Old 07-06-2016, 10:46 AM   #43
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by Thorpedo View Post
You know that the point of failures were all over the board right? If you were talking about a particular issue that the 2013s had then you might have a case. The engines are nearly the same, and since there were so many different types of failures, you can't seriously hope to sound reasonable by making the point that "2013s can't take boost". That's sort of like saying 2013s have weak head gaskets, cranks, rods, blocks, DI seals, DI pumps etc etc.
Get real man, you sound downright foolish.
Still here? Might want to see how many 2013's have gone bye-bye by now...sounds downright correct is more like it...
Lonewolf is offline
Old 07-06-2016, 10:47 AM   #44
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by TurboBRZ View Post
No, it more has to do with throwing out blanket claims with little to no reasoning behind it other than your own opinion... If you had some facts that you threw in you wouldn't sound so foolish.
Have you read the F/I forums the last year? Don't ignore all the rod bearing issues from both stock and boosted 2013's as well. Notice any trends?
Lonewolf is offline
Old 07-06-2016, 10:58 AM   #45
raven1231
FWIW 2013's have also been around longer, and likely have more miles compared to most 14's and up
raven1231 is offline
Old 07-07-2016, 08:46 AM   #46
Thorpedo
The SquadWhisperer
Still here, still right. You still clearly aren't a statistician.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline
Old 07-07-2016, 12:04 PM   #47
Lonewolf
Lonewolf's Avatar
Drives: Moped
Never claimed to be, but the evidence that the bulk of the 2013 motors are deficient when it comes to handling boost is quite clear by now, lol
Lonewolf is offline
Old 07-07-2016, 01:53 PM   #48
brianhj
Drives: 2017 Camaro 1SS
This is the first I've heard of this.. What's the issue with 2013 motors? Is there any proof that the other MY motors are actually different? I thought they were the same
brianhj is offline
Old 07-07-2016, 02:10 PM   #49
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
2014 showed some changes, but 2015 MY + years showed a heavy valvetrain revamping. 2017 + will show even more in the way of improved engine design, though in smaller details. 2013's are technically more prone to failures of various sorts, but the rods are just as terrible in all years.
-Zach
DeliciousTuning is offline
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Summerwolf (07-07-2016)
Old 07-07-2016, 02:25 PM   #50
brianhj
Interesting! What kind of revamping have they done exactly? Do you know
brianhj is offline
Old 07-07-2016, 02:42 PM   #51
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
From what I remember they chaged the valve stem length (not nessecarily the springs, iirc) as to attempt to prevent more rocker arms from exiting the motor.
This thread is basically a bunch of people stomping their feet.
I think its a logical reason to sit here and think the 2013's are more prone to boost application failures as opposed to newer MY engines because of the revisions they made.
The rods have always been a weak point.
At any power level over double the stock SAE rated for the engine, is a ticking time bomb. reguardless of modle year. a 2015 vs a 2013 will pop at 700whp. Not if, when.
cdrazic93 is offline
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post:
brianhj (07-07-2016)
Old 07-07-2016, 03:26 PM   #52
DeliciousTuning
The entire valvetrain was heavily revised in 2015. This is also why 2015-2016 cars typically dyno just a bit lower than prior model years. 2017 will receive further valvetrain changes including revised cams, valves, and rockers from the DIT engine. Changes on the bottom end will include additional stiffening ribs, a surface treatment on the pistons, and more.
-Zach
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
brianhj (07-07-2016), Lonewolf (07-07-2016)
Old 07-07-2016, 05:12 PM   #53
Calum
That Guy
Drives: 2013 asphalt FRS MT
-Zach
Do you know of the newer parts will fit on the older heads?
Calum is offline
Old 07-07-2016, 08:35 PM   #54
Lonewolf
Lonewolf's Avatar
Drives: Moped
Many small changes were made, its been discussed before (valves, tune, etc.)
I said a while back that the MY 2013 motors were not built well to handle boost and were time bombs. Bunch of people jumped down my throat for it, but it turns out to be true
Lonewolf is offline
Old 07-08-2016, 09:44 AM   #55
Thorpedo
The SquadWhisperer
:b onk:
Older cars are more prone to failures, as they have done more miles, were the guinea pigs for boost systems, tuning, and all the rest. Typically people who got the 2013 were more so motorsports enthusiasts (as they waited for the car) and have done things "that the car was built for." How about looking at sales numbers too? How many of each model year are out there?
Some guy named Lonewolf watches a TINY, miniscule fraction of failures on a forum, takes nothing else into account, and declares 2013s "time bombs". His only real piece of supporting evidence being that they revised the valvetrain. Newsflash, typically MANY revisions are done to new engine platoforms over the years to address "issues" that come up in a small fraction of engines to further decrease failure rates. How do I know? I worked at and ran an engine shop for years.
But nooooo, they're "time bombs" even though my car and many of my friends' 2013s run raised rev limits and do hundreds and hundreds of autocross runs and laps at the local track (both with and without boost). Wait a minute, there are probably thousands of people on this forum who do stuff like that!!!!! (You'd think a light bulb would come on above his head, but no.)
Don't get me wrong, are the failure rates for 2013's higher? Absolutely, but calling them time bombs makes you look like a complete fool to anyone who has a clue.
Thorpedo is offline
Old 07-08-2016, 10:58 AM   #56
Lonewolf
Lonewolf's Avatar
Drives: Moped
:b onk:
Many of your "points" are already known and accepted to be common knowledge. You just wasted your time typing out that
boilerplate response.
CN Takeaway: So your opinion is the only valid one? LMAO....
Lonewolf is offline
Cars & Coffee w/ Edge Motorworks (Mountain View) Sunday Aug 24 9-12pm MyRx Northern California 19 08-28-2014 01:07 PM
Zeal Motorworks front lip/splitter ghost86 Cosmetic Modification (Interior/Exterior/Lighting) 7 04-10-2014 12:48 PM
Edge Motorworks BRZ Autocross Build, March 3rd Mountain View! race2win Northern California 24 03-14-2013 10:05 AM
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
