Old 06-06-2016, 12:25 PM   #449
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Copied over the latest cranking tables as mine were way out of date and finally did the fix for the fans to come on sooner. Too lazy to log but quite a nice difference in IATs when sitting in traffic when it is 80*f+ ambient. Thank you for all your help @Wayno
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 06-10-2016, 01:58 AM   #450
Rezi
Drives: GT86
@Wayno, is your v104 Stage 1 safe to run on pump-gas? You mentioned something that "it is for flex-fuel", but i never will run on any Ethanol.
Rezi is offline   Reply With Quote
Old 06-10-2016, 02:48 AM   #451
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Haven't posted anything for flex fuel and if i did it wouldn't be for stg1. But yes it's fine.
Old 06-21-2016, 11:47 PM   #452
phrosty
I see you've changed overrun a fair bit in your latest. Any links explaining what it affects?
phrosty is offline   Reply With Quote
Old 06-22-2016, 03:24 AM   #453
Wayno
Wayno's Avatar
Did you look at the table properties?
Throttle plate angle.
The Following User Says Thank You to Wayno For This Useful Post:
phrosty (06-22-2016)
Old 06-22-2016, 09:18 PM   #454
Wayno
Wayno's Avatar
This is not the full picture as these are paired with exhaust cam, a 3D graph of the valve overlap would be better. But gives some indication of the work done on AVCS.
EL OTS 91 vs EL v107 Intake cam
STOCK vs OFH vs UEL v107 Intake cam
elBarto (06-24-2016)
Old 06-24-2016, 10:32 PM   #455
Blood
Drives: 2018 STI
If I wanted to use the E85 cranking tables with DW 700cc injectors what would I need to scale the tables by? It is current value x old injector scaling / new injector scaling, right? The E85 roms have 171cc/min scaling (stock roms have 228cc/min) and I am assuming I would use 700cc/min as the scaling for the larger injectors. So in that case, the cranking tables should be scaled down to 24.43% of their current values?
Blood is offline   Reply With Quote
Old 06-24-2016, 10:39 PM   #456
Wayno
Wayno's Avatar
I've no idea. Better to start a new thread in software section to ask some of the FI guys that are FI - kodename, ztan, shiv, etc. These values are for stock/NA only.
Old 06-25-2016, 05:00 AM   #457
Kodename47
Kodename47's Avatar
Drives: UK GT86
The E85 ROMs scale "down" the value to provide more fuel for the requirements of E85. So what you need to do is give the new injector scalar the same ratio. So (171/228)*700.
For the cranking values, you would reduce these by (228/700)*original value. That's based on the original E85 cranking tables.
Don't forget to set the latency values too, and confirm that 700cc is the correct value to set.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-03-2016, 04:11 PM   #458
phrosty
Your VVT smoothing gives a pretty striking improvement to driveability when just cruising around. Almost completely removed bogging down on light throttle 2500->1900rpm upshifts. Going to give it a go at dialing in a bit more, but fantastic work.
The Following User Says Thank You to phrosty For This Useful Post:
Wayno (07-09-2016)
Old 07-03-2016, 06:10 PM   #459
Wayno
Wayno's Avatar
I got 5L/100km @ 115kph / 2200 rpm the other day. That 56.5 mpg. So I would recommend not touching 2200 rpm.
It's possible the 2000 rpm row could use some more advance though as it was also 5L/100km, like this.
0, 0, 8, 10, 12, 14, 16, 19.
I just didn't want to stray too far from every other calibration out there and also I'm tired of flashing and testing.
I've added that timing to the OP as v107.1.
The Following 2 Users Say Thank You to Wayno For This Useful Post:
gonzo (09-09-2016), phrosty (07-07-2016)
Old 07-07-2016, 02:21 PM   #460
Vash
Drives: Whiteout FR-S
I was using the OFH AVCS tables and it was a bit difficult to drive in the lower RPMs (it felt very gutless below 3000RPM). It kind of felt like I had to avoid having my RPMs fall below 3000rpm or else it'd drop off a cliff and I had to climb back up, but after switching to the v107.1 tables, it felt much smoother and more linear. Thanks Wayno
Vash is offline   Reply With Quote
The Following User Says Thank You to Vash For This Useful Post:
Wayno (07-09-2016)
Old 07-09-2016, 07:30 AM   #461
Wayno
Wayno's Avatar
Attached Stg1 with smoothed AVCS tables at part throttle.
For comparison against vanilla Stg1/v107 only.
It should either feel noticeably improved with better economy
or will feel noticeably rubbish having too much cam advance for stock header.
Old 07-09-2016, 09:25 AM   #462
freerunner
freerunner's Avatar
Drives: GT86
Going to check it out.
freerunner is offline   Reply With Quote
The Following User Says Thank You to freerunner For This Useful Post:
Wayno (07-09-2016)
Help uploading 2.06 tunes to OFT Jimmy817 Software Tuning 3 12-28-2014 09:06 PM
Custom Az Tunes Juggles Arizona 13 11-08-2014 10:15 AM
EcuTek Tunes Rio Engine, Exhaust, Transmission 1 04-29-2014 12:10 AM
How long until *other tunes? ScionFrsFan Engine, Exhaust, Transmission 61 12-07-2012 05:34 PM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 04:26 PM
