Old 06-20-2012, 08:04 PM   #43
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Originally Posted by Keith@AIRAID View Post
We are getting air from the front bumper just like stock, so there is no need to add an inlet because it's all the same air. The factory inlet only exists to house the Helmholtz resonators that control noise.
I see, so it's still sealed to the oval shaped hole above the radiator. Makes sense.
I misunderstood when you said "no inlet," thinking it was left totally open to the engine bay.
uspspro is offline   Reply With Quote
Old 06-20-2012, 09:45 PM   #44
Max Schnell
Drives: Lexus GS350 F-sport
Why not a plastic lid? After all that effort to keep temperature down using polyethylene it seems a shame to add a metal lid to soak and radiate heat down into the box.
BTW this is the best designed intake for this car I've seen so far. Sealed systems with all the filter surface area and flow of a cone system is the best combination.
Max Schnell is offline   Reply With Quote
Old 06-20-2012, 10:17 PM   #45
was385
Drives: MT WRB BRZ Limited, 2007 911s
Do you have a vague price point for this yet?
was385 is offline   Reply With Quote
Old 06-21-2012, 03:31 AM   #46
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Group buy?
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 06-21-2012, 08:46 AM   #47
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Looking forward to this
tonystewart is offline   Reply With Quote
Old 06-21-2012, 09:30 AM   #48
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
Hell, I'm just glad to have people a stones throw from where I live putting something like this together. Is pretty close to what I am looking for, and no one else is even in the ballpark.
So, when can I come get it?
Pscylo is offline   Reply With Quote
Old 06-21-2012, 09:33 AM   #49
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
Originally Posted by Max Schnell View Post
Why not a plastic lid? After all that effort to keep temperature down using polyethylene it seems a shame to add a metal lid to soak and radiate heat down into the box. ...
Here's an early prototype without the lid so you can see the filter. ...
FYI: First line of his post with the pics.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 06-21-2012, 12:43 PM   #50
Keith@AIRAID
Drives: 51 Kaiser, 97 4Runner, 07 Civic Si
First off, thanks! I think our enthusiasm for this vehicle shows in the final product.
Because I'm an Industrial Designer and brushed aluminum has a nice contrast against the black molded parts. Really though, I am working on insulating the lid as we speak. Even if it were not insulated, the surface area of the lid is a small percentage of the overall surface area of the complete system. Very little heat, if any, will radiate off the lid and make it into the throttle body.
Keith@AIRAID is offline   Reply With Quote
Old 06-21-2012, 02:05 PM   #51
boarder1995
Drives: 2013 Subie BRZ Limited, black, 6MT
Another piece of the puzzle I'm interested in. Price range? Thanks for the hard work on this.
boarder1995 is offline   Reply With Quote
Old 06-21-2012, 09:46 PM   #52
Max Schnell
I do agree contrast looks good. I like this design alot and I look forward to the finalized production version.
Old 06-21-2012, 10:03 PM   #53
speed3
Walkin' on sunshine
speed3's Avatar
Drives: Ford BA MKII XR6 ute
Any chance you will make one that completely deletes the sound generator? I'd rather have the pipe look as clean as possible.
Gutsy question. You're a shark. Sharks are winners, and they don't look back because they have no necks. Necks are for sheep.
speed3 is offline   Reply With Quote
Old 06-21-2012, 11:46 PM   #54
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
This.
Glad to see someone finally using a velocity stack on one of these aftermarket intakes. I'd try to work one into the filter mount tube too
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-22-2012, 12:48 PM   #55
Keith@AIRAID
This.
Maybe I did.
Old 06-22-2012, 12:52 PM   #56
Keith@AIRAID
Machining a mold is very costly so we will probably not be making two molds to delete the sound tube port. However I think if you use our delete plug you might be happy to see the little feature we designed into it. I'll keep it a secret for now, but it does have some utility if you choose to take advantage of it.
Technical information on the Toyota D-4S system arghx7 Engine, Exhaust, Transmission 72 01-13-2025 08:43 PM
cold air intake? carbonBLUE Engine, Exhaust, Transmission 72 09-30-2013 12:56 PM
FRS AEM Cold Air Intake KenAEM Engine, Exhaust, Transmission 28 10-24-2012 12:48 PM
2013 Scion FRS AEM Cold Air Intake KenAEM Engine, Exhaust, Bolt-Ons 2 07-12-2012 07:30 PM
Hello From AIRAID Filter Company AIRAID Announcements, Contests, Giveaways 3 06-11-2012 08:00 PM
