#4075 | |
Senior Misanthrope
#4076 | |
That's the closest combo, but ideally you want front and rear pads to be the same. Did you purchase brzaapi's kit? |
| The Following User Says Thank You to CSG Mike For This Useful Post: | kch (07-12-2016) |
#4077 |
Senior Misanthrope
Yep, brzaapi's kit. Haven't pedal danced in the past (just 3sec TC hold), but will next time.
#4078 |
Drives: 2014 BRZ Sport-tech
This is more of a theoretical question but figured I'll ask here since it's been bugging me for a while.
If you're taking a corner in isolation (no worries about what happens before or after), is it faster to take it with a slight understeer or slight oversteer? Assuming the driving is perfect and the you can adjust damper settings to induce the desired behaviour in the car. Looking to understand the best way to maximize the available grip in the tires. |
#4079 |
Drives: '22 BRZ
Ideally you don't want understeer or oversteer. Realistically, line choice and driving style contribute a lot.
edit: figured I'd clarify. The ideal car is one that never slides at the front or rear (ignoring slip angle and all of that fun stuff) but the driver's comfort plays in. Is the driver smooth enough to make a car that's 100% neutral work? Is the driver more comfortable with understeer or oversteer? A small line choice change can compensate for most car behaviors and if the driver is more comfortable they will be faster. Pro drivers are as fast as they are because they can very quickly adapt to a car by changing their cornering a little bit ir tweaking the car to their liking. It's really interesting to have two people drive the same car and see how differently they approach the goal of going fast. I recently shared my car with a friend of mine that normally drives much faster cars and it was very revealing how differently we drive, some of it habit from different cars, some of it purely preference.
| The Following 5 Users Say Thank You to DocWalt For This Useful Post: | infinity21 (07-13-2016), ka-t_240 (07-13-2016), Racecomp Engineering (07-13-2016), strat61caster (07-13-2016), Uplink (07-27-2016) |
#4080 | |
Assuming it's a perfect 90 degree bend, for the highest average speed through the corner, slight oversteer. However, using the damper to induce the desired behavior means you're reducing grip to get that desired behavior. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | CxG (07-13-2016), infinity21 (07-13-2016) |
#4081 | |
Oversteer is always faster, in a theoretical context. In a real world context, you have to be able to manage it, and most drivers will be faster with an understeery car, because they fear oversteer, and avoid it, instead of seeking to exploit it. |
| The Following 5 Users Say Thank You to CSG Mike For This Useful Post: | DocWalt (07-13-2016), infinity21 (07-13-2016), Lynxis (07-13-2016), strat61caster (07-13-2016), Uplink (07-27-2016) |
#4082 |
Drives: '22 BRZ
I was trying to avoid the purely theoretical context for a reason
It is definitely worth thinking about and knowing that a truly neutral car is slower than a car with slight oversteer, so hurray physics.Mathematically neutral and real world neutral are two different things, in my experience. For example, I consider my BRZ neutral, but everybody that's ridden with me comments on how "active" (aka tail happy) I like my car to be. Someone that prefers that little bit of understeer is likely driving a car that's actually mathematically neutral
| The Following User Says Thank You to DocWalt For This Useful Post: | infinity21 (07-13-2016) |
#4083 | |
![]() If you can't spin your rear tires at a given speed, then you want a looser car. If you can spin your tires at a given speed, then you want to make sure you know which way the rear will go when they spin. Neutral is relative, but loose is fast. |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#4084 |
Thanks for the input guys. I feel pretty comfortable with slight understeer (as with many others) but wanted to explore the other side of slip angles to see if it's worth mastering. My bouts with oversteer is one that aims to immediately correct it. I have no reservations going WOT out of corners and applying corrective steering as necessary but I'm not very good at sustaining slight oversteer so it's something I will work towards in future track days
![]() Back to real life, I currently run RCE T2 which slightly understeers with 400/400 springs (at least that's my perception of the car's behaviour). Would it be faster to get the car to oversteer through appropriate brake/throttle/steering application or should I just stick to what I'm doing until I get stiffer springs in the rear? Perhaps the first step is to approach the apex smoothly and try to oversteer out of the corner? A good example of my current driving style can be seen in the last minute or so of this video [ame="https://www.youtube.com/watch?v=PSI--VO6oZY"]2016-06-11 SPDA DDT lapping - YouTube[/ame] |
#4085 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | infinity21 (07-13-2016) |
#4086 |
JHerbert Racing
Drives: 2013 Scion FRS
I am looking to change the pads in my almost track only car. (I drive to some car shows and to the track only.) I want to go with the Hawk DTC-60 pads. I hear rumors of blank rotors being 100% good to track with. Is this true? or is slotted the way to go? My car is NA with DOT slicks.
#4087 | |
They are fine, I've ran a couple sets of HP+ and DTC60s on my car, no interest in spending more than amazon prime pricing on rotors. ***Just Remember the DTC 60 dust is corrosive and a bitch to get off after it gets wet and then hot again. |
#4088 |
Drives: '17 Camaro SS 1LE
Hi guys,
Question about wheel hub rings on track. I've read and was told mixed things from seemingly credible sources about whether or not to use them. On track, I'm running 17x9 Enkei RPF1 wheels w/ RE71R tires. From what I'm gathering for the BRZ on the forums - the wheels are centered by the lugs since they're conical, and after proper star-pattern torquing, there is no load on the studs/lugs. My alignment/race shop and a customer of theirs this weekend claimed metal (aluminum?) hub rings are very much recommended because they've seen broken studs when not used. I tend to trust them because they have several years of track experience and STI/BRZ specific setups but I'm a sitting duck on this one. What gives? FYI - I also run the RCE T2 400/400 with their out of the box recommended settings for damper clicks and I wouldn't say it understeers at all on track. It could very well likely be your alignment setup; what are your alignment specs? |
| The Following User Says Thank You to Yanbags For This Useful Post: | Racecomp Engineering (07-25-2016) |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
