#15 |
Drives: 2013 Black FR-S
LMAO 40-50 threads!!!!
| The Following User Says Thank You to sw20kosh For This Useful Post: | Yoda (07-16-2015) |
#16 |
Drives: '13 FR-S Whiteout
#17 |
Sarcastic SOB
The question that begs to be asked is why go to all the time and expense to set up a configuration that is bound to destroy the engine vs prepping the engine for these conditions??
Why would anyone deliberately destroy an engine? Makes no sense! This is analogous to constructing a multi storey building on patio stones. I would think anyone with the budget to do a failure test could just as easily utilize the expertise of someone who could predict the weak points empirically. I'm going to go with rod>piston>valve>gasket failure. And I have no expertise other than reading of previous instances.
| The Following User Says Thank You to wbradley For This Useful Post: | Tcoat (07-17-2015) |
#18 | |
I Love custom Turbo kits
Drives: Limited BRZ
It did not. Stupid rumors are stupid.
Boosted to 552 whp 471 wtq for two years. Still running strong. It's all in the way you drive, tune, supporting mods and maintain your car. Of course, this is not a bulletproof engine and the factory does produce some bad engines, but most times than not, the motor can hold boost, again with the proper setup.
| The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post: |
#19 |
Drives: 2015 brz
Also tune is VERY VERY important! I say 90% of it has to do with the tune!
| The Following User Says Thank You to Streetthrowback For This Useful Post: | Sgtfluffy16 (09-27-2016) |
#20 |
Drives: 2013 BRZ Limited
It's absolutely badass that a stock 2.0L motor can hit nearly 700WHP, but at the same time this car is a death trap! This guy has no idea what he's in for if he gets into a front-end collision now after removing his bumper impact beam and absorber... I've seen the impact these things can take and I feel bad for whatever driver eventually wrecks this car on some amazing run at 700hp. Performance without safety (in my opinion) is the definition of stupid.
The BlueBaru Turbo Rebuild: http://www.ft86club.com/forums/showthread.php?t=90382
I Rebuild BRZ's for Breakfast. ![]() |
#21 |
Drives: Moped
#22 |
You mean people who paid a shop to do all of their install and then bought a cookie-cutter out of the box tune for their turbo or SC setup instead of taking it into a dyno for tuning? Ya - that'll make your motor blow up a lot sooner than if you did it right the first time. Out of the threads I've read where people blew their motor below 300hp, they all had a cookie-cutter tune rather than doing it the right way. It has little to do with how much boost you run or what HP you are making and a lot more to do with "quick, easy and cheap".
#23 | |
The SquadWhisperer
Get real man, you sound downright foolish.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion 2017 Bluenose Autosport Club Overall Rallycross Champion Powered by Great North Performance, Jani-King Canada, and OK Tire. |
#24 | |
Drives: Moped
![]() I sound foolish because I made an opinion based on consistent observations I've made over the years? Lol...oh well, I guess you can't please people who live in fantasy land.
#25 |
No, it more has to do with throwing out blanket claims with little to no reasoning behind it other than your own opinion... If you had some facts that you threw in you wouldn't sound so foolish.
#26 | |
There were undeniably issues with the early engines that have been changed since then and there is plenty of documentation here to support that as a fact. Another aspect that I have not seen mentioned here is that there is a rather lengthy list of engines that were blown doing R&D for tunes and aftermarket parts. These pioneers knew exactly what the risks were while they pushed the limits to develop the best performance while keeping as much reliability as possible and fully accepted that they could/would blow up an engine or two. The boosted engines that are still going strong are the result of this R&D not in spite of it nor the exception to the rule. I do however disagree with Lone on the fact that all the 13s are ticking time bombs. If the stock engine has had the fixes applied (especially the updated TSB tunes) and is properly maintained there is no reason to expect it to be any worse than the later ones. From what little info I have been able to glean on major failures the rate is no greater than the average new release of any other make. Engines that have been modded or boosted will last as long as the quality of work and materials that were initially put into them, how hard they are used and how well they are maintained.
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#27 | |
Drives: 13 Subaru BRZ
#28 |
AutoX-10/10ths every run
I've got 86K plus on a 2013 motor, 52K+ boosted. My car is still running fine.
| Cars & Coffee w/ Edge Motorworks (Mountain View) Sunday Aug 24 9-12pm | MyRx | Northern California | 19 | 08-28-2014 01:07 PM |
| Zeal Motorworks front lip/splitter | ghost86 | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 04-10-2014 12:48 PM |
| Edge Motorworks BRZ Autocross Build, March 3rd Mountain View! | race2win | Northern California | 24 | 03-14-2013 10:05 AM |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
