Old 07-12-2016, 04:56 PM   #29
Scikotic
Scikotic's Avatar
Drives: 2014 FR-S Silver
So I had a mechanic from the shop that installed the clutch take a ride with me today. Of course at first I could not get the car to buck at all. No matter what rpm or throttle position clutch let off. finally after about 7 stop signs it did it about half as bad as this past weekend. His eyes got wide open and he had a confused look. I was then able to recreate it about 5 times, but of course less severe than it has been. He then said there were 2 things I could do....
1) Contact Competition clutch and try to get them to warranty it out and he would talk to the shop manager about discounted services to have it R&R'd
2) Its an aggressive clutch, drive it aggressively and see how that affects it.
Scikotic is offline   Reply With Quote
Old 07-12-2016, 05:22 PM   #30
gramicci101
Off Topic
Both of which are fine options, but what if they installed it wrong? I doubt Competition Clutch is going to warranty it without it being taken off and sent to them for inspection first.
The Following User Says Thank You to gramicci101 For This Useful Post:
FRS Justin (07-12-2016)
Old 07-12-2016, 08:07 PM   #31
FRS Justin
Drives: 2013 Asphalt FRS
ok I just looked up your stg3 disc. and that is your problem the hotter it gets the stickier it is. Its a ceramic disc if I were you I would by a stg 2 disc and slap it in there and it should fix your problem. Or just beat on the ceramic one.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 07-12-2016, 08:08 PM   #32
Scikotic
Scikotic's Avatar
I agree that they wont do a thing without it being removed. I am going to drive it harder and see what happens, then go from there
Old 07-12-2016, 08:10 PM   #33
Scikotic
Scikotic's Avatar
Thanks! I will look into that. I am going to try and drive it harder this week and see how that goes
The Following User Says Thank You to Scikotic For This Useful Post:
ISSUE: 1900-2000 RPM Shutter/Shaking (Free load) Neurytic Issues | Warranty | Recalls / TSB 29 11-22-2020 10:19 PM
2-3K RPM hesitation/bucking - logged 86fun Software Tuning 5 01-29-2016 08:58 AM
loss of power/ bucking in rain fasteddy Issues | Warranty | Recalls / TSB 30 10-20-2015 02:08 AM
DIY CLUTCH INSTALL .. charged86 DIY (Do-It-Yourself) Guides 3 09-13-2013 12:10 PM
HELP...Drive Shaft/Rear Tire Shutter UM FRS Issues | Warranty | Recalls / TSB 11 09-05-2012 11:14 AM
