Old 05-01-2016, 08:46 PM   #1
Visitor.S
Drives: Frs
help! AT trans rev match problems
my frs is auto transmission, and when i put on M model to use the paddle down shift, the transmission will do the rev match, toyota called it dynamic rev managment system, but the prblem is sometime the rev match is work and sometime is not work, anyone know how to fix it? and whats the problem is? thanks
Visitor.S is offline   Reply With Quote
Old 05-01-2016, 08:53 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
http://www.ft86club.com/forums/showthread.php?t=96615
It is a well documented issue that I discovered the TSB for please check that thread out and get the latest TCM logic flashed.
Old 05-02-2016, 07:31 PM   #3
Visitor.S
Drives: Frs
thanks for help, but my frs is already install the turbo kits and reflashed the ECU, is that still possible to go to dealer fix the TCM reflash?
Old 05-02-2016, 08:11 PM   #4
FRSBRZGT86FAN
Do you know someone with the techstream? I have the cuw file for you to flash if you need it.
Old 05-02-2016, 09:09 PM   #5
Visitor.S
Drives: Frs
i can try to go tuning store, or it has to be a dealer to flash it?
Old 05-02-2016, 09:11 PM   #6
FRSBRZGT86FAN
A dealer will have to flash it honestly, you may have to pay for it because you have a turbo. Also important note, if you have an ecutek tune there's no way in hell your ecu can be flashed by techstream. That's becaue your ecu is locked after a flash to prevent tampering of the tune. You really should go to wherever you got the tune done and ask them if they have access to techstream to flash the latest tcm logic.
Old 05-02-2016, 09:23 PM   #7
Visitor.S
Drives: Frs
thanks again, can you give me the file? i will give to my tunner and let them find a way to take care it
Old 05-02-2016, 09:26 PM   #8
FRSBRZGT86FAN
Here you go:
https://drive.google.com/file/d/0Byr...ew?usp=sharing
But honestly only toyota techstreams calibration update wizard can open that file. If that doesn't fix the rev match issue then the turbos constant boost must've worn something out in the trans, but the dynamic rev matching being the only issue really comes across as a tcm issue
Old 06-19-2016, 08:06 PM   #9
Visitor.S
Drives: Frs
Here you go:
hey buddy, i went to dealer, they can not help me flash that, did you know somewhere or some tuner can help me do that in los angeles area? thanks man~
Old 06-19-2016, 11:39 PM   #10
FRSBRZGT86FAN
You'd have to flash to stock somehow and then beg your dealer to flash it through techstream the proper way, which will be nearly impossible for you because of the turbo kit.
Old 06-20-2016, 12:05 AM   #11
steve99
Drives: FT86
ecutek only locks you out of the engine ECU.
maybe the dealer doesn't realise it a transmission control unit update, not engine ECU.
Old 07-10-2016, 08:49 PM   #12
Visitor.S
Drives: Frs
im agree with u, i will try to find a dealer can help me update, thanks man
Old 07-11-2016, 12:10 AM   #13
Mattstermh
Drives: '13 FR-S A/T - Stock
Do you have it in sports mode when driving in manual? I've found it to be smoother when sports mode isn't on. Matter of fact, the car feels better when it's not in sport mode/vsc imo.
Mattstermh is offline   Reply With Quote
Old 07-11-2016, 12:43 AM   #14
FRSBRZGT86FAN
Sport does not effect throttle mapping regardless, and also doesn't effect shifting when in manual mode....
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-05-2016 12:18 AM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 05:01 PM
fs: Perrin trans mount and whiteline trans bushing RWD_FR-S Transmission and Driveline 1 01-02-2014 06:34 PM
Can the FR-S trasmission Rev-match? Razor Engine, Exhaust, Transmission 75 04-22-2013 01:12 AM
Proper way to Rev Match pinoyplaya Engine, Exhaust, Transmission 46 09-05-2012 02:09 PM
