Old 07-04-2016, 04:23 PM   #29
wbradley
Sarcastic SOB
wbradley's Avatar
After installing a Revworks catless UEL header, my Magnaflow catback is too loud IMHO.
Almost for sure you will regret a muffler delete if you do a header afterward.
Old 07-04-2016, 05:59 PM   #30
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Jnamrefiel View Post
I want to say invidia sells a bolt on panel to correct that issue.
You're thinking Borla, but you already repeated what I said:
"This is why complete rear diffusers improve gas mileage on our cars, because that is probably the most inefficient part of a car that is already pretty good."
Old 07-04-2016, 06:30 PM   #31
Jnamrefiel
Drives: 2015 Subaru BRZ LIMITED
My apologies it's by A'pexi for their N1-Evolution extreme
http://www.frsport.com/Under-Diffuse...hsPxoC6__w_wcB
Sent from my 831C using Tapatalk
Jnamrefiel is offline   Reply With Quote
Old 07-04-2016, 07:50 PM   #32
Cole
Not a troll
Cole's Avatar
Originally Posted by Norville Rogers View Post
Can you have a rhetorical answer?
Did you have anything to add to the topic at hand? Or were you just going to add some further BS to the conversation? I've had more catbacks than axlebacks. Or will that just add more rhetoric to the topic?
Cole is offline   Reply With Quote
Old 07-05-2016, 01:32 AM   #33
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Muffler delete affects MPG
It's not so different. Your foot is still a much bigger factor. That diffuser does kill off good amount of noise generated by letting that big open area act like a drum with ur exhaust.
I have N1X+ diffuser for a year & half already.
Old 07-05-2016, 08:27 AM   #34
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
A few weeks ago I got the Berk dual muffler delete and it is kind of loud. I have a pretty high tolerance for a loud exhaust, so it's not a big issue for me- some other people do not have a tolerance for a loud exhaust so it is a prob for them- know what your tolerance is before you delete the muffler. But IMHO it sounds awesome and cheap. as for MPG- yes, mine has gone down a little but it's because I get on it and I like the sound. Plus to get any power from this engine you have to run the revs up high and the more I have this car the more comfortable I am running the revs up so high.
To reduce the drone on the highway I had a cherry bomb (glasspack muffler) installed and now when I get on it, the exhaust is loud but when I cruise, it is very quiet. I love this setup. I also have an intake and I can hear the extra sound of the intake when I get on it, the exhaust does not overpower the sound from the front of the car and I don't have the annoying sound induction tube either (the tone of that tube didn't sit well with me once I went with the Berk).
I can't see how this is a waste of money- esp. since I got both used for less than half the MSRP. The setup is for sound, not power (though shedding 20 lbs from the car works for me!) and it is down to my preference- how is that a waste of money? A catback system will net the same gains as an axleback... none at all. I don't plan on dropping big money for a catback system that will sound the same (with my old car I had a stainless turbo back setup but no one ever crawled under my car to admire the bling underneath) and yield the same power gains. If you are going catback only, you are modding for sounds and/or bling and that's it. You can mess up your engine output with a catback, but there are no real gains. the FRS exhaust is very well setup and tuned for this engine.
One mistake many people make is instantly going for a bigger exhaust diameter on a N/A car. If you want that little bit of power from deleting the cats, then OK- that + a tune = kiss your powertrain warranty goodbye- but you WILL GET that extra bump in power. No cats also = big noise. So then you need a muffler again. It's a lot of money to void your powertrain warranty and gain 10% engine output and spend a couple thousand dollars in the process. Look at dynoes on this forum to see what headers do for power- they are mostly for sound until you delete that cat + tune.
But going big on your exhaust piping in a low power N/A car will mess up your power curve and sap what little low end grunt these cars may have even if you find dyno gains on the top end where you spend very little time anyway.
[ame="https://www.youtube.com/watch?v=RWTARjxiqlo"]No More Exhaust Myths - /ENGINEERED - YouTube[/ame]
Watch this if you're thnking of going big to gain engine output. Where do you want your engine to make power?
guybo is offline   Reply With Quote
Old 07-05-2016, 09:48 AM   #35
guybo
Huge E85 fan!
guybo's Avatar
I just saw this video and it says a lot for the stock exhaust [ame="https://www.youtube.com/watch?v=DOrxEBzRD7o"]Subaru BRZ 3 year update - YouTube[/ame]
Old 07-05-2016, 10:09 AM   #36
Silver Cervy
*Some really cool title*
Silver Cervy's Avatar
First of all, don't worry about what's "ricer" and what isn't. Modding a car is self subjective, meaning you will know what you like and when you've taken it too far. I did a catback w/ muffler delete first and I am very satisfied with it, don't feel like a ricer at all. If there's been any decrease in mpg since it's because I've been driving my car twice as hard just to hear the lovely noise it makes.
Also, I would agree that headers are the better first option, but keep in mind that if you get a catless header you will need to get a tune to prevent a cel from flipping, which can cost up to $1000 alone based on what you get. So while it is a better mod it is much more expensive. I learned this the hard way when I bought a header with my catback but had to return it because I couldn't afford a tune, which meant getting a %20 refund fee being charged by the place I ordered it from. So if I were you I would do a TON of research and do it right instead of screwing up like I did.
Edit: Wow, I'm an idiot. Didn't see how old this post really was.
Silver Cervy is offline   Reply With Quote
The Following User Says Thank You to Silver Cervy For This Useful Post:
guybo (07-05-2016)
Old 07-05-2016, 10:39 AM   #37
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
Lol yea it's pretty old. I ended up going with the Dezod Cat-back. Things changed, for good.
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 07-05-2016, 11:07 AM   #38
guybo
Huge E85 fan!
guybo's Avatar
That's my point too, it's all about YOUR preference. I think some things are ricer and I don't like such as adding fake hood vents, gaudy trim pieces and performance robbing mods just for looks or sound- but a catback or an axleback is not ricer at all. This is one of the first mods people have been doing to thier cars for a LOT of years now.
Old 07-05-2016, 12:09 PM   #39
ShadowReaper
Indulgent Tormenter
It's not. Whoever said it was?
Custom Muffler Delete vs Berk Dual Tip Muffler Delete eric2523 Engine, Exhaust, Transmission 7 07-27-2015 09:40 AM
Any muffler shop on Oahu for muffler delete? ALOHA_FR-S Hawaii 1 07-01-2015 10:49 PM
WTB: Berk Track Pipe Muffler Delete or Nameless Muffler Delete Hollwood_lives Canada Classifieds 5 04-12-2015 07:02 PM
WTB Berk Dual Exit Muffler Delete or Works AB Delete Admired Want-To-Buy Requests 2 09-10-2013 04:20 PM
Muffler Delete sound without deleting muffler sw20kosh Engine, Exhaust, Transmission 10 01-30-2013 05:09 PM
