Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
06-28-2016, 07:09 PM | #43 |
Don't change your oil right after you just drove it. I've never "torqued" my drain plug. It's common sense to know it can't be loose and you can't crank on it. I feel like this part is over simplifying an already simple task. It's convenient, yes, but it's also risky. See OP.
The Following 3 Users Say Thank You to NickDC88 For This Useful Post: |
06-29-2016, 04:12 AM | #44 |
Drives: BRZ limited GBS
i have the short nipple version and it does not stick out of the skid plat.
it even says on the fumoto site not to get the normal nipple for cars with low clearance. |
06-29-2016, 08:03 AM | #45 |
Drives: BR86
I have the short nipple FU and it comfortable clears inside the alloy plate but must always be careful. As others have suggested you will hit the front nose cone first before anything else
06-29-2016, 04:06 PM | #46 |
Drives: GT86
Have had my Fumoto valve on since my first oil change (3+ years). No nipple version. Seems like it's well protected under the car.
No issues whatsoever and I took the car off road, on track. Damaged the front bumper once (off-road due to hitting a bump), no issues with the valve whatsoever. Still looks like new. The valve will not "leak" oil, it's not that easy to open. If you hit something hard enough or hear a loud bang you should stop and check it out anyway. Regardless of what modifications you have it is just common sense. |
The Following User Says Thank You to lazyluka For This Useful Post: | stevesnj (06-30-2016) |
06-29-2016, 04:32 PM | #47 | |
extra what?
And yes, to call that bottom cover a skid plate is misleading. It's there just for aero. Not structural at all. Does look nice though and really helps keep everything clean underneath.
06-29-2016, 04:37 PM | #48 | |
Turning is for Nerds
Drives: 35 characters is not enough
The Following User Says Thank You to Decay107 For This Useful Post: | funwheeldrive (02-24-2017) |
06-29-2016, 04:42 PM | #49 |
extra what?
Never considered shear loading. Hmmm!...
The Following User Says Thank You to Ultramaroon For This Useful Post: | Decay107 (06-29-2016) |
06-29-2016, 04:48 PM | #50 |
Exactly, they'd have used plastic for a structurally insignificant part especially considering how much attention was paid to making the car light weight.
06-29-2016, 04:57 PM | #51 |
extra what?
Mmmm... I dunno about that. It gets super hot down there. Either way, it's a nice part. Not exactly a full blown skid plate but it's nice.
06-29-2016, 05:05 PM | #52 |
They'd have used thermal shield and plastic. I've seen it done on enough motorcycles to know that heat is a non issue on plastics with the proper insulation.
The Following User Says Thank You to Decay107 For This Useful Post: | Ultramaroon (06-30-2016) |
06-30-2016, 12:31 AM | #53 |
extra what?
Yeah, good point. That stuff is really effective. Hell, I dunno.
06-30-2016, 01:56 AM | #54 |
for what it's worth, there's this plastic piece on both sides of the header with thermal tape on the inside. it connects to the skid plate with the push lock buttons. it sits REALLY close to the header and when I installed my headers I was wondering if it would melt... but nope it is in perfectly fine condition. I guess thermal tape works wonders
06-30-2016, 02:02 AM | #55 | |
extra what?
dammit
06-30-2016, 10:03 AM | #56 | |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
The Following 2 Users Say Thank You to stevesnj For This Useful Post: | FRSBRZGT86FAN (06-30-2016), lazyluka (06-30-2016) |
Similar Threads | ||||
FS: Fumoto Valve | jvenetto | Engine, Exhaust, Bolt-Ons | 6 | 10-01-2015 07:16 AM |
EZ oil drain same as Fumoto? | wbradley | CANADA | 18 | 06-15-2015 03:40 PM |
Fumoto valve in the winter? | Muskokan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 02-25-2014 12:06 PM |
Question about Fumoto valve | Bleevin | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 04-18-2013 09:27 AM |
