Drives: Frs
help! AT trans rev match problems
my frs is auto transmission, and when i put on M model to use the paddle down shift, the transmission will do the rev match, toyota called it dynamic rev managment system, but the prblem is sometime the rev match is work and sometime is not work, anyone know how to fix it? and whats the problem is? thanks
#2 | |
It is a well documented issue that I discovered the TSB for please check that thread out and get the latest TCM logic flashed.
#3 | |
Drives: Frs
thanks for help, but my frs is already install the turbo kits and reflashed the ECU, is that still possible to go to dealer fix the TCM reflash? |
#4 | |
Do you know someone with the techstream? I have the cuw file for you to flash if you need it.
#5 |
Drives: Frs
#6 |
A dealer will have to flash it honestly, you may have to pay for it because you have a turbo. Also important note, if you have an ecutek tune there's no way in hell your ecu can be flashed by techstream. That's becaue your ecu is locked after a flash to prevent tampering of the tune. You really should go to wherever you got the tune done and ask them if they have access to techstream to flash the latest tcm logic.
#7 | |
Drives: Frs
thanks again, can you give me the file? i will give to my tunner and let them find a way to take care it |
#8 | |
Here you go: https://drive.google.com/file/d/0Byr...ew?usp=sharing But honestly only toyota techstreams calibration update wizard can open that file. If that doesn't fix the rev match issue then the turbos constant boost must've worn something out in the trans, but the dynamic rev matching being the only issue really comes across as a tcm issue
#9 | |
Drives: Frs
#10 | |
You'd have to flash to stock somehow and then beg your dealer to flash it through techstream the proper way, which will be nearly impossible for you because of the turbo kit.
#11 | ||
Drives: FT86
ecutek only locks you out of the engine ECU. maybe the dealer doesn't realise it a transmission control unit update, not engine ECU. |
#12 |
Drives: Frs
#13 |
Drives: '13 FR-S A/T - Stock
Do you have it in sports mode when driving in manual? I've found it to be smoother when sports mode isn't on. Matter of fact, the car feels better when it's not in sport mode/vsc imo.
#14 | |
Sport does not effect throttle mapping regardless, and also doesn't effect shifting when in manual mode....
| Buddy Club Race Spec Coilover Problems on Problems on Problems | mpross | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 48 | 09-04-2016 11:18 PM |
| Transmission problems, oil leaks and detonation problems.. | turboviper | Issues | Warranty | Recalls / TSB | 4 | 06-18-2014 04:01 PM |
| fs: Perrin trans mount and whiteline trans bushing | RWD_FR-S | Transmission and Driveline | 1 | 01-02-2014 05:34 PM |
| Can the FR-S trasmission Rev-match? | Razor | Engine, Exhaust, Transmission | 75 | 04-22-2013 12:12 AM |
| Proper way to Rev Match | pinoyplaya | Engine, Exhaust, Transmission | 46 | 09-05-2012 01:09 PM |
