Old 07-05-2016, 06:40 PM   #1
csmith171
Drives: 2013 FRS
Changed clutch and wheel studs and all hell has broken loose
A couple weeks back I changed my clutch and flywheel as well as my wheel studs and now I am getting codes for the transmission speed sensors, right front speed sensor, left rear, low voltage, and the car is in limp mode with the cel traction control and abs lights all on. I double checked all the sensors and everything is plugged in... what the hell is going on??
csmith171 is offline   Reply With Quote
Old 07-05-2016, 06:48 PM   #2
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
Did you check the relevant fuses?
theadmiral976 is offline   Reply With Quote
Old 07-05-2016, 07:11 PM   #3
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
holy hell in a hand basket.....check the ABS rings and unplug and clean connectors and plug it all back in to see if that works. And check what theadmiral976 said, something has to of been missed or changed to have all of it go haywire. I bet it's something simple and small too.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 07-05-2016, 08:23 PM   #4
Teseo
Drives: frs
Ha, auto's
Old 07-05-2016, 09:49 PM   #5
Exactly what codes did you get? Did you remove or mess with the wheel speed sensors? There are no speed sensors in the manual transmission.
Did you mess with the crankshaft position sensor plate when you swapped flywheels? I don't see how it's possible but I hear people have screwed up the installation.
Old 07-05-2016, 10:49 PM   #6
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Specific codes will definitely help. Did you remove the hubs to change the studs? The front hubs have a protective backplate that shields the backside of the sensor. The rear axle has a plate that does the same. If you pulled the hub without removing the sensor from the upright first it's very likely you damaged or snapped the sensor. Not sure about the other problems until we get the codes.
I have been dumb enough to put the crank reluctor plate on backwards, car wouldn't read crank turning and I had to pull the trans a second time to fix it. That wouldn't be your problem though, symptom of getting it backwards would be it not starting at all.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
The Following 3 Users Say Thank You to zkv476 For This Useful Post:
jcw99 (07-06-2016), LenA (07-06-2016), Ultramaroon (07-05-2016)
Old 07-05-2016, 10:59 PM   #7
Wow, I would say that's Subaru's fault for keying it symmetrically. A slight offset would keep the bolt holes from lining up. Thanks. I'll keep an eye out for that in the future.
Old 07-05-2016, 11:25 PM   #8
zkv476
zkv476's Avatar
It's funny because I knew immediately after watching the ECU readout and it showing 0 rpm. The motor was out of the car and on the hoist from a build and I placed it with the teeth facing me, and didn't think anything of it. It didn't occur to me until it was all buttoned up and didn't work. The plate usually stays somewhat put if you don't need to remove it. But yes certainly wouldn't have been hard to make it keyed one way.
The Following User Says Thank You to zkv476 For This Useful Post:
Old 07-06-2016, 05:34 PM   #9
csmith171
Drives: 2013 FRS
It was all just a broken left rear abs sensor haha. All is well at the moment.
The Following User Says Thank You to csmith171 For This Useful Post:
Drakiv (07-10-2016)
Old 07-06-2016, 05:38 PM   #10
AdrianSaldana
That Guy
AdrianSaldana's Avatar
Drives: Fast and Hard
Scaring us here haha
"Knowledge will give you power, but character respect.."
DD: 2007 Suzuki Sv650
Weekend Car: 1969 Chevelle
Summer/Weekend Car: 2014 BRZ
AdrianSaldana is offline   Reply With Quote
Subaru field engineer says OEM wheel studs only good for 75 to 80 wheel changes Pat Tracking / Autocross / HPDE / Drifting 86 07-16-2021 10:50 AM
stiffer clutch= broken Clutch fork KAR Engine, Exhaust, Transmission 1 04-25-2016 05:31 AM
Clutch Fork Broken rick s Issues | Warranty | Recalls / TSB 8 08-27-2015 01:49 PM
Broken Clutch HPDE yzarc0g Tracking / Autocross / HPDE / Drifting 0 06-25-2014 08:33 PM
broken wheel studs Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-06-2012 12:47 AM
