Old 06-18-2012, 09:06 PM   #127
Getagrip
Getagrip's Avatar
Drives: SWP BRZ
This past Saturday I took my BRZ out for its first autocross. I consider myself a seasoned driver as I have been autocrossing since 1996. I’ve driven mostly Subaru AWD cars in stock or lightly modded ST classings.
The car is set up with 245/40-17 StarSpecs on 17x8 +48 Rota G-Force. I have not checked or messed with alignment yet.
The pavement does not get all that warm here so I started with about 32 PSI and ended up with 30 front and 29 rear.
The car did push some going into turns but was easy to rotate from mid-way through to the end.
I’d like to get a little more front bite without making the rear too twitchy.
I finished 3rd in PAX with 30 or so drivers.
Sorry for the quality on the left side, I found a smudge on the lense.
Here is my best run.
And my best run, although dirty.
Just realized this is a stock class thread, oh well the car is basically stock.
SWP BRZ
Getagrip is offline   Reply With Quote
Old 06-21-2012, 08:18 AM   #128
AX_FRS
Drives: 05 Ford Focus ZX4
The July Fastrack is out and it says CS for FRS and BRZ. I thought it interesting they didn't place it in any ST class though.
AX_FRS is offline   Reply With Quote
Old 06-21-2012, 09:07 AM   #129
Mitch
form follows function
Drives: RIP '13 BRZ
Last week I pre-registered for an autocross in CS. Glad I don't have to change! Curious on the lack of noise about ST. Where do most CS cars end up when they transition to ST_?
Mitch is offline   Reply With Quote
Old 06-21-2012, 09:44 AM   #130
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Rx-8 stx solstice/miatas str 350z/370z not classed
Sccabrz192 is offline   Reply With Quote
Old 06-21-2012, 11:33 AM   #131
FTD
Drives: 2002 WRX
Originally Posted by dwx View Post
I guess the stock wheels are +48 not 42. The section width of a 225/45/17 star spec is 8.9" on a 7.5" rim. A 245/40/17 A6 is 10" but measured on a 9" rim... My guess is on a +50 rim it isn't going to fit without a spacer, with more camber.
I tried running larger diameter tires on my old SM WRX to get some more out of 2nd gear and I hated it and it didn't keep me from having to shift into 3rd most of the time. I used to autox in milwaukee which has a large lot with fast courses. Now I'm in Atlanta where things are tighter and slower.
Phil, what didn't you like about the 245's?
From my testing on 17"x7" wheels the main difference between the 225/40's and 245/40's was the 'feel'. The 245's were more spongy and slower to react, but run times were on par. The MX-5 isn't gear challenged so sticking with the 225/40 was an easy choice (63.5mph in 2nd). On a gear challenged car such as this I would try to make the 245's work. Another upside for the 245's is they will last longer before cording/wearing out.
FTD is offline   Reply With Quote
Old 06-21-2012, 05:51 PM   #132
AX_FRS
It looks like the 350z is classed in STR (though it makes me wonder if only the roadsters run in that?)
I don't think a car can compete nationally in a ST class unless they are specifically classed in the rules, and I know there are people on this site that would like to do just that and have been pushing to get it classed. That's why I was confused as to why they chose a Stock class and not an ST class, aditionally.
Thinking about it though, most of the modifications that are allowed for ST class have yet to be released for the cars and so SCCA really has no way to judge (aside from pulling it out of the air) just how effective the car will be after modifications.
Old 06-21-2012, 06:02 PM   #133
xwd
I think there was some context missing in what I was saying. Another poster had talked about running 245/45. I believe 245/40 will be best tire for the BRZ in CS.
I tried 275/45 on the SM car and I didn't like it.
Old 06-25-2012, 10:39 AM   #134
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Just another quick update from this past weekend. I decided to try a revised rear alignment AND the Cusco 20mm front sway bar.
Quick shout out to Circuit Motorsports who got me the bar on Friday with some quick service - very professional and reasonable shipping, considering.
I went from ~0.14 deg. toe-in to ~0.25 deg toe-in on each side in the rear. The bar went on with no issues. I felt the car drove more to my liking. I improved against the few folks that I've now run against more than once and PAX'ed well against a very small field, but that could just as easily be driving improvement. At this point, I've got no more changes planned and will just work on driving it better!
Video (sorry for the nasty audio) of my best run of the day here.
jdrxb9 is offline   Reply With Quote
Old 06-25-2012, 03:59 PM   #135
EMguy
A couple quick notes from this weekend in a BRZ:
1) A 245/40/17 A6 fits with room to spare on a +42 17x7. If Hoosier made a 255/40/17, I wouldnt be afraid to try that.
2) The same set of 245s (brand new, wrapped in storage totes) fits in the back seat area with room for a driver, passenger, and as much stuff as you can cram in the trunk.
3) The car is wonderfully balanced stock and tends toward the loose side of neutral, especially in quicker transitional elements. Sweepers are blissful. Slaloms could be improved, but are great for a stock car.
4) OEM crash bolts and a front bar will be magical. (I think)
EMguy is offline   Reply With Quote
The Following 2 Users Say Thank You to EMguy For This Useful Post:
Scooby South (06-26-2012), simpleisbest (07-11-2012)
Old 06-26-2012, 11:00 AM   #136
xwd
Good to know on the storage! Did you fold the seats down to get them in there?
Old 06-26-2012, 02:23 PM   #137
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
So this is a good read. While the zok and the msr are being moved. The mrs suspension and what not was also sold as a street package and those are not being moved. http://www.sccaforums.com/Forums/tab...s/Default.aspx
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 06-26-2012, 02:40 PM   #138
ubersoph
I think you are referring to the Z0K package/Street edition solstice. Chances are good that it will get moved anyway if someone writes a letter.
ubersoph is offline   Reply With Quote
Old 06-27-2012, 01:56 PM   #139
UncleFester
Good thread.
I too experienced the loose rear-end this past weekend. I really had to watch throttling through and exiting turns. I got confident on my third run though and actually spun it.
My alignment was -2.2 front and -.8 rear. Zero toe all the way around.
Looks like I'll be trying .25 toe-in on the rear and perhaps a front bar next event.
I too have been looking for some of the wheels you guys have discussed. However it seems everything won't be available for months, which would be past the vast majority of the racing season. Perhaps I should hold off and get some Street Touring spec wheels over the winter as I don't see myself staying in stock class next year.
UncleFester is offline   Reply With Quote
Old 07-06-2012, 11:54 AM   #140
simpleisbest
Senior Citizen
Drives: Scion FR-S
Does anyone know if there is a hollow front sway available yet? If so, please post a link.
Thanks!
simpleisbest is offline   Reply With Quote
Which autocross class? jpdarty7 Tracking / Autocross / HPDE / Drifting 66 06-21-2012 05:53 PM
FORMULA D Round 1 Long Beach 2012 Discussion Thread Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 0 04-08-2012 02:43 AM
GT5 Stock GT86 Competition - March 2012 Deslock Off-Topic Lounge [WARNING: NO POLITICS] 34 04-01-2012 07:39 AM
2012 Mercedes A-Class Revealed ZetaVI Other Vehicles & General Automotive Discussions 12 03-06-2012 02:15 PM
GT5 Stock GT86 Competition - February 2012 Deslock Scion FR-S / Toyota 86 GT86 General Forum 100 03-01-2012 07:14 AM
