 PM   #35
iamjacob
insert witty quip here
Drives: 2016 Limited BRZ
I have never noticed the doors closing on me. I must have got the super special sticky-door edition, either that or I know how to use a car door?
iamjacob is offline   Reply With Quote
Old 07-18-2016, 04:37 PM   #36
Well, now, PresiO, have you checked out post #3 ...... ??
When you open and close your car door, do you feel it slip into the notches built into the door closer hinge.
If not, it is either lose, broken or worn out.
Old 07-18-2016, 04:39 PM   #37
You couldn't understand ....... Stockton is flat ......
Old 07-18-2016, 04:59 PM   #38
iamjacob
Fair enough. I only reverse up the driveway so I may have just never noticed what everyone else is experiencing.
Old 07-18-2016, 05:45 PM   #39
PresiO.
I even will hold it there for a few seconds and make sure it gets into the notches and about 5 seconds later.... WHAM.....
I would say its probably just worn out but its been like this since I got the car almost 4 years ago.
but its progressively gotten worse so I'm guessing it was a problem that got even worse as time went by.
Old 07-18-2016, 06:48 PM   #40
I just checked mine again and it takes quite a bit of effort to push the door out of the notches.
You may wish to purchase a couple new closers.
They shouldn't be that expensive. (ya right....).
They look to be easy to replace ....... after you get the door apart .....
OR, the one beer humfrz redneck fix: ...... twist the closer arm with a pair of channel locks to deform it. ........
PresiO. (07-19-2016)
Old 07-18-2016, 06:54 PM   #41
Yep, "combat parking" ........ I've done that ...... when I'm someplace I'm not supposed to be .......
iamjacob (07-18-2016)
Old 07-18-2016, 07:46 PM   #42
They're plastic.
Door Open Switch Raz BRZ First-Gen (2012+) — General Topics 7 04-10-2022 05:07 PM
Door open light rosol16 Issues | Warranty | Recalls / TSB 6 11-22-2015 12:42 PM
Door wont stay open cregor Issues | Warranty | Recalls / TSB 21 06-11-2013 11:43 PM
Door Open Buzzer cmspooner Cosmetic Modification (Interior/Exterior/Lighting) 5 08-13-2012 10:20 AM
