Old 06-20-2012, 04:52 PM   #29
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Looks good.
Old 06-20-2012, 05:05 PM   #30
Keith@AIRAID
Drives: 51 Kaiser, 97 4Runner, 07 Civic Si
Here is the prototype off our 3D printer installed on Matt's car. This is very close to what the production parts will look like. It uses an enclosed airbox and draws air from the stock location.
And here it is on the flowbench. We decided to make the airbox mate to the factory inlet in case people did not want to take their bumper apart to remove it.
To get the most airflow I recommend removing the factory inlet to let the box breathe from the space behind the bumper. It is possible to unbolt the top edge of the bumper and sneak the inlet out very carefully. We designed in a nice smooth velocity stack where it mates to the inlet which netted a couple more hp. By adding the velocity stack and removing the factory inlet, the CFM increased by 20% on the flowbench. I also stuck my hand in through the opening where the airbox breathes from and it is noticably cooler inside the bumper, so we know it is a great source for fresh, cool air.
Keith@AIRAID is offline   Reply With Quote
Old 06-20-2012, 05:08 PM   #31
baldolera
baldolera's Avatar
Drives: None Yet
That looks pretty good, kudos to you guys!
Originally Posted by LexusFman View Post
Nope because I have had Keichii Tsuchiya skills from the womb and I'm a beast at Gran Turismo. Reall cars can't be all different.
baldolera is offline   Reply With Quote
Old 06-20-2012, 05:08 PM   #32
Cudgel
Drives: 2008 Mazda3 GT Hatchback
Very nice! I will keep this one in mind.
Cudgel is offline   Reply With Quote
Old 06-20-2012, 05:09 PM   #33
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I appreciate the development and hard work going into this intake and I don't doubt its functionality at all, but damn that's a BIG airbox! I'm sure the final design will look cleaner with paint and branding
Old 06-20-2012, 05:22 PM   #34
Cheddar
Saving them pennies...
This is what I wanted someone to come up with when creating a intake for this car.
I don't want a tube that sits in front of the wheel!
I want a air box that keeps engine heat out and lets the cool air in.
Cheddar is offline   Reply With Quote
Old 06-20-2012, 05:35 PM   #35
Keith@AIRAID
You get it.
Old 06-20-2012, 05:46 PM   #36
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Were the dyno runs done with or without the stock "snorkel"?
Is the velocity stack built into the airbox, or is it an add on part?
So far, this looks like the intake Im going with. Im not a fan of metal intakes since they absorb heat. I love the Iceman intake on my '88 Civic, and it was a similar material to yours.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 06-20-2012, 05:51 PM   #37
Keith@AIRAID
Here's an early prototype without the lid so you can see the filter. It has a 120mm (4 3/4") opening and attaches to the MAF housing. This is a new filter that we tooled up for specifically for the FR-S. I wanted to fit the biggest filter possible so it required an odd size.
We effectively split the intake tube and moved part of it inside the airbox due to packaging constraints. I've never seen an intake that does that, but it looks pretty cool and it works well. Also note that since the part is rotomolded we were able to hit a very specific diameter at the MAF sensor to dial in the calibration. No tune required!
This is why I recommend removing the stock inlet. It more than doubles the size of the opening the intake is drawing air from.
If you leave the inlet in, this is what the cross section looks like. Not bad, but it could be better.
Old 06-20-2012, 05:55 PM   #38
Keith@AIRAID
We did both, but the chart I posted is stock with the snorkel VS Airaid without snorkel. That was the ideal configuration.
It is built in, it looks added on in the picture because it was an on-the-fly revision to the prototype.
I believe Iceman intakes were also rotomolded, which would use the same Crosslinked Polyethelene that we use.
Old 06-20-2012, 06:10 PM   #39
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Did you guys think about making a better designed inlet to compliment your system? That way you still get fresher air (like stock) but with better flow.
uspspro is offline   Reply With Quote
Old 06-20-2012, 06:14 PM   #40
ATL BRZ
ATL BRZ's Avatar
Very cool! Thanks for explaining the big design!
Old 06-20-2012, 06:50 PM   #41
Keith@AIRAID
We are getting air from the front bumper just like stock, so there is no need to add an inlet because it's all the same air. The factory inlet only exists to house the Helmholtz resonators that control noise.
Old 06-20-2012, 08:02 PM   #42
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
just a quick check-in, still running the latest prototype, sound tube delete, OEM front bumper 'snorkel' removed -- and I still love it.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Technical information on the Toyota D-4S system arghx7 Engine, Exhaust, Transmission 72 01-13-2025 08:43 PM
cold air intake? carbonBLUE Engine, Exhaust, Transmission 72 09-30-2013 12:56 PM
FRS AEM Cold Air Intake KenAEM Engine, Exhaust, Transmission 28 10-24-2012 12:48 PM
2013 Scion FRS AEM Cold Air Intake KenAEM Engine, Exhaust, Bolt-Ons 2 07-12-2012 07:30 PM
Hello From AIRAID Filter Company AIRAID Announcements, Contests, Giveaways 3 06-11-2012 08:00 PM
