Old 07-01-2016, 10:52 PM   #14267
choiboie
Drives: 2013 Fr-S UltraMarine
Originally Posted by FNCrazy View Post
It depends on what I can afford, and if someone helps me install. That eats the most money. I'm going to try to change the whole system though
Sent from my SM-G935V using Tapatalk
I was gonna do the same last month but ended up using the money to buy wheels and echaust lol
Sent from my SM-G920V using Tapatalk
choiboie is offline   Reply With Quote
Old 07-01-2016, 10:57 PM   #14268
FNCrazy
Rambling Man
FNCrazy's Avatar
Drives: 2013 FR-S 6MT - In Heaven Now
Let's see pics!!
FNCrazy is offline   Reply With Quote
Old 07-01-2016, 11:12 PM   #14269
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Hooked up an air hose to the front of my Weapon R intake filter and ran it to the wheel liner (poked a hole in it) for cooler air. I couldn't figure out a way to use the OEM air feed.
guybo is offline   Reply With Quote
Old 07-02-2016, 03:18 PM   #14270
pooch
pooch's Avatar
Drives: 2013 Scion FR-S (M/T)
Installed Crawford Power Blocks, nice little mod with some nice improvements in 3rd gear. Thanks to Kevin Nguyen for the blocks!
pooch is offline   Reply With Quote
Old 07-02-2016, 03:30 PM   #14271
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
How tough was the install? Any fitment issues?
MJones_RB is offline   Reply With Quote
Old 07-02-2016, 03:34 PM   #14272
pooch
pooch's Avatar
45min total maybe? Direct bolt on fitment machined perfectly. Most challenging was lifting the intake manifold high enough to slide them under but i used a hammer handle for better leverage and they slipped right in and everything bolted right back up.
Old 07-02-2016, 04:20 PM   #14273
TimmyC
TimmyC's Avatar
Drives: 2013 FRS
They overtightened the bolts that hold on the calipers, or never reset the pistons? Sometimes the shims can bind, causing issues.
Take them apart and redo them yourself. Use lots of molly grease on everything that moves (just not the brake pad surface). Use silicon grease on the caliper posts.
http://www.ft86club.com/forums/showthread.php?t=24614
Thanks! I just brought it back to them and they fixed it. But quite a disappointing experience from the dealership, I expected better.
TimmyC is offline   Reply With Quote
Old 07-02-2016, 09:06 PM   #14274
DarkSunrise
DarkSunrise's Avatar
Track day! Gorgeous weather. Perfect for testing out new suspension, alignment and tune.
2022 BRZ Build
2013 FR-S Build
Old 07-03-2016, 03:07 AM   #14275
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Three wheeled while leaving a steep Burger King exit... Car got stuck. Ended up reversing and finding another way out.
"Have it your way," yeah right.
dhuang is offline   Reply With Quote
Old 07-03-2016, 05:43 PM   #14276
stevesnj
stevesnj's Avatar
Amber fogs wired up! Finally! I love this classic look of amber and blue contrast.
My 2016 Build thread
Old 07-03-2016, 07:37 PM   #14277
guybo
Huge E85 fan!
guybo's Avatar
If one of your rear wheels is off the ground and the diff free wheels and you're stuck, you can lock up the wheels by using the handbrake just a little.
Old 07-03-2016, 09:33 PM   #14278
notout86
Drives: GTS 86 auto
Originally Posted by GenRuleAThumb View Post
Do I spy a torque wrench? You would never make a mechanic.
GTS86 Auto (Australia)
Old 07-03-2016, 09:55 PM   #14279
Lococholo84
Drives: Celica, Frs
Installed a Bayson lip
Was worried about it being shipped this way but fortunately it straightened out.
Lococholo84 is offline   Reply With Quote
Old 07-03-2016, 11:45 PM   #14280
anchovy619
anchovy619's Avatar
Drives: Into Crowds
palomar run with my room mates and a bunch of other people
anchovy619 is offline   Reply With Quote
